Raising A CAPA on Current CAPA system
Hi guys
Ive recently moved company and already implemented a new NCR process as it wasn't fit for purpose.
I have raised a CAPA on the current CAPA process as again this is not fit for purpose.
My CAPA scope/Justification is as follows;
The reliability of the current CAPA process and connecting forms has been deemed unsuitable and has been identified by QE leadership as an improvement for TBS. Connecting Forms relating to the current process are being missed out during investigation and we as a company recognise this needs addressing”
Do you believe it to be okay to do this? its the best way to capture the issue and will be an improvement CAPA.
If you believe that the CAPA system is inadequate in it’s current form it is absolutely appropriate to ‘raise a CAPA’ against it. The important thing is that you are assessing your QMS and continually improving it.
One thing to consider is to articulate the effect on the business of the current system - what isn’t it doing it well? is it too slow, not effective, not focused on the right type of non-conformances, etc.
Pancho
wikineer
When you say you “raised a CAPA”, what exactly are you doing, in your system’s terminology? Is it a request for corrective action? Or are you reporting a nonconformity?
As with any other process, if you spot a weakness or “nonconformity” then you usually raise a Nonconformity Report. Is that what you meant when you say that you “raised a CAPA”? The NCR should be as thorough as possible because it will then help you investigate and find the root cause of the NC. For example, if forms are not being completed, then isn’t that the NC to be reported? Then, if corrective action is warranted, from specific NCs you can raise corrective action requests (CARs; is this what you say you did when you “raise a CAPA”?).
When you say:
In CAPA as in any other process, the corrective action process is like this: (1) Identify what is nonconforming, (2) investigate and find the root cause, (3) eliminate the root cause by modifying the process.
In your description I’m not very clear on what is nonconforming. What connecting forms are being missed out? How is that making the process reliability unsuitable? Being specific will help find the root causes and then successfully modify the process to eliminate them.
Q Raising a Major Nonconformance during an Internal Audit Internal Auditing 23
C Raising NCRs for Supplier Errors Supplier Quality Assurance and other Supplier Issues 10
L Criteria for raising a Nonconforming Material Report Nonconformance and Corrective Action 4
J Concessions - Raising a concession untill the BOM (Bill of Materials) is updated Quality Tools, Improvement and Analysis 1
N Raising a Nonconformance for Lack of Competency of Contractor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Sidney Vianna Raising the bar for TS 16949 auditors General Auditing Discussions 0
M Tasked with Raising Quality Awareness - Metrics to apply - Identification wrist bands Quality Tools, Improvement and Analysis 4
I Nonconformities and CAPA Nonconformance and Corrective Action 9
F NCMRs and its relation to CAPA Nonconformance and Corrective Action 7
C Projects in the CAPA system Preventive Action and Continuous Improvement 6
S EU MDR CAPA - GAP Assessment on CAPA SOPs EU Medical Device Regulations 1
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
B Do you use paper or web-based templates for CAPA processes? ISO 13485:2016 - Medical Device Quality Management Systems 3
G Any good examples of CAPA forms that include a risk based approach? ISO 13485:2016 - Medical Device Quality Management Systems 8
B CAPA - Extensions vs Overdue Nonconformance and Corrective Action 11
G New CAPA Work Flow with Revised 8D Approach Process Maps, Process Mapping and Turtle Diagrams 35
Y Blank Fields on CAPA Form Document Control Systems, Procedures, Forms and Templates 21
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
V CAPA effectiveness check Nonconformance and Corrective Action 3
Ed Panek CAPA against Notified Body? EU Medical Device Regulations 5
CPhelan Nonconformance opened as incorrect expiration date placed on received product. Escalate to CAPA? Nonconformance and Corrective Action 4
N How to monitor the effectiveness of the CAPA system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 16
Z Security for Approvals - Cloud based Complaint, NC, and CAPA systems Qualification and Validation (including 21 CFR Part 11) 8
S FDA requirements and CAPA's Qualification and Validation (including 21 CFR Part 11) 2
J MDR reporting and CAPA thoughts? Classifying Complaints on Risk 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
P Documentation for correction, corrective action, mini CAPA Nonconformance and Corrective Action 9
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
A Can change control can be closed if the CAPA is still open? Nonconformance and Corrective Action 3
Don Fardie CAPA vs. Risk Assessment - Changing a product material for better performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A NCR, NCMR, CAPA, Deviations - Medical Device Distributor Nonconformance and Corrective Action 2
S CAPA Investigation Methods Nonconformance and Corrective Action 3
qualprod Should I initiate CAPA for a nonconformance not recorded? Nonconformance and Corrective Action 25
R CAPA Verification - ISO 13485:2016 Requirements and Objective Evidence ISO 13485:2016 - Medical Device Quality Management Systems 2
J CAPA and other Log Requirements ISO 13485:2016 - Medical Device Quality Management Systems 8
D Any Elsmar members using Traqpath to manage CAPA? Nonconformance and Corrective Action 2
D CAPA - Suggested Action vs Action Plan Nonconformance and Corrective Action 5
A Audit Finding - CAPA, Improvement Initiatives not filed in CAR System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Moncia Complaint / Non-Conforming Product / CAPA Procedures - Please share your experience ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Issue with CAPA system - Should Over Due CAs warrant a CAPA? Nonconformance and Corrective Action 17
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
M CAPA due to Consumer not following Maintenance Instructions... Nonconformance and Corrective Action 9
A Escalation to CAPA - Assessing if an NC warrants a CAPA Nonconformance and Corrective Action 4
P Trending CAPA's in our Management Review Meetings ISO 13485:2016 - Medical Device Quality Management Systems 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
Q Customer Complaint Vs. Nonconformance - CAPA SYSTEM Customer Complaints 2
P How CAPA's are trended in Management Review Nonconformance and Corrective Action 1
P Sample FDA compliant CAPA procedure wanted Document Control Systems, Procedures, Forms and Templates 2
