Questions on use of SPC, Ppk, Cpk during PPAP
bobdoering
Stop X-bar/R Madness!!
#11
For those just coming across this issue in the archives, I am updating the responses to current requirements:
Since, I have tried to ask the following question to our consultant but nothing clear for me.
Go figure...:rolleyes:
My question is quite simple and I would like to ask by using the following model.
Model: Suppose that I have one new machine which operate only one process , let say drilling dia 10 +/- 0.1 mm and roughness is 6.3Rz . Our customer request us to use SPC for both value where the requirements are
1) For PPAP, Ppk must greater than 1.67
2) For ongoing SPC Cpk must greater than 1.33
Question: 1)Why we use Ppk at the PPAP stage? (Ppk is for long term study but doe not require for stability???)[/
It is probably not applicable at all. Drilling is not a normal distributions, and surface finish is not a bilateral specification. See below:
AIAG PPAP 4th Edition
2.2.11.5 Processes with One-Sided Specifications or Non-Normal Distributions
NOTE: The above mentioned acceptance criteria (2.2.11.3) assume normality and a two-sided specification (target in the center).
When this is not true, using this analysis may result in unreliable information.
NOTE (cont.): These alternate acceptance criteria could require a different type of index or some method of transformation of the data. The focus should be on understanding reasons for the non-normality (e.g. is it stable over time?) and managing variation.
Question: 2)Do we need to use X bar R chart during our run for PPAP?
For drilling, use a X hi/lo-R chart. Xbar -R chart is the worst chart you can use. See Statistical process control for precision machining . You might be able to use an X-bar-R chart for surface finish if it is bad enough to exhibit a normal distribution.
Question 3)If yes in 2, How can we set a UCL and LCL?
You need to do a capability study to determine the true control limits for the surface finish.
Question 4) For one side spec (roughness in this case),if the requirement is Ppk greater than 1.67. It means that the average value will near 3.2Rz which also means that we have to design our process not for 6.3Rz but for 3.2Rz Otherwise, we will not earn those. For this case, it will cost a lot more, so can we use Pp for this.
See Question 1.
Question 5) When will we apply Cpk instead of Ppk (when it stable??)
See Question 1.
Question 6) UCL, and LCL of X bar and R chart of Cp, Cpk come from???
They originate from the capability study.
Question 7) Since Cpk is a study of short term, so how can we use Cp for ongoing process??
See Question 1.
atulsharma98
#12
Dear
As per aiag guidelines during ppap run we have to take 300 consicutive parts
and for consicutive data only ppk is valid
and secondly as per ppap we have to go for initial process study where all causes can be captured
2) and secondly for ppap you no need to go for xbar r chart
bobdoering
#13
Yes, per AIAG the minimum run size requirement is 300 consecutive parts. The common problem is people stop reading when they get the simple answer. One of the Big 3s customer specific requirements does not agree that the 300 pcs are consecutive, but rather the PPAP run is long enough to capture all variability (shift, tool, machine, etc.) and that if it exceeds 300 the capability samples are to be spread out evenly over the entire run.
Also, in AIAG PPAP 4th edition, 2.2.11.4 requires the process has to be stable. Guess how that is established? Yep, a control chart. The correct control chart - may not necessarily be X-bar/R. Also, it states all special causes are to be removed. How are they identified? Yes, control charts.
Sections 2.2.11.1 specify the evidence is needed for special characteristics. Remember, the customer print may not be the only source of special characteristics. APQP 2nd edition section 2.11 states they are a concurrence of the customer and the supplier and often discussed in the Customer Specific Requirements. CSRs may also expand the need for evidence beyond just the special characteristics. The most correct answer to any question: it depends.
So, I agree the x bar/R chart itself is not required (and shouldn't be - it is not always the right one), but the correct control chart is. It may not be mandated to be included in the PPAP package (and not everything is) but you would need it to support your claim the process is stable.
Clarity and conciseness (and, in cases accuracy) is not the AIAG's strong suit. The rule on verboseness, though!
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
M SPC, Moving Range Chart and Weighted Graph Basic Questions Statistical Analysis Tools, Techniques and SPC 1
B Frequently asked PPAP, FMEA, SPC, MSA, APQP & 7QC Tools questions for Interviews Career and Occupation Discussions 1
T Conceptual Questions on SPC - Operating characteristic curve of a control chart Statistical Analysis Tools, Techniques and SPC 2
C UDI Questions on Control Units Other US Medical Device Regulations 6
M NFPA 70 electrical harness questions Various Other Specifications, Standards, and related Requirements 2
L Project Managers - Questions For You Career and Occupation Discussions 0
B Toyota PPAP Process - Three Questions APQP and PPAP 3
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
D Signature Matrix questions ISO 13485:2016 - Medical Device Quality Management Systems 4
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
C 8.5.1.1 Control of Equipment, Tools, and Software Programs - Questions about the extent of control of NC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Rules for Paper Forms outside of an eQMS - 3 Questions (ISO 13485) Document Control Systems, Procedures, Forms and Templates 9
D Shipping and recall questions ISO 13485:2016 - Medical Device Quality Management Systems 2
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 6
M Quality Metrics Questions Lean in Manufacturing and Service Industries 2
K FDA Premarket Cybersecurity Guidance - 4 questions Other US Medical Device Regulations 5
A Some questions about voluntary consensus standards in traditional 510(k) submission US Food and Drug Administration (FDA) 6
T AMS2570E certification equipment questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Mr Roo ISO 9001 - 7.1.3 Infrastructure - questions concerning evidence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Medical Device Identification & Codes - Article 27 Requirements questions EU Medical Device Regulations 1
Q Asset / Tooling Management - Two Questions Manufacturing and Related Processes 3
Q VDA 6.3 questions vs IATF 16949 clauses VDA Standards - Germany's Automotive Standards 0
I Questions to ask when auditing for Organizational Leadership and Planning for the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO13485:2016 name and ownership changes questions ISO 13485:2016 - Medical Device Quality Management Systems 3
C CQA Test Questions Bank General Auditing Discussions 1
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Informational EU – EMA revised guidance – Questions & Answers on Implementation of the Medical Devices and In Vitro Diagnostic Medical Devices Regulations ((EU) 201 Medical Device and FDA Regulations and Standards News 2
M Informational EU – MDCG 2019-6 v2 Questions and answers: Requirements relating to notified bodies Medical Device and FDA Regulations and Standards News 0
Ed Panek Relevant questions on Substantial Change Form CE Marking (Conformité Européene) / CB Scheme 3
K Beginner in ISO 45001 here! Three questions Occupational Health & Safety Management Standards 6
D Framing FDA Questions - Validation US Food and Drug Administration (FDA) 1
M Informational US FDA – Frequently Asked Questions (FAQs) About the Accreditation Scheme for Conformity Assessment (ASCA) Pilot Medical Device and FDA Regulations and Standards News 0
F Barcoding questions - Is there a plain English primer for newbies? ISO 13485:2016 - Medical Device Quality Management Systems 10
D Questions about the contents of a Design History File 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S ISO 14971 Risk Management - Questions for Hazard identification ISO 14971 - Medical Device Risk Management 2
M Informational EU – MDCG 2019-6 Questions and answers: Requirements relating to notified bodies Medical Device and FDA Regulations and Standards News 0
C MDR Importer/Distributor Definition Questions EU Medical Device Regulations 14
A Purchasing - Internal Audit Questions Internal Auditing 8
M Informational USFDA – Efforts to evaluate materials in medical devices to address potential safety questions Medical Device and FDA Regulations and Standards News 0
M Informational USFDA draft guidance – A Risk-Based Approach to Monitoring of Clinical Investigations Questions and Answers Guidance for Industry Medical Device and FDA Regulations and Standards News 0
E Basic Risk based thinking questions Risk Management Principles and Generic Guidelines 5
F Job Travelers questions - unsigned operations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 41
J Training documentation - ISO 13485 audit and the auditor had questions General Auditing Discussions 7
G Auditor watching tech do procedure - Can tech ask questions? ISO 17025 related Discussions 6
A Any recommendation for ASQ's CPGP (Pharmaceutical GMP Professional) Certification exam questions? ASQ - American Society for Quality 2
M Informational EU – Questions And Answers Related To The United Kingdom’s Withdrawal From The European Union With Regard To Industrial Products Medical Device and FDA Regulations and Standards News 0
