Rational Subgroup and Estimation of Variability Due to Common Causes
Bapun
Hi friends
I have joined the forum just today.
Wish you all a very bright & properous New year (2008)
I have been exposed to the field of SPC some time back.
I understand that the concept of Rational Subgroup and its use in estimation of variability due to chance causes is central in SPC
However the question which is bugging me is -
Within Rational Subgroup (RS) variation is assumed to capture the Common cause variation.
How to choose the RS in a particular situation which ensures that the assumption (that the RS realy captures the common Cause variation, nothing more and nothing less) is correct ?
I am unable to find a satisfactory answer to this question.
Please enlighten me on this point.
Thanks in Advance
Bapun
India
Stijloor
Hi friends
Thanks in Advance
Bapun
India
Hello Bapun.
Welcome to The Cove! :bigwave: :bigwave:
Happy New Year to you.
A search on The Cove Forums revealed this.
Are you familiar with this great resource? This may help too.
Stijloor.
Steve Prevette
Deming Disciple
Establishing rational subgrouping requires knowledge of the process being monitored. To illustrate the issue, I think it best to give an example (we had something like this on the Cove as an actual data example a few years back).
Let us say that I am monitoring a production output, and I choose to subgroup in sequential lots of 5 units produced. Let us assume that there is something in the process that makes every 5th unit significantly smaller than the other four units. Since my subgroup is 5 units, every group will include 1 small item, and 4 regular sized items. My average size, and range of the size within each sample will be similar from group to group. I will then assume that any variation observed is "common cause" since the variability from group to group is stable and predictable.
But then, let us change the grouping size. Let's plot an individuals chart. When I do that, I will visually see that every fifth unit is different. Perhaps every fifth unit will be outside the control limits if the difference is severe enough. In this case, I will end up declaring the process to have "special cause" variation - every fifth unit is "different".
So, depending upon your grouping plan, one chart gave that there was common cause variation, the other said special cause. Interestingly, both interpretations could lead to improvement - if the common cause variation was "too high" and the process not capable in the first scenario, you would then look further into the data and discover the every fifth item issue. The special cause in the second scenario should immediately lead you to an answer.
I hope that illustration is of assistance.
Bapun
Dear Frainds,
Extremely sorry for being late, I was busy because of serious illness of one of my family members and could not visit the forum.
Thanks to Stijloor. I have visited the links suggested by you. They are excellent. I need some time to critically look into them and then only I can comment on them.
Thanks to Brad for the links you have suggested I have seen them too. They will surely be helpful.
I am afraid; I was not able to put my question clearly. I would try to put it in a better way.
Rational Subgroup as a concept is excellent. They, IF selected correctly will surely give a good estimate of the common cause variation.
However It’s really a VERY BIG IF. The thumb rules like “five consecutive” pieces are supposed to form a Rational Subgroup (RS); however my question was how one can be sure that the selection was correct. Often one comes up with situations where one finds that the Control Chart shows unstableness.
This could be because the selected “Rational Subgroups” captured only a part of the Common cause variation (e.g. variation due to the measurment process only) and left out others. As a consequence Such a selection of Rational Subgroup would underestimate the common cause variation of the process.
It is important that the selected Rational Subgroup captures the entire common causes variation and excludes any variation due to special causes.
How one can be sure that this will be the case for a particular selection of a Rational Subgroup?
I thank Steve also for his posting. It was clear that he has understood my question. He gave a nice example to support his views.
My fresh question are
- whether one has to depend on his experience and develop one’s own method of selection of Rational Subgroups or is there or could there be a somewhat structured method for doing so?
- Can statistical methods provide some guidance in this regard ?
Regards,
Bapun
India
Dear Frainds,
Regards,
Bapun
India
The only 'structured' way is to undertand your process, how variation could happen in time groupings (within piece, piece to piece, cavity to cavity, tiem to time, operator to operator, line to line or equipment to equipment, etc.), get some data across these groupings, plot it in time sequence and look at it. Rational subgroups are not assigned ahead of time - they are assigned only after knowledge of the true process variation is gained. Then the rational subgroup is determined to match the actual variation. That is why it is called rational.
Steve Prevette
Deming Disciple
Regards,
Bapun
India
This is a case where there is not a silver bullet answer. Rational subgrouping requires knowledge of the process, and experience. Probably the most important "structured method" is to do the SPC itself correctly and then you will be able to detect problems with the subgrouping.
Personally, I prefer to do individuals charting. The weakness in this is less ability to detect shifts in the variation (standard deviation) of the data. The other potential weakness is that if you have A LOT of data (say from an automated measurement system) you may need to go to large subgroups to keep the chart size reasonable. In that case, I prefer xbar - sigma charting.
yes - simply plotting your data in any time series chart will do the the trick. I personally prefer to plot my data with a multi vari chart. Of course if there is no within piece or within (fixture/mold) to be measured the multi-vari defaults to looking like an individuals chart...
but again teh message is that there is no "a priori" method.
B How to apply a Rational Subgroup Plan to Various Processes Statistical Analysis Tools, Techniques and SPC 1
R Help on Rational Subgrouping: How to Subgroup Data given... Statistical Analysis Tools, Techniques and SPC 0
Ronen E A Rational Basis for Design Verification Design and Development of Products and Processes 5
S Screening and Screening Rational Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Rational subgrouping in case of control chart Statistical Analysis Tools, Techniques and SPC 1
A IEC 60601-1-2 - EMC Retesting Rational - Minor Component Changes IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Marc ISO 17024 - New accreditation standard - What is it? Is it rational? Do we need this? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
Marc Rational calendar with 364 days - Extra week celebrating Isaac Newton Coffee Break and Water Cooler Discussions 0
Q Using Rational Unified Process for Medical Device Software ISO 13485:2016 - Medical Device Quality Management Systems 3
A Two batches - Is the subgroup 4 or 2? Statistical Analysis Tools, Techniques and SPC 8
I Can subgroup size change daily? (X-bar & R) Capability, Accuracy and Stability - Processes, Machines, etc. 5
H Control limits for varying subgroup sizes Statistical Analysis Tools, Techniques and SPC 1
K Estimation Sigma (Within) when subgroup n=1 (MiniTab) Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Sample Subgroup Size for NP/P chart - nPbar>=5 Statistical Analysis Tools, Techniques and SPC 4
S Understanding Subgroup Size - Multi Cavity (Minitab) Statistical Analysis Tools, Techniques and SPC 4
C Subgroup Size in Minitab for Capability Study Statistical Analysis Tools, Techniques and SPC 4
P Determination of Subgroup Size for P Charts Statistical Analysis Tools, Techniques and SPC 4
G How to calculate Subgroup Size for Machine Capability Study Statistical Analysis Tools, Techniques and SPC 4
B SQCPack SPC Software Subgroup Size to Small Quality Assurance and Compliance Software Tools and Solutions 2
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
K Subgroup Size - Understanding what is meant by Subgroup Size Six Sigma 13
G What may be the best way to determine if single point in subgroup is out of control Statistical Analysis Tools, Techniques and SPC 6
S How is Cpk /Ppk value calculated in Minitab since I have subgroup size of 1 Capability, Accuracy and Stability - Processes, Machines, etc. 1
C Looking for d2* table with parameter m (subgroup size) > 20 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S PPAP - Production Run Quantities, Number of Subgroups and Subgroup Size APQP and PPAP 2
P Xbar-R Chart better than Xbar-S Chart when the subgroup size is small - Why? Capability, Accuracy and Stability - Processes, Machines, etc. 12
I Cp Calculation - Subgroup size greater than 25 Capability, Accuracy and Stability - Processes, Machines, etc. 11
U P Charts - Subgroup Sizes? Process Control Indicator Statistical Analysis Tools, Techniques and SPC 3
Q Design of Experiments Using Subgroup Data - Conducting a 2^3 factorial DoE Quality Tools, Improvement and Analysis 6
P Capability Analysis in Minitab - Subgroup size Misc. Quality Assurance and Business Systems Related Topics 2
Y SPC Daily Monitoring and Subgroup Size Statistical Analysis Tools, Techniques and SPC 19
B Choosing number of subgroups and subgroup size Statistical Analysis Tools, Techniques and SPC 4
C Is it possible to get Pp,Ppk more than the within subgroup (Cp,Cpk's) indices? Statistical Analysis Tools, Techniques and SPC 7
M Subgroup Size for Control Limit Calculations - SPC Statistical Analysis Tools, Techniques and SPC 5
Manix Initial Capability study on N50 parts - Subgroup Size? Statistical Analysis Tools, Techniques and SPC 5
P U-chart regarding defect count - The operator as subgroup? Statistical Analysis Tools, Techniques and SPC 4
D How are the d2 values for subgroup sizes derived? Statistical Analysis Tools, Techniques and SPC 4
F Issues in Uncertainty Estimation Measurement Uncertainty (MU) 5
C Uncertainty Estimation for Spark Optical Emission Device Measurement Uncertainty (MU) 1
N Risk Severity Estimation for Medical Devices as per ISO 14971 ISO 14971 - Medical Device Risk Management 12
M Standard Deviation Estimation Formula - Student Question Statistical Analysis Tools, Techniques and SPC 4
T Sample Size Estimation using Mintab 16 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Tolerance Estimation of a Load Cell I want to Calibrate General Measurement Device and Calibration Topics 9
R Procedure for Measurement Uncertainty Estimation for Electrical Measurements Measurement Uncertainty (MU) 2
S Uncertainty Estimation in Temperature Measurement by K type Thermocouples Measurement Uncertainty (MU) 7
S Software Risk Estimation: Probability of Medical Device Software Anomaly Occuring ISO 14971 - Medical Device Risk Management 9
S Type B Uncertainty Estimation - Accuracy and Calibration Error Measurement Uncertainty (MU) 4
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
R Calibration of Jensen JTM-30 clamp meters (estimation) General Measurement Device and Calibration Topics 4
BradM Uncertainty calculation - Estimation for a Mettler Toledo XP 56 balance at 20 grams Measurement Uncertainty (MU) 11
