Quick Gage R&R Question
Got a quick question about Gage R&Rs.
If I have part A and I use a 0 - 6" caliper to check a feature that is +/-.020.
I have part B and I use the same caliper to check a feature that is +/-.010.
I have part C and I use the same caliper to check a feature that is +/-.005.
Should I do a gage r&r on all three parts, or can I do one on part C, being the tightest tolerance, and use that to justify using a caliper on parts A and B?
Welcome to the Cove. What QMS standard? In general, tolerance has less to do with it than ensuring that the measurement system is appropriate to a given feature on a specific part. Tell is more about what you're measuring.
outdoorsNW
What Jim is alluding to is some measurements are easier than others. The distance between two parallel hard surfaces is much easier than the distance between two angled surfaces at a particular point for instance. You first need to establish that part C is harder or the same in terms of measurement difficulty, This includes factors such as size of feature, angles, soft vs hard, curves, measurement must be at one point vs anywhere on a larger surface, and probably some more factors that I am not thinking of right now.
I understand what you're saying. So if I'm going to group things together then I should consider attributes like material also.
If the caliper isn't the right gage to measure certain features, won't the Gage R&R tell me that? Material too. If I'm measuring the O.D. of a silicone connector the Gage R&R should tell me if a caliper is the right gage to use, correct?
You should consider anything that might affect the results.
MSA takes into consideration the parts, the operators and the device. You might not have the right system for any of those reasons, or any combination of them.
See the previous response.
Matt's Quality Handle
Also, please consider what the measurements are used for. Minitab (or your software of choice) will give you 2 "answers"; the % of Study Variance (and number of distinct categories) and the % of Tolerance. These answer the following questions respectively:
1. Is my measurement system good enough to provide feedback to my process? (% Study Variance)
2. Is my measurement system capable of reliably distinguishing in spec vs. out of spec parts? (% of Tolerance)
If part A is more tightly controlled than part C, regardless of the spec, then a GRR would also be helpful in answering question number 1.
EDIT: I bet Miner's going to swoop in on this thread ;-)
So taking material in mind if part A is ABS and the measurement is 1.37 ±0.020 and part B is Makrolon and the measurement is 1.17 ±0.010. I could justify doing a Gage R&R on just one part - the tighter tolerance.
We're back to your original question. Part geometry must also be taken into account.
Ron Rompen
Mr. Bill, just want to clarify one of the points made here. A GRR study done on a given gauge type (such as a caliper), using the minimum tolerance, can be extended to cover a variety of similar parts AS LONG AS the parameters of measurement are the same. For example, an R&R study done measuring the overall length of a block would NOT be useful when evaluating the ability of the same gauge to measure the inside diameter of a small hole.
E Digital Height Gauge Gage R&R - Need Advise and Help Quick Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
sonflowerinwales Quick question M3 screw plug gauge AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
A Sterile Packaging Quick Query EU Medical Device Regulations 5
Quality Specialist Quick question on the sequence of ISO 17025 external audits ISO 17025 related Discussions 14
J Quick question on responsible person's experience requirements UK Medical Device Regulations 3
R Controlling Quick Reaction Checklists Document Control Systems, Procedures, Forms and Templates 1
O QRQC (quick response quality control) methodology in automotive industry IATF 16949 - Automotive Quality Systems Standard 3
C Quick - Tell me everything you know about TS 16949! LOL IATF 16949 - Automotive Quality Systems Standard 5
Ron Rompen Quick question on results of Student-t test Statistical Analysis Tools, Techniques and SPC 7
S What is an Efficient and Quick Salmonella Test Food Safety - ISO 22000, HACCP (21 CFR 120) 2
L Quick way to check spline pitch runout for machine operators Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
W TS16949 Quick Learning Material Training - Internal, External, Online and Distance Learning 1
F Suggestions for quick & effective solution for Continuous Improvement Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Plating - A quick, certifiable way to measure Plating Bath Temperature Manufacturing and Related Processes 3
P Cost Saving Excercises in Electronic Manufacturing - Quick and Efficient Lean in Manufacturing and Service Industries 2
H Quick Comparison Check of Multiple Thermocouples on one Datalogger General Measurement Device and Calibration Topics 6
Fender1 How to comply with ISO 9001 and provide quick/short lead-time orders? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Quick Guide - Processes vs. ISO 9001 Clauses? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J QRQC (Quick Response Quality Control) Training Material or Information Quality Tools, Improvement and Analysis 3
K When to create a new Control Chart? Quick question Statistical Analysis Tools, Techniques and SPC 4
Q Quick ISO-TS 16949 Electronic Copy Cost Estimate IATF 16949 - Automotive Quality Systems Standard 2
1 Is anybody familar with Quick Response Manufacturing? Lean in Manufacturing and Service Industries 6
A Quick Transition ISO-9001 to TS-16949 IATF 16949 - Automotive Quality Systems Standard 6
bobdoering Quick Overview of SPC Scaling Factors from Wheeler Statistical Analysis Tools, Techniques and SPC 0
V Quick ISO 9001 Presentation for Internal Quality Auditors team needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L How to get an FDA approval before May 2010 - ?Quick and Dirty? FDA Approval 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
J Salary / Rates for CMM Programmers in UK - Quick Question Career and Occupation Discussions 5
S I am asked to fit 2 lines - Basic Minitab Question - Quick Help needed Using Minitab Software 1
B Drunken Thread Inspection - Gauges for quick check for drunken threads General Measurement Device and Calibration Topics 3
B Quick and Simple Management System Review Spreadsheet? Quality Manager and Management Related Issues 7
A Changes to QRI (Quick Reference Instruction)? What I can or cannot change ISO 13485:2016 - Medical Device Quality Management Systems 2
G Video Example of Quick Setup Lean in Manufacturing and Service Industries 8
K Factory Quick Assessment Model - Assessment a small factory (<50 employee) Human Factors and Ergonomics in Engineering 8
G Quick Reference for the 8 Quality Management Principles in ISO 9000 IATF 16949 - Automotive Quality Systems Standard 2
J LPAs (Layered Process Audits) and TS 16949 Clause 8.2.2.2 - Quick Question Process Audits and Layered Process Audits 20
N FORD Quick QFD (Quality Function Deployment) Document information wanted Customer and Company Specific Requirements 5
L Employee Morale Boosters - Low cost, quick, and easy ideas to boost morale Preventive Action and Continuous Improvement 31
D Quick and dirty training for team - Structured problem solving Six Sigma 21
Q Quick Overview of the Standards for Medical Devices - ISO 13485:2003 and ISO 14696? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Definition QRQC - Quick Response Quality Control - A problem solving tool Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 42
Wes Bucey Need a quick million? Got an unused website? After Work and Weekend Discussion Topics 5
P A Quick look at a failing business Career and Occupation Discussions 6
Al Rosen Quick Test - Are You 98% or 2%? You just thought about.... Coffee Break and Water Cooler Discussions 123
Al Rosen Quick Quiz Coffee Break and Water Cooler Discussions 23
A Quick question about RPNs - Any RPN over 100 should be actioned? FMEA and Control Plans 9
B Request: Quick list of Required ISO9k2k RECORD Records and Data - Quality, Legal and Other Evidence 5
B The Idea Generator - Quick and Easy Kaizen Book, Video, Blog and Web Site Reviews and Recommendations 1
Marc Microsoft sez: Upgrade! Quick! After Work and Weekend Discussion Topics 1
D Hey! Quick question, are any of these companies using 6 Sigma? Six Sigma 4
M MTTR - Quick and dirty way to calculate Mean Time To Repair - Solenoid valves Statistical Analysis Tools, Techniques and SPC 6
