Quick Comparison Check of Multiple Thermocouples on one Datalogger
H
HikerLT
I have a question:
Using an Agilent Datalogger, with approximately 40 thermcouples placed directly onto the units we are testing in a thermal chamber from -40C to +70 C . We also have thermocouples plcaed in free air positions ( low, middle, top) of the racks holding the test units, and also at the air intake and air exhaust of the chamber.
The question I have is :
What is a quick method to check that all the thermocouples are reading the same temperature ? My reason for asking is that on the last test run, a couple of the channels apeared to have temperture reading results that were significantly different from the other sensors.
Would it make sense to place all the sensors close together on a metal plate, inside the chamber, and get readings at cold, ambient, and high temperatures ?
Thanks for any suggestions and advice !
Ninja
Looking for Reality
Sorry to "answer" a question with a question(s)...
What temperature range are you measuring, and with what type of thermocouple?
The temperature and type can make all the difference in the world.
Are you measuring any temperatures in excess of ~700C ?
Edit: Silly me...you already stated your temperature range in the OP, sorry.
Good advice down below...I second the recirculating temp bath as a reality check and for setting offsets and span.
Mikishots
I have a question:
Not sure I follow your intent; the thermocouples should NOT be reading the same temperatures. Based on your stated locations of the probe tips, you should be getting differing values returned. Are you using calibrated probes?
We use multiple thermocouples in a large solution heat treating oven - the probes returen different values depending on where they are situated in the chamber. We depend on the spread to tell us that degree of variation within the chamber.
If you could provide more detail on what exactly it is that you're measuring, and why, it would be very helpful.
BradM
It sounds to me like the first thing you need to do is assure your measuring device is working correctly. The best way is to have a high uniform environment (recirculating bath or something) and have all the probes in there at once.
You really need to have that system calibrated. It's been a while since I have used Agilent datalogger, but I recall there being a way to assign an offset, assure the scaling is correct, etc.
Do you have access to a recirculating bath or a calibrator block or something? At least you should verify they are all reading consistently.
You can build a proper ice bath and possibly boil some water to verify accuracy at 0 C and 100 C, but there are issues with them. Just bundle the wires together where the tips are together (but try to keep them from touching).
Z
zamclachia
What we have done is to send the data logger out for calibration / verification and included a single TC to be used during the cal / val stage. We then use this TC as a reference. We place the other TC's alongside the ref. and compare the temperatures. Each TC is individually numbered to keep control.
H
HikerLT
Thanks Everyone for the tips and suggestions
- the Agilent Datalogger IS calibrated
- yes,I understand the distributed placement of the thermocouples means they will not all read the same temperature - it's just that ONE of the thermocouples has readings that are significantly different from others in close proximity to it - which is why I question it's data.
Jerry Eldred
Such a quick bevy (sp?) of responses. A pretty common quick check (as zero offset is one of the more common issues with thermocouple probes/sensors, is to put them all in crushed ice slurry (and for this purpose, it doesn't HAVE to be pure distilled water - I'll explain), as you are just looking for if one of them has an offset.
Put them all together in the crushed ice slurry (read my article on the topic in Oct/Nov/Dec 2011 if you want a good reference on the subject). They should all read approximately zero celsius. The reason it does not HAVE to be distilled is that this is a relative offsete check.
If you want a true zero degrees celsius, use finely crushed distilled ice per one of the procedures referenced in my article.
One of the mitigators is that each metal to metal interface is theoretically another thermocouple junction, and can (and sometimes does) cause an offset. A bad, corroded or loosely connected thermocouple plug can cause offset. So if you get a zero offset on one of the thermocouples, try cleaning and/or re-tightening the plug. Also clean the pins of the plug if they look corroded.
A significant offset is defined by the specs for the type thermocouple you are using. I believe type K for example is +/-2.2 C (don't have docs in front of me). If offset is less than the specs of the thermocouple, but more than your process can tolerate, you may need to pre-characterize the individual sensors at zero for offset, and perhaps check them in an accurate bath or drywell at approximately your critical temperature. End user processes often are tight enough that just being "calibrated" regarding the data logger isn't enough. The data logger may be calibrated, but that does not take into account some other system variables (such as what I wrote above).
Hope that is of some help.
R Controlling Quick Reaction Checklists Document Control Systems, Procedures, Forms and Templates 1
O QRQC (quick response quality control) methodology in automotive industry IATF 16949 - Automotive Quality Systems Standard 3
C Quick - Tell me everything you know about TS 16949! LOL IATF 16949 - Automotive Quality Systems Standard 5
Ron Rompen Quick question on results of Student-t test Statistical Analysis Tools, Techniques and SPC 7
S What is an Efficient and Quick Salmonella Test Food Safety - ISO 22000, HACCP (21 CFR 120) 2
L Quick way to check spline pitch runout for machine operators Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
W TS16949 Quick Learning Material Training - Internal, External, Online and Distance Learning 1
F Suggestions for quick & effective solution for Continuous Improvement Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Plating - A quick, certifiable way to measure Plating Bath Temperature Manufacturing and Related Processes 3
P Cost Saving Excercises in Electronic Manufacturing - Quick and Efficient Lean in Manufacturing and Service Industries 2
Fender1 How to comply with ISO 9001 and provide quick/short lead-time orders? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Quick Guide - Processes vs. ISO 9001 Clauses? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J QRQC (Quick Response Quality Control) Training Material or Information Quality Tools, Improvement and Analysis 3
K When to create a new Control Chart? Quick question Statistical Analysis Tools, Techniques and SPC 4
Q Quick ISO-TS 16949 Electronic Copy Cost Estimate IATF 16949 - Automotive Quality Systems Standard 2
1 Is anybody familar with Quick Response Manufacturing? Lean in Manufacturing and Service Industries 6
A Quick Transition ISO-9001 to TS-16949 IATF 16949 - Automotive Quality Systems Standard 6
bobdoering Quick Overview of SPC Scaling Factors from Wheeler Statistical Analysis Tools, Techniques and SPC 0
V Quick ISO 9001 Presentation for Internal Quality Auditors team needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L How to get an FDA approval before May 2010 - ?Quick and Dirty? FDA Approval 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
J Salary / Rates for CMM Programmers in UK - Quick Question Career and Occupation Discussions 5
S I am asked to fit 2 lines - Basic Minitab Question - Quick Help needed Using Minitab Software 1
B Drunken Thread Inspection - Gauges for quick check for drunken threads General Measurement Device and Calibration Topics 3
B Quick and Simple Management System Review Spreadsheet? Quality Manager and Management Related Issues 7
A Changes to QRI (Quick Reference Instruction)? What I can or cannot change ISO 13485:2016 - Medical Device Quality Management Systems 2
G Video Example of Quick Setup Lean in Manufacturing and Service Industries 8
K Factory Quick Assessment Model - Assessment a small factory (<50 employee) Human Factors and Ergonomics in Engineering 8
G Quick Reference for the 8 Quality Management Principles in ISO 9000 IATF 16949 - Automotive Quality Systems Standard 2
J LPAs (Layered Process Audits) and TS 16949 Clause 8.2.2.2 - Quick Question Process Audits and Layered Process Audits 20
N FORD Quick QFD (Quality Function Deployment) Document information wanted Customer and Company Specific Requirements 5
L Employee Morale Boosters - Low cost, quick, and easy ideas to boost morale Preventive Action and Continuous Improvement 31
D Quick and dirty training for team - Structured problem solving Six Sigma 21
Q Quick Overview of the Standards for Medical Devices - ISO 13485:2003 and ISO 14696? ISO 13485:2016 - Medical Device Quality Management Systems 5
E Digital Height Gauge Gage R&R - Need Advise and Help Quick Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Definition QRQC - Quick Response Quality Control - A problem solving tool Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 42
Wes Bucey Need a quick million? Got an unused website? After Work and Weekend Discussion Topics 5
P A Quick look at a failing business Career and Occupation Discussions 6
A Quick Test - Are You 98% or 2%? You just thought about.... Coffee Break and Water Cooler Discussions 123
A Quick Quiz Coffee Break and Water Cooler Discussions 23
A Quick question about RPNs - Any RPN over 100 should be actioned? FMEA and Control Plans 9
B Request: Quick list of Required ISO9k2k RECORD Records and Data - Quality, Legal and Other Evidence 5
B The Idea Generator - Quick and Easy Kaizen Book, Video, Blog and Web Site Reviews and Recommendations 1
Marc Microsoft sez: Upgrade! Quick! After Work and Weekend Discussion Topics 1
D Hey! Quick question, are any of these companies using 6 Sigma? Six Sigma 4
M MTTR - Quick and dirty way to calculate Mean Time To Repair - Solenoid valves Statistical Analysis Tools, Techniques and SPC 6
K Comparison: AS9110C vs. C.A.S.E. 1-A AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
K Comparison wanted: ISO 15378:2018 vs. PS9000:2016 Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
O ISO 13485 vs. GMP - Comparison matrix wanted EU Medical Device Regulations 4
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
