Radius Gauge R&R Study
Golfman25
Since it doesn't give you a variable reading, I think you have to treat it as a go / no go gauge. There's a methodology in the AIAG msa book.
Many thanks for that.
As an attribute study and with rad gauges with a descrimination of 0.25 i wondered how others had approached it ?
Again thanks for the reply
bobdoering
Stop X-bar/R Madness!!
What are the gages being used for? Control (process adjustment) or product verification? How are they being used - use several to find the correct one, or compare to the correct one? What is the tolerance of the radius on the part?
In general they are being used for open tolerances (As you would expect!) But even at that to set up a study is proving a little difficult. The rad gauges are .025mm increments. Any suggestions would be welcome!
Many thanks
Many thanks
Please describe what the gages are used for, and what an "open" tolerance is.
AMIT BALLAL
Many thanks
We use radius gage for attribute measurement such as Ok or Not Ok. Hence it would require an attribute GRR i.e. Kappa study.
You'll need 50 parts (recommended) for measurement. Determine whether the parts are defective or not using more accurate measurement system (variable measurement system is recommended)/ system that you trust/ controlled. Based on these measurements, define reference value.
It would be better to have 20 to 30% defective parts, if available. If no defective parts available, at least take parts that are close to specification limits.
Then take 2 appraisers (at least) and these appraisers should measure each part 2 times (at least) using radius Gage.
Enter the readings in MSA format. Here are the results from google search. Please download and use the format you find useful.
attribute MSA.xls - Google Search
At end you'll get Kappa value. It should be minimum 75% (0.75).
You can also refer following link shared by Stiljoor in similar thread:
Attribute Gage study site:Elsmar.com - Google Search
Hi Amit,
Many thanks for the reply I will give that a try!
Best regards
Richard
It would be good if you could answer the questions asked, such as what the radius gages are used for and what you mean by "open tolerances." It could well be that Amit's advice is overkill in your situation.
Good evening Jim,
Firstly apologies for not directly replying yo your post!
The radius gauges are being used for measuring machined radii in various machined components for the aerospace industry!
We mean by 'open' tolerance that it is the general drawing tolerance for machined features e.g +/- 0.25mm
Best regards
Richard
D Measuring a round edge - Looking for a 20 degree radius gauge General Measurement Device and Calibration Topics 8
Roberticus Negative corner radius (per ISO 1101)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Radius Measuring Tools General Measurement Device and Calibration Topics 4
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T Linear Measurement - Radius Center or Intersection Point? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Drawing Callout - Arrow pointing to an inner edge where there is a radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Measurement of a Radius on Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B AAMI Standard - 6 Foot Radius Patient Vicinity Various Other Specifications, Standards, and related Requirements 2
P Corner Radius & Fillet Radius Differences Manufacturing and Related Processes 5
V How to measure radius without radius gages APQP and PPAP 4
D Large, untoleranced radius of 20? - Inspection and Tolerancing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
F Angularity of 2 Surfaces to a Datum which is a Radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Radius Measurement question - Print that calls out a 5.5-5.7mm Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Profile of a Surface Tolerance - Part with a 195 mm radius on it Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
J Measuring the Small Radius on the Edge of a Strip of Metal Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S How to apply a Tolerance to a Bend Radius Manufacturing and Related Processes 15
T Accurate Method of Internal Radius Check Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
G Where to find Ggg-g-17 - Spec is related to GAGE, FILLET AND RADIUS Customer and Company Specific Requirements 7
J Clarification of ISO 2768-1 - Inside bend radius tolerance - Metal stamped part Various Other Specifications, Standards, and related Requirements 2
T Measurement of Large Radius (30.0") on Product - No CMM available Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
K The Best Way to Calibrate Radius Gages General Measurement Device and Calibration Topics 34
H Definition of feature "R" as regards a radius on a print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
B Capability Study for Radii of laser cut pockets - 0.030" radius Capability, Accuracy and Stability - Processes, Machines, etc. 15
D Calibration of Optical Comparator Overlays - Radius, Thread and Angle General Measurement Device and Calibration Topics 11
J Finding a Radius - How to measure diameters that are not a full diameter Registered Visitor Articles Archive 19
D What does RTYP on a Print Stand For? Radius Typical? Misc. Quality Assurance and Business Systems Related Topics 7
Proud Liberal Definition Radius and Full Radius - Need a definition for each and difference(s) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
K Calibration procedure for radius gages General Measurement Device and Calibration Topics 12
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
F Gauge R&R & Calibration Intervals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
