It appears to define "enforcement discretion" as being exempt from the 510K submission process.
quote: ...exemption from the requirement of premarket notification (section 510(k) of the act) for a generic type of class I or II device is only to the extent that the device has existing or reasonably foreseeable characteristics of commercially distributed devices within that generic type or...
FDA also lists several reasons why a device would not be exempt, such as the device having a different intended use.
To answer your original question: it seems that a 510k will not be required as long as your device has a predicate, of the same classification, already legally on the market. I strongly recommend you hold a detailed documentation explaining how/why your device and the predicate have the same intended use and the same fundamental scientific technology.
Dear All, So it means the company has only to register & list their devices and have GMP put in place if required ? and then can put MD on the US market ?
Yes, but be sure to study the applicable guidance as noted above, and memo-to-file how your particular product conforms to the applicable requirements.
