R&R Studies - how many? per product?
mjoakin
I have a question regarding how to schedule R&R. For example, I have calipers, and 10 final inspectors that use this device, different programs/products thought. We measure stitch length. If one inspector is certified to use this caliper to measure the stitch length in the VW and Nissan products, I do not have to do a separate R&R because now he is measuring stitch length in a new product from Honda, right? if the person is certified, it does not matter if he/she measure stitches of 4 mm or 5.5 mm in different programs/product, their certification by the original R&R make them competent, right?
MSA, (in this case GR&R) is not a "certification" process as such. It's used to determine whether a given measurement system is suitable for measurement of a particular feature (or suitably similar features). They "system" includes operators, devices and parts. Operators of typical skills should be used. If, via the study, the system is found to be acceptable, there should be no reason to repeat it unless something substantive has changed. Whether your parts for different customers are suitably similar is a decision for you to make.
mjoakin
Thank you Jim, is the same I thought, but this guy made doubt.
I appreciate your help!
Ron Rompen
Jim is (as usual) absolutely correct. I would, however, add a comment in regarding this. When using an MSA study from a 'similar' part you need to ensure that the tolerance used for the MSA study is the SMALLER of the two. This ensures that your measurement system is able to adequately discriminate between a good and bad part.
Another thing to consider is the overall size of the feature. If it is 30mm ± 1.0mm on the first part, and only 5mm ± 1.0mm on the second part, you may want to consider repeating the study.
And of course, your customer specific requirements will dictate any specific nuances that they may have.
B How many MSA studies are required and at what interval(s)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
R How many batches have to be kept under Stability Studies Qualification and Validation (including 21 CFR Part 11) 6
B How many Samples are required in Attribute Data MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Linearity, BIAS & Stability - How many studies do I need to do for a device? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
CalRich GR&R (Gage R&R) - How many studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
S Gage R&R Studies - 1200 operators, 2000 measurement tapes and many characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Machine Capability Studies: How many parts needed? Statistical Analysis Tools, Techniques and SPC 11
D Capability Studies - 5 different dimensions - How many parts? Statistical Analysis Tools, Techniques and SPC 6
P Worst case HLD sample for efficacy studies Other US Medical Device Regulations 0
A Do clinical performance studies for IVDs need to be conducted in a member state? EU Medical Device Regulations 2
A Do clinical performance studies for IVDs need to be conducted in a member state? CE Marking (Conformité Européene) / CB Scheme 0
K Initial capability studies on similar parts APQP and PPAP 7
R MSA Studies for chemical analytical instruments in QC Lab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Nonclinical Studies Other US Medical Device Regulations 0
I RWE Studies and Design Controls US Food and Drug Administration (FDA) 1
S MSA clause 7.1.5.1.1 - Statistical studies on counting weight scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Packaging studies - ISTA vs ASTM CE Marking (Conformité Européene) / CB Scheme 0
R Compatibility studies for Combination Products - Europe Medical Device and FDA Regulations and Standards News 2
R Compatibility studies - combination product CE Marking (Conformité Européene) / CB Scheme 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
V Part selection for R&R studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
L Proof of Concept Studies - Do we need to comply with SAE reporting? Medical Device and FDA Regulations and Standards News 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Revalidation machine line and Stability Studies impact. Medical Device and FDA Regulations and Standards News 3
C Medical Device Shelf life studies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Post-market clinical followup studies (PMCF) EU Medical Device Regulations 16
A We're currently looking for any studies performed on various PPE materials Qualification and Validation (including 21 CFR Part 11) 1
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
J Pre-clinical Studies for RUO Product Other Medical Device Regulations World-Wide 1
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Informational US FDA final guidance – Utilizing Animal Studies to Evaluate Organ Preservation Devices Medical Device and FDA Regulations and Standards News 0
C Medical Device Stability Studies - Non-validated pilot production Other Medical Device Related Standards 1
H Frequency of shelf life/sterilization/bench studies conducted on a medical device Other Medical Device Related Standards 1
P Performance evaluation (IVDD Annex VIII) & Design and Development Validation Studies EU Medical Device Regulations 1
M Informational Understanding Costs And Risks For HFE Usability Studies — Part 1: Testing In-House Medical Device and FDA Regulations and Standards News 0
M FDA News FDA Safety communication – Interim Results of Duodenoscope Reprocessing Studies Conducted in Real-World Settings Medical Device and FDA Regulations and Standards News 0
S Clinical Studies - Premarket Submission Requirements Canada Medical Device Regulations 1
Sam Lazzara Time Zero testing in med device aging studies Qualification and Validation (including 21 CFR Part 11) 3
H Do all animal studies have to be GLP compliant? EU Medical Device Regulations 1
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
W Interesting Discussion PMCF (Post-Market Clinical Followup) vs PMCF studies EU Medical Device Regulations 39
A Accelerated Stability Studies - Class III Medical Gloves Other Medical Device and Orthopedic Related Topics 1
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
N Substantial or non-substantial modification in clinical studies EU Medical Device Regulations 1
A Risks related to Method Validation and Stability Studies Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Studies conducted on the amount of autoclave sterilization of a PEEK implant Other Medical Device and Orthopedic Related Topics 1
