Questions on Technical File to show it is current
K
katastic2908
Good Afternoon,
I really just want to scream right now so I am hoping someone here can talk me off the ledge.
Ok, during our recent unannounced NB audit we were given a finding because the particular Tech File for the product they were observing during the audit wasn't up to date. What I mean is some of the controlled documents within the tech file had be revised and the tech file didn't have the most recent revisions and in the Tech File itself it referenced both the document number and revision of the applicable document.
Fine, I'll take my CAPA like a grown up. So I have been searching and searching the dark corners of the interwebs and can't find what I need.
So here are my questions and I would appreciate any links to guidance documents if you have any
1. Can the Tech File be a document that references other documents within our DMR and DHF that comprise the Tech file which can still be accessed onsite, or does the Tech File itself need to also contain copies of those documents at all times?
2. Does a Tech File need to have a revision history that would include descriptions of all of the changes made to the documents contained within the tech file? It seems redundant to be since each document has its own revision history.
depending on the responses I get I may have more follow up questions.
Thank you for taking the time to read and respond, I really do appreciate it.
pkost
In my mind the technical file is more of a concept than a file
The information that is required to be in a technical file must be accessible, but nothing says that that has to be in a single location such as a filing cabinet all in neat order. It could be multiple files spread out over the site.
A contents list of all required documents and their location is sufficient; I'd probably even go as far to say that the contents list doesn't need to list the versions if you can adequately show that your change control of a document adequately assessed and approved the affect on the product/file as a whole - the version your contents list points to will always be the current approved and this can be identified on that specific document
With regards to the change history, this forms part of the original sub document therefore is intrinsically part of the technical file, it doesn't need to be reproduced!
somashekar
Good Afternoon,
1. YES. No need to duplicate. This leads to your current situation.
2. NO. Again duplication. Your TF as a whole needs a revision control.
We maintain our Technical Files as ring-bound paper files.
Tech A has 6 sections, Tech B 13. The 'Contents' front page shows the issue number for each section along with the date and Change Note number of when it was last changed. The Change Note records details of the change.
For the sections that call for test specifications and for manufacturing drawings, both of which are part of the Device Master File, the TF just has a pointer. The Issue number of the Contents page is used as the Issue number of the entire file - this is recorded in the DMF.
(Strictly speaking the drawings and other parts of the DMF are part of the Tech Files rather than the other way around).
For the Instructions for Use it just has a pointer to a server location and a path that ends ...IfU-IssN, where N is the highest number available.
It actually works fairly painlessly, and having the entire TF available, in one easily referred to package was a definite benefit when it came to our unannounced audit. (One 'Minor')!
hogheavenfarm
"...What I mean is some of the controlled documents within the tech file had be revised and the tech file didn't have the most recent revisions and in the Tech File itself it referenced both the document number and revision of the applicable document..."
I simply refer to the documents (name/title) and instead of quoting the revision, I state "(current revision level)" so I do not have to scramble every time a referenced document is revised. Periodically I review the tech file and make any updates needed (if there is a major document change or new process). That's when I note in the revision matrix that I reviewed the file and date it, if there are changes it gets a new revision then.
A CE Marking Technical File questions EU Medical Device Regulations 2
Q New Casting Supplier System Assessment - What technical questions to ask? Supplier Quality Assurance and other Supplier Issues 3
P Basic questions about earning TSOA (Technical Standard Order Authorization) and PMA Federal Aviation Administration (FAA) Standards and Requirements 2
K Technical quality interview questions, answers, and tips Career and Occupation Discussions 7
M Internal Audit questions on Technical Resources & Work Environment Internal Auditing 9
C UDI Questions on Control Units Other US Medical Device Regulations 6
M NFPA 70 electrical harness questions Various Other Specifications, Standards, and related Requirements 2
L Project Managers - Questions For You Career and Occupation Discussions 0
B Toyota PPAP Process - Three Questions APQP and PPAP 3
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
D Signature Matrix questions ISO 13485:2016 - Medical Device Quality Management Systems 4
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
C 8.5.1.1 Control of Equipment, Tools, and Software Programs - Questions about the extent of control of NC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Rules for Paper Forms outside of an eQMS - 3 Questions (ISO 13485) Document Control Systems, Procedures, Forms and Templates 9
D Shipping and recall questions ISO 13485:2016 - Medical Device Quality Management Systems 2
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 6
M Quality Metrics Questions Lean in Manufacturing and Service Industries 2
K FDA Premarket Cybersecurity Guidance - 4 questions Other US Medical Device Regulations 5
A Some questions about voluntary consensus standards in traditional 510(k) submission US Food and Drug Administration (FDA) 6
T AMS2570E certification equipment questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Mr Roo ISO 9001 - 7.1.3 Infrastructure - questions concerning evidence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Medical Device Identification & Codes - Article 27 Requirements questions EU Medical Device Regulations 1
Q Asset / Tooling Management - Two Questions Manufacturing and Related Processes 3
Q VDA 6.3 questions vs IATF 16949 clauses VDA Standards - Germany's Automotive Standards 0
I Questions to ask when auditing for Organizational Leadership and Planning for the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO13485:2016 name and ownership changes questions ISO 13485:2016 - Medical Device Quality Management Systems 3
C CQA Test Questions Bank General Auditing Discussions 1
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Informational EU – EMA revised guidance – Questions & Answers on Implementation of the Medical Devices and In Vitro Diagnostic Medical Devices Regulations ((EU) 201 Medical Device and FDA Regulations and Standards News 2
M Informational EU – MDCG 2019-6 v2 Questions and answers: Requirements relating to notified bodies Medical Device and FDA Regulations and Standards News 0
Ed Panek Relevant questions on Substantial Change Form CE Marking (Conformité Européene) / CB Scheme 3
K Beginner in ISO 45001 here! Three questions Occupational Health & Safety Management Standards 6
D Framing FDA Questions - Validation US Food and Drug Administration (FDA) 1
M Informational US FDA – Frequently Asked Questions (FAQs) About the Accreditation Scheme for Conformity Assessment (ASCA) Pilot Medical Device and FDA Regulations and Standards News 0
F Barcoding questions - Is there a plain English primer for newbies? ISO 13485:2016 - Medical Device Quality Management Systems 10
D Questions about the contents of a Design History File 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S ISO 14971 Risk Management - Questions for Hazard identification ISO 14971 - Medical Device Risk Management 2
M Informational EU – MDCG 2019-6 Questions and answers: Requirements relating to notified bodies Medical Device and FDA Regulations and Standards News 0
C MDR Importer/Distributor Definition Questions EU Medical Device Regulations 14
A Purchasing - Internal Audit Questions Internal Auditing 8
M Informational USFDA – Efforts to evaluate materials in medical devices to address potential safety questions Medical Device and FDA Regulations and Standards News 0
M Informational USFDA draft guidance – A Risk-Based Approach to Monitoring of Clinical Investigations Questions and Answers Guidance for Industry Medical Device and FDA Regulations and Standards News 0
E Basic Risk based thinking questions Risk Management Principles and Generic Guidelines 5
F Job Travelers questions - unsigned operations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 41
J Training documentation - ISO 13485 audit and the auditor had questions General Auditing Discussions 7
G Auditor watching tech do procedure - Can tech ask questions? ISO 17025 related Discussions 6
A Any recommendation for ASQ's CPGP (Pharmaceutical GMP Professional) Certification exam questions? ASQ - American Society for Quality 2
M Informational EU – Questions And Answers Related To The United Kingdom’s Withdrawal From The European Union With Regard To Industrial Products Medical Device and FDA Regulations and Standards News 0
