Question on Supplier Quality (SCAR)
duff999
I have a question related to managing the supplier quality (SCAR) process.
In a situation where the supplier implemented a corrective action that was deemed ineffective after verification what would be the next best steps:
1. Update the SCAR with the results and close out the CAPA that was issued to raise the SCAR, and then open a new CAPA and a new SCAR and start the process over?
2. Or is there a better process to document the next steps?
Any advice would be appreciated
William55401
Hello Duff999. This is a style question. You decide. As long as the overall outcome gets you to a verified CA, that is success. With that said, my gut reaction is to declare the EC (effectiveness check) ineffective and return the CAPA for reinvestigation. Go back to go, do not collect $200 (if I have to explain this, it's not funny..does anyone play board games anymore?.).
Your QMS procedures may explicitly state to close it as ineffective and open a new event. In the absence of QMS instruction, I would return the issue to investigation. Next time you update your SOP, add this workflow so you don't have to be creative next time an EC fails.
Have fun. Hope this helps. Enjoy the ride!
John C. Abnet
Teacher, sensei, kennari
Good day @duff999 ;
In all of the organizations I have worked for we developed a supplier handbook, which , ...
1- first and foremost, provided the information and tools (forms, links, etc... ) that the suppliers needed to interact with our organization and be
successful.
2- Listed all the terms/abbreviations needed to interact with our organization.
3- Laid out the rules of engagement
(I also help my clients construct similar handbooks).
As part f "3" above, we always described the QMR (Quality Management Review) process. Wherein, the conditions that may initiate a QMR are stated, including failure to reply, overdue CM, repeat failures, safety critical failures, line stoppage occurrences, etc..etc... Regardless of what it is called ("QMR< etc...), there needs to be a stipulated recourse. The QMR, as described here, required a member of the supplier management to come to our site and present in regard to how the occurrence was allowed to happen and the corrective action to prevent recurrence.
Keep in mind, however, a QMR should be a last resort for a problematic supplier. Hopefully you are able to mentor them by "red lining' their corrective action and retuning it to them. A strong relationship is the best approach when developing a strong supply chain. Teach them. Mentor them. Go to their site and review their processes and educate them. If all that fails, then having a QMR defined in the supplier handbook (which is /should be part of the "contract" with the supplier), should be initiated.
Hope this helps.
Be well.
John C. Abnet
...by the way, It is helpful to have specific rules for what is a "CAR", what allows closure of a "CAR", etc..etc...
I would recommend that the original not be closed until an acceptable countermeasure has been received. IF the original was already closed, then a recurrence would (my recommendation) constitute creating a new event.
Hope this helps.
Be well.
Evelyn7E
Just curious what is your definition of not effective? Have you categorize the problem as special cause or common cause problem.
Ed Panek
QA RA Small Med Dev Company
Its up to you. I always imagine having to explain to a large customer why we did something and if I feel comfortable with that, its usually ok. Just obey your SOPs if applicable here.
I don't know how many definitions of "not effective" are possible in this context. We should assume, for the purposes of this thread and the OP's question, that a nonconformity occurred, the supplier was asked to remove or neutralize the cause, and the supplier's efforts failed. I think also that application of special/common cause categorization is irrelevant; those terms are generally applied to control chart phenomena, in which case a common-cause issue may or may not result in a nonconformity.
G Question - Supplier Quality Manual: Content, Purpose, Format? Supplier Quality Assurance and other Supplier Issues 17
M ISO 13485 Supplier Question ISO 13485:2016 - Medical Device Quality Management Systems 13
D Question and advice for a supplier self audit questionnaire ISO 13485:2016 - Medical Device Quality Management Systems 6
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Supplier audit question cataloque VDA Standards - Germany's Automotive Standards 0
Ed Panek Inactive key supplier question - We are not actively buying from them ISO 13485:2016 - Medical Device Quality Management Systems 2
J AS9100 Rev. D - Question about 8.4.3 (k) - Supplier Certificates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
I Supplier Selection based on Total Cost question Supplier Quality Assurance and other Supplier Issues 4
R Supplier Metrics Analysis question Supplier Quality Assurance and other Supplier Issues 4
M ISO 13485 Calibration Supplier Evaluation Requirements question Other ISO and International Standards and European Regulations 2
T ISO 14001 Implementation Help & Question about Supplier Approval ISO 14001:2015 Specific Discussions 5
J New Vendor (Supplier) Certification & AQL Question AQL - Acceptable Quality Level 1
J Prior Notice of Sub-Supplier or Material Source Change - PPAP Requirements Question APQP and PPAP 13
S Supplier Development Process failed - Question regarding sub-suppiler audits IATF 16949 - Automotive Quality Systems Standard 4
L Question: outsource medical device electric safety test to OEM supplier ISO 13485:2016 - Medical Device Quality Management Systems 3
J Question regarding supplier approvals ISO 13485:2016 - Medical Device Quality Management Systems 12
D Long Time Supplier sending Out-of-Specification Parts - Supplier Question Supplier Quality Assurance and other Supplier Issues 18
P Part Identification question - Supplier's identification on the box ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L Supplier ScoreCard Question - Declared NonConformance vs Undeclared NonConformance Supplier Quality Assurance and other Supplier Issues 3
ScottK ISO9001 Approved Supplier List format question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C Question on Finding - BSI Stage 2 ISO 13485:2016 Certification - PMS ISO 13485:2016 - Medical Device Quality Management Systems 5
J Quick question about 9001 Quality Objectives Manufacturing and Related Processes 9
was named killer PROCESS OWNERSHIP (QUICK QUESTION) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
N Private Label Manufacturer Question Canada Medical Device Regulations 2
Q Question on finding • Failure to follow Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
H A question about Null Hypothesis for 1 Sample T-test Statistical Analysis Tools, Techniques and SPC 6
Z AS9102B Form 1, line 19 question. Is a printed name and signature both required or is only a signature sufficient? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
K Question on registration of class 1 medical device in Turkey Other Medical Device Regulations World-Wide 0
L General FMEA Question FMEA and Control Plans 2
D What do you think of Chat GPTs answer to this Risk Acceptability question? ISO 14971 - Medical Device Risk Management 5
A Question regarding new VDA_AIAG fmea approach for process FMEA FMEA and Control Plans 0
Ed Panek FDA Submission Question US Medical Device Regulations 3
M Cleanroom Question Manufacturing and Related Processes 10
T Aircraft GAPP Software Testing Compliance Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
sonflowerinwales Quick question M3 screw plug gauge AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
B FDA regulations medical device prescription fulfillment DME question US Medical Device Regulations 0
M An interesting question about import company Other Medical Device Regulations World-Wide 5
Sam.F Question about training Training - Internal, External, Online and Distance Learning 20
B Labeling question about different manufacturers on a single label Manufacturing and Related Processes 4
J Question regarding classification of custom made device EU Medical Device Regulations 5
Sam.F Question about granite surface plates out of spec AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Ed Panek MDR question - Meaning of Stability CE Marking (Conformité Européene) / CB Scheme 6
B GD&T Question, True Position Confusion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Initial Importer question Other US Medical Device Regulations 2
Ed Panek Calibration question Manufacturing and Related Processes 4
M Class Exempt Medical Device Recall Question US Food and Drug Administration (FDA) 3
sonflowerinwales Metric or Imperial; that is the question... After Work and Weekend Discussion Topics 6
M Can someone help me with this CMM programming question? Manufacturing and Related Processes 2
A A strange question about predicate device selected in 510(k) submission Medical Device and FDA Regulations and Standards News 8
S Question regarding AQL - ISO 3951 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
