Radius Measuring Tools
L
langlda
Currently, I am working on a problem that involves my machine shop not forming metal corners within tolerance. I've been looking for a radius gauge that will measure between 2" and 8". I have found some that start at 2.5" but, my measurements start around 2.6" +/- .050 and go to 7" +/- 0.050. Does anyone have a recommendation of either a gauge or a company that makes either a digital or manual device for this application? Any help on this would be appreciated.
Eredhel
Quality Manager
When I worked in sheet metal fabricating we made our own check fixtures for things like that. It looks like it's too big to throw on a comparator or use repro rubber with a comparator. I'm guessing you also don't have a CMM. If you make your own check fixtures you could try and develop a relationship with someone's CMM room and have them check it too, although we never felt the need to.
anders.kemper
In a lasercutting machine it’s easy to do it by you self.
Skickat från min iPhone med Tapatalk
Q
QAMTY
you can use a cad software, draw what you need,print it at real scale,then using the printout,you can use it directly for the measurements, or based on it,do a template in a sheet metal or something like that.
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Measuring the Small Radius on the Edge of a Strip of Metal Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
D Measuring a round edge - Looking for a 20 degree radius gauge General Measurement Device and Calibration Topics 8
K Radius with specification only Max limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
Roberticus Negative corner radius (per ISO 1101)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Radius Gauge R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
T Linear Measurement - Radius Center or Intersection Point? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
J Drawing Callout - Arrow pointing to an inner edge where there is a radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Measurement of a Radius on Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B AAMI Standard - 6 Foot Radius Patient Vicinity Various Other Specifications, Standards, and related Requirements 2
P Corner Radius & Fillet Radius Differences Manufacturing and Related Processes 5
V How to measure radius without radius gages APQP and PPAP 4
D Large, untoleranced radius of 20? - Inspection and Tolerancing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
F Angularity of 2 Surfaces to a Datum which is a Radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Radius Measurement question - Print that calls out a 5.5-5.7mm Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Profile of a Surface Tolerance - Part with a 195 mm radius on it Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
S How to apply a Tolerance to a Bend Radius Manufacturing and Related Processes 15
T Accurate Method of Internal Radius Check Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
G Where to find Ggg-g-17 - Spec is related to GAGE, FILLET AND RADIUS Customer and Company Specific Requirements 7
J Clarification of ISO 2768-1 - Inside bend radius tolerance - Metal stamped part Various Other Specifications, Standards, and related Requirements 2
T Measurement of Large Radius (30.0") on Product - No CMM available Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
K The Best Way to Calibrate Radius Gages General Measurement Device and Calibration Topics 34
H Definition of feature "R" as regards a radius on a print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
B Capability Study for Radii of laser cut pockets - 0.030" radius Capability, Accuracy and Stability - Processes, Machines, etc. 15
D Calibration of Optical Comparator Overlays - Radius, Thread and Angle General Measurement Device and Calibration Topics 11
J Finding a Radius - How to measure diameters that are not a full diameter Registered Visitor Articles Archive 19
D What does RTYP on a Print Stand For? Radius Typical? Misc. Quality Assurance and Business Systems Related Topics 7
Proud Liberal Definition Radius and Full Radius - Need a definition for each and difference(s) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
K Calibration procedure for radius gages General Measurement Device and Calibration Topics 12
eule del ayre Clause 7.1.5 Monitoring and measuring resources IATF 16949 - Automotive Quality Systems Standard 14
armani Monitoring and measuring equipment for occupational health and safety purposes Occupational Health & Safety Management Standards 10
Q Class I Medical Device with measuring function (UK MDR 2002 / MDD) UK Medical Device Regulations 3
G Calc uncertainty of angle; by measuring x,y points Measurement Uncertainty (MU) 0
R Gage Measuring 15 Parts at a Time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A ISO 13485 Calibration Requirements- Assess and Record validity Previous measuring results ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 17025:2017 Clause 6.4 - Measuring Equipment Validity ISO 17025 related Discussions 2
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Dan Pare Density Column setup for Measuring General Purpose ABS General Measurement Device and Calibration Topics 0
S Classification of product (measuring or not?) CE Marking (Conformité Européene) / CB Scheme 5
D Measuring Radii Measurement Uncertainty (MU) 6
J Register of the monitoring and measuring equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
