R A value tolerances for stainless steel finishes
P
Phil Fields
#11
How about....
BS 1449, Part 4, and the Committee of Stainless Steel Producers, American Iron & Steel Institute
or
ANSI B 46.1
We use 2B, 3 and BA finishes here, but we inspect by visual inspection.
I assume it depends on your application, whether or not there is a spec covering the surface finish. Most of these finishes call outs are for commercial quality stainless, so there may be minimal governing specs.
Carolx,
You mention that you Visual Inspect for this finsih...do you have a reference standard that you use. This issue came up this morning, we do not have a reference.
Thanks,
Phil
CarolX
#12
Carolx,
Thanks,
Phil
Hi Phil,
Sorry - I do not - it is more just "tribal knowledge". You steel service center may be able to help you.
Proud Liberal Improving low p-value Statistical Analysis Tools, Techniques and SPC 13
BeaBea Registrars with VAR (Value Added Reseller) experience Registrars and Notified Bodies 8
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
F Missing value of Uncertainty B Measurement Uncertainty (MU) 10
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
S In BAC5300 we have machining mismatch allowed is 3tau, what is the value of tau? Document Control Systems, Procedures, Forms and Templates 1
S Change value of target during a batch Capability, Accuracy and Stability - Processes, Machines, etc. 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Torque Value for Different types of Fasteners (Socket Head, Button Head, CSK) Manufacturing and Related Processes 2
M IATF 16949 - 8.5.6.1.1 Providing a list of process controls: Does this requirement add value to QMS? IATF 16949 - Automotive Quality Systems Standard 4
qualprod Cycle times, value stream mapping, inventory, average values? Lean in Manufacturing and Service Industries 1
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
S Adding Value prior to signing EASA Form 1 EASA and JAA Aviation Standards and Requirements 5
M Creating a Plant Level Value Stream Map Process Maps, Process Mapping and Turtle Diagrams 1
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
T Value Chain Map for Food Services Industry Service Industry Specific Topics 1
O P-Value less than 0.05. but everything else in control Statistical Analysis Tools, Techniques and SPC 19
qualprod P x I = Value interpretation for residual risk? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
G What degrees of freedom means in uncertainty budget and how do I set the value Measurement Uncertainty (MU) 2
Q Really do they add value (Vision, Mission, Values)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D What is the exact Temperature Coefficient Value to be set on a Conductivity Meter? General Measurement Device and Calibration Topics 2
M Value Stream Mapping Calculations Process Maps, Process Mapping and Turtle Diagrams 5
L How to interpret the average R bar Value shown in the R Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Non Value Added Corrective Actions IATF 16949 - Automotive Quality Systems Standard 15
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
J Agenda of Value Stream Mapping workshop required Quality Tools, Improvement and Analysis 1
M What is the value of documenting in-process rework for easily-detectable issues? Quality Manager and Management Related Issues 4
R VSM - Value Stream Mapping (catheter manufacturing unit) Customer Complaints 10
W Quality for value adding or certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
dubrizo Internal Audit Value - What is the point of conducting internal audits to a checklist Internal Auditing 40
L 5 minutes only for this Survey on the Value of PDCA and Your EMS Miscellaneous Environmental Standards and EMS Related Discussions 1
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J F and P-value in L9 Taguchi Design Using Minitab Software 22
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
V Analysis of 'Value Added' System & Process Steps - Inspection Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
P Which ISO 13485 clause(es) are applicable for Value Proposition Creation ISO 13485:2016 - Medical Device Quality Management Systems 1
R The Value and Effectiveness of In Process Inspection Quality Manager and Management Related Issues 17
D Value-Added Analysis - Staff (Employee) Satisfaction Quality Tools, Improvement and Analysis 11
T ISO Auditor Training - What online training is actually value added? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Specific Capability case - Target Value is same as the Lower Limit Capability, Accuracy and Stability - Processes, Machines, etc. 9
S GR&R for an "R" value instrument installed on my 10K Horizontal Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Value Stream Mapping for a Product Family Lean in Manufacturing and Service Industries 5
WCHorn Are Inspection Operations Value Added? Lean in Manufacturing and Service Industries 50
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Labeling Medical/Health Value Claims with No Sources to Back Up EU Medical Device Regulations 1
