Question re: Class II Medical Device Software - Label / Device Definition
W
WP_Regulatory
Hi: I have two questions concerning medical device software:
1) The product in question is software, which is provided with a cart and monitor. The software itself allows clinicians to provide patient care by transmitting patient images from remote locations through the use of telecommunication lines and wireless communication infrastructure. The aspect of the device that makes it Class II is the software; therefore, is it appropriate to consider the software the device, and the other pieces of equipment accessories?
2) What kind of label should be included with the software to meet US label requirements? My thought is that this information should be on the initial splash screen, but I am struggling with whether the monitor and cart, etc., should also include a label specific to US label requirements.
Thanks in advance for any help!
Ronen E
Problem Solver
Moderator
Hello and welcome to the Cove :bigwave:
Is the software stand-alone, i.e. can it run (and is it supplied in a way that it can be installed) on an ordinary computer? Or is it "embedded" in you system (or a component of it)? Further, to meaningfully answer regulatory questions, it is quite important to have a complete description of the device / system. At the moment I understand that you provide a package that includes a software, a monitor, a cart, and some other type of console. Is that true? Are there other components? Which are essential for operation, and which are "nice to have"? Are all/some of the components "rigidly" connected together, or is it a rather modular system (phisically, electronically, functionally)? etc. etc.
It sounds that the software could be "the device" and the monitor and cart could be accessories. Please note that in the USA accessories to medical devices are classified and regulated under the same ProCode as the device which they are accessories to (execpt in specific few cases, where certain types of accessories have their own specific ProCodes).
If you sell the software and the accessories separately, each must comply with all applicable labeling requirements, on their own:
http://www.fda.gov/MedicalDevices/DeviceRegulationandGuidance/Overview/DeviceLabeling/
If, on the other hand, all the components are supplied as one system, which is the regulated object, one main set of labeling should suffice, with (as applicable) individual labels to address any requirements that can't be met via such a "central" set. If you intend to provide parts of the labeling in electronic format (e.g. some software screens etc.), pay attention to applicable requirements. Most of the labeling regulations and guidance are focused on hard labeling.
Cheers,
Ronen.
W
WP_Regulatory
Hi Ronen:
Thanks so much for your fast and detailed reply. The software is installed on a laptop that is provided to the customer, with the cart and monitor. The only testing I see as being needed for this device is software V&V to support the 510(k); I do not see any other kind of performance testing that would be required.
The components are all sold together as the device - there will be an IFU and also a "label" on the splash screen when starting the program. But there are currently no plans for physical labels for the cart or monitor (or laptop).
Thanks again for your help.
I
isoalchemist
You might want to take a look at the Medical Device Data System (MDDS) guidance, I think it was finalized, but I'm not 100%; based on what you stated earlier.
Also most "telecommunication carts" have 60601 certification or conformance statements associated with them. Don't know your system, but this safety evaluation should at least be considered.
W
WP_Regulatory
Thanks; I did think of that. I need to check into the cart in more detail; it is not one that the software manufacturer designed, but it makes sense to determine what testing may have been performed on it previously by the company that does manufacture it. I will also check on the MDDS guidance.
Thanks again.
S Conformity Assessment Route question for Class IIa medical device under MDR EU Medical Device Regulations 3
C Class I Medical Device ProCode JCB Question 2 (UDI) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Class I Medical Device ProCode JCB Question 1 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B Class II Medical Device UDI (Unique Device Identification) Question(s) Other US Medical Device Regulations 8
J Question about CE mark for Dental Gel which is probably Medical Device Class 2a EU Medical Device Regulations 2
Q Remanufacturing and Refurbishing of Class 1 Medical Devices - Process Question ISO 13485:2016 - Medical Device Quality Management Systems 8
M GMP Question for Polyethylene Drum Faucet - Class I Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
Ron Rompen Question on 'Class of Fit' - Gage Pin Clearance Manufacturing and Related Processes 2
Q US FDA UDI Compliance Question - Class II (Special Controls) Other Medical Device and Orthopedic Related Topics 4
F Class II 510(k) question for device with different EU - US configuration 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Question re: Class II 510K Enforcement Discretion US Food and Drug Administration (FDA) 5
J ISO 14644-5 section C3 - ISO Class 7 question Other Medical Device Related Standards 4
D GCP for Class III Device Programming (Predecessor Device Program question) US Food and Drug Administration (FDA) 2
S CE Marking Question - Class IIa device by complying with Annex V & VII EU Medical Device Regulations 10
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
C Gauge R&R Question Using Minitab Software 1
K Question on MDR classification EU Medical Device Regulations 4
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
D Work Instruction Question ISO 13485:2016 - Medical Device Quality Management Systems 5
M Clinical Decision Support Software Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
D Equipment Register and PM question ISO 13485:2016 - Medical Device Quality Management Systems 2
D Question regarding "storage and distribution" ISO 13485:2016 - Medical Device Quality Management Systems 1
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
D Equipment Register related question ISO 13485:2016 - Medical Device Quality Management Systems 1
S Study sign off question / responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 3
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
M Question for Auditors - "Off the Record" Conversation? General Auditing Discussions 14
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
R Accelerated Aging - Creating test samples - Implantable medical device Question Other Medical Device Related Standards 4
A Question on Authorized Representative in Malaysia Other Medical Device Regulations World-Wide 3
D Limited Scope for second site Question? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I ISO 2233:2000 Question - Medical Device Shipping/Transportation Validation Other ISO and International Standards and European Regulations 1
Anonymous16-2 Labeling Question (Dietary Supplements/Food) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
T Question for: Cg & Cgk calculation General Measurement Device and Calibration Topics 3
N ASL Question for GitHub ISO 13485:2016 - Medical Device Quality Management Systems 6
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
A Question on ISO 14001:2015 - Are annual audits required? ISO 14001:2015 Specific Discussions 11
dinaroxentool Question about FDA Classification of a Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Another DFAR question 252.225-7009 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
F Conflict Mineral Smelter Question RoHS, REACH, ELV, IMDS and Restricted Substances 8
R NRTL - Scope Question - Off-the-Shelf Plug In IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
dinaroxentool Question about qualification as a medical device or accessory in Europe EU Medical Device Regulations 2
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
C MDR - Question around software accesories EU Medical Device Regulations 2
K My question is, what/when is a nonconformity? Therefore what requires an NCR? Nonconformance and Corrective Action 9
