Question regarding O-ring application for water proofing a device
Q
quality1
I would like to ask experts in Rubber O-Rings if you can help me. We're new to using O ring in our products. The O-ring material is "nitro", size is 1X13 mm. We have a body and a cap, in between the body and the cap is where the O-ring sits, this is for water proofing the device. Our problem is when the cap is snapped into the body, the O-ring tends to twist which does not provide a good seal. We tried to resolve the problem with silicon lubricant which seemed to help. Can an expert determine if there's a better way of preventing twist besides using the lubricant? Our dimension is correct for the part and O-ring.
Thank you in advance for your help!
Re: Rubber O-Ring Inspection Standard - SAE J515?
I am not an o-ring expert, but I have some experience with them and have a lot of experience with rubber products.
First, o-rings are not ideal for this type of application. They are better suited as a static seal. If the seal is to be dynamic, it should be a straight compression, not shear. Your application will rapidly wear and stress the rubber resulting in shortened life. Do you have a retention groove for the o-ring? The retention groove allows the o-ring to seal on all 4 sides versus the top and bottom only.
Second, make sure the rubber is compatible with the silicone lubricant.
The following is a description of nitrile rubber o-rings by Da-Pro Rubber Co.: "Nitrile rubber is more resistant to oils and acids compared to natural rubber but is not as strong or flexible. Like natural rubber it can be attacked by ozone, aromatic hydrocarbons, ketones, esters and aldehydes but is generally resistant to aliphatic hydrocarbons."
Skydog
Sorry for not replaying before. Could you please share a picture?
I work for major O-ring manufacturer.
Nitrile works for water with no problem. But also it does EPDM. The advantage of EPDM is that is resistant to weather and ozone (NBR can be made resistant, but is not inherent to the material).
To avoid the twist, one solution would be using X-Rings, instead of o-rings... But the cost generaly is higher.
We have several options for materials (many of them used with water, as NSF approved material), some with internal lubricant, some with external lubricant added.
Please send me the the pictura or sketch of the assembly, along with some information about the application (temperature range, liquids expected to have contact, etc), and I may give a better indication.
Sincerely yours,
Daniel
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
D Question regarding "storage and distribution" ISO 13485:2016 - Medical Device Quality Management Systems 1
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
C Question regarding Quality Manual Content and Specificity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
optomist1 Generic question regarding Two Way ANOVA Results Statistical Analysis Tools, Techniques and SPC 8
apestate Question on wording in DOD RFQ regarding ISO 9000 Various Other Specifications, Standards, and related Requirements 7
N ASME B89.1.13 question regarding Resolution and Maximum Permissible Error General Measurement Device and Calibration Topics 3
B Question regarding Mandatory Procedures and Manual AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
P Question in auditing regarding CAR (Corrective Action) Logs Internal Auditing 7
S Supplier Development Process failed - Question regarding sub-suppiler audits IATF 16949 - Automotive Quality Systems Standard 4
J Question regarding Device Master Records & Specification Developers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
J Question regarding supplier approvals ISO 13485:2016 - Medical Device Quality Management Systems 12
J Cancellation of Specifications - Question regarding cancelled specifications Various Other Specifications, Standards, and related Requirements 3
ScottK ASME B&PVC Section VIII Div 1 question regarding "Seal" Various Other Specifications, Standards, and related Requirements 0
K Auditor's Question Regarding TS16949 Clause 7.5.2 - How vague can an auditor be IATF 16949 - Automotive Quality Systems Standard 18
S Question regarding document control - Control EVERY version of the same graphic? Document Control Systems, Procedures, Forms and Templates 5
A Question regarding TS16949 auditor rules 3.3 - Different auditors IATF 16949 - Automotive Quality Systems Standard 4
C Question Regarding MSA (Measurement Systems Analysis) - Pass / Fail Criteria tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
E Question Regarding OHSAS 18001 Occupational Health & Safety Management Standards 3
C Gauge R&R Question Using Minitab Software 1
K Question on MDR classification EU Medical Device Regulations 4
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
D Work Instruction Question ISO 13485:2016 - Medical Device Quality Management Systems 5
M Clinical Decision Support Software Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
D Equipment Register and PM question ISO 13485:2016 - Medical Device Quality Management Systems 2
D Equipment Register related question ISO 13485:2016 - Medical Device Quality Management Systems 1
S Study sign off question / responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 3
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
M Question for Auditors - "Off the Record" Conversation? General Auditing Discussions 14
R Accelerated Aging - Creating test samples - Implantable medical device Question Other Medical Device Related Standards 4
A Question on Authorized Representative in Malaysia Other Medical Device Regulations World-Wide 3
D Limited Scope for second site Question? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I ISO 2233:2000 Question - Medical Device Shipping/Transportation Validation Other ISO and International Standards and European Regulations 1
Anonymous16-2 Labeling Question (Dietary Supplements/Food) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
T Question for: Cg & Cgk calculation General Measurement Device and Calibration Topics 3
N ASL Question for GitHub ISO 13485:2016 - Medical Device Quality Management Systems 6
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
A Question on ISO 14001:2015 - Are annual audits required? ISO 14001:2015 Specific Discussions 11
dinaroxentool Question about FDA Classification of a Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Another DFAR question 252.225-7009 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
F Conflict Mineral Smelter Question RoHS, REACH, ELV, IMDS and Restricted Substances 8
R NRTL - Scope Question - Off-the-Shelf Plug In IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
dinaroxentool Question about qualification as a medical device or accessory in Europe EU Medical Device Regulations 2
