Question on whether IEC 60601-2-62 standard is applied
Hello everyone.
I'm medical device test engineer. one of my customer asked me whether IEC 60601-2-62 is applied to skin lifting device.
In the scope of the IEC 60601-2-62, this standard is applied to therapeutic high intensity ultrasound equipment.
Since skin lifting device is not therapeutic equipment but beauty equipment, I'm not sure but I think there is no need to apply IEC 60601-2-62.
I would like to have some advise on this. Thank you.
Benjamin Weber
As Ronen E already asked: What is the physical effect to achieve the skin lifting?
Second question: Is this a medical device? I guess not really, since it is only for cosmetic reasons. If we are talking about the european market, the MDR is applicable. There is Annex XVI, were some device types are explicitely listed, which do not fall under the definition of a medical device but whoch are also in the scope of the MDR. As far as I can see, a skin lifting device that uses ultrasound is not covered here. But this strongly depends on the physical effect! Annex XVI lists for example:
Equipment intended to be used to reduce, remove or destroy adipose tissue, such as equipment for liposuction, lipolysis or lipoplasty.
Maybe this applies to the device?
If not: Which regulation or directive should be followed? Sometime cosmetic device manufacturers apply the low-voltage directive hoping they might completely forget about the 60601 series. But the problem is, that you have to apply the current state of art according to all regulations/directives I know. And performing some kind of risk management might find that you have to apply of course the relevant harmonized standards of the directive/regulation, but also relevant standards that are beyond the harmonized standards. This might lead to applying 60601 for non medical devices.
So, if the device really uses high intensity ultrasound, I think IEC 60601-2-62 should be applied. I don't have the complete standard, so I am not really sure how "hight intensity therapeutic ultrasound" is defined, maybe this could clarify if the standard is applicbale?
But be aware, that there are also exclusions in the scope:
This particular standard does not apply to:
• ULTRASOUND EQUIPMENT intended to be used for physiotherapy (use: IEC 60601-2-5 [1]2)
and IEC 61689);
• ULTRASOUND EQUIPMENT intended to be used for lithotripsy (use: IEC 60601-2-36 [2]);
• ULTRASOUND EQUIPMENT intended to be used for dedicated hyperthermia devices;
• ULTRASOUND EQUIPMENT intended to be used for phacoemulsification.
Maybe one of these applies to the device?
Ronen E
Problem Solver
Moderator
A few of comments:
1. Not all regulatory jurisdictions require/expect that the state of the are is kept up with (it's mostly an EU thing). There are pre-amendments (pre-1976!) devices perfectly-legally in distribution, with no FDA expectation of manufacturers to update them or their original clearance.
2. Under no circumstances anyone "has to" apply any harmonized standards as such.
Annex A of the standard IEC 60601-2-62 sates:
Definition 201.3.218 HIGH INTENSITY THERAPEUTIC ULTRASOUND (HITU) EQUIPMENT
HIGH INTENSITY THERAPEUTIC ULTRASOUND (HITU) is a precise medical procedure using high
levels of ultrasound intensity (e.g. Ispta > 100 Wcm-2) or ultrasound pressures (e.g. p-> 3 MPa
but this is frequency dependent) to destroy or disrupt tissue or non-tissue elements (for
example liquids, bubbles, micro-capsules).
I doubt that the device is able to produce such levels of intensity or pressures. Therefore, I don't believe that the -2-62 is the right standard to apply.
I would rather take a look the standards -2-5 or -2-37 to check the levels of Mechanical Index, Thermal Indices (-2-37), Beam non linearity ratio (-2-5) and the requirements for the transducer heating (both standards).
S Contract Manufacturer Question - Whether or not the reference to the ex-CMO ISO 13485:2016 - Medical Device Quality Management Systems 6
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
C Gauge R&R Question Using Minitab Software 1
K Question on MDR classification EU Medical Device Regulations 4
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
D Work Instruction Question ISO 13485:2016 - Medical Device Quality Management Systems 5
M Clinical Decision Support Software Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
D Equipment Register and PM question ISO 13485:2016 - Medical Device Quality Management Systems 2
D Question regarding "storage and distribution" ISO 13485:2016 - Medical Device Quality Management Systems 1
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
D Equipment Register related question ISO 13485:2016 - Medical Device Quality Management Systems 1
S Study sign off question / responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 3
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
M Question for Auditors - "Off the Record" Conversation? General Auditing Discussions 14
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
R Accelerated Aging - Creating test samples - Implantable medical device Question Other Medical Device Related Standards 4
A Question on Authorized Representative in Malaysia Other Medical Device Regulations World-Wide 3
D Limited Scope for second site Question? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I ISO 2233:2000 Question - Medical Device Shipping/Transportation Validation Other ISO and International Standards and European Regulations 1
Anonymous16-2 Labeling Question (Dietary Supplements/Food) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
T Question for: Cg & Cgk calculation General Measurement Device and Calibration Topics 3
N ASL Question for GitHub ISO 13485:2016 - Medical Device Quality Management Systems 6
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
A Question on ISO 14001:2015 - Are annual audits required? ISO 14001:2015 Specific Discussions 11
dinaroxentool Question about FDA Classification of a Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Another DFAR question 252.225-7009 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
F Conflict Mineral Smelter Question RoHS, REACH, ELV, IMDS and Restricted Substances 8
R NRTL - Scope Question - Off-the-Shelf Plug In IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
dinaroxentool Question about qualification as a medical device or accessory in Europe EU Medical Device Regulations 2
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
C MDR - Question around software accesories EU Medical Device Regulations 2
K My question is, what/when is a nonconformity? Therefore what requires an NCR? Nonconformance and Corrective Action 9
Watchcat Authoritative References about the Research Question? Quality Tools, Improvement and Analysis 0
T Question about Quality Department employee position titles Quality Manager and Management Related Issues 10
N Question on creepage/clearance requirements for HF Active Accessories for 2nd edition 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Question: How to create an IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
B QMS question in regards to multiple medical devices/products and N/A activities Other Medical Device Related Standards 12
C NB approval - Basic question about Notified Bodies and their role EU Medical Device Regulations 10
G Question about Non-conformances during New Product Introduction Nonconformance and Corrective Action 14
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
O Mitutoyo Digital Caliper to PC USB question General Measurement Device and Calibration Topics 2
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
Q Supplier audit question cataloque VDA Standards - Germany's Automotive Standards 0
Ed Panek Inactive key supplier question - We are not actively buying from them ISO 13485:2016 - Medical Device Quality Management Systems 2
