Raw data retention for Diagnosis Results
My question is related to the retention of raw data and diagnosis results based on this raw data. Our medical device is a "Medical Device Software" falling under the new EU MDR regulation. The software uses raw data from another medical device and computes a diagnosis that influences treatment given to a patient.
It is unclear to me if 1/ we need to keep the raw data and/or the diagnosis 2/ if so, for how long.
Any pointers, insights would be great.
Thanks.
Ninja
Looking for Reality
Howdy Ernesto,
I am not in medical...and not in the EU...so understand that up front.
I do, however, work in data, data storage and data integrity...
Simply from a CYA standpoint, if you are going to store the diagnosis, you should also store the data that diagnosis was based upon...helps immensely for the lawsuits later.
There's a balance between cost, speed and lowering risk. (Speed comes in since copying data takes longer than RAM access of data via query).
There may be regulations at play as well, as you ask in the first place...but others here can answer that one.
yodon
In theory, when you validate your system, you have high assurance that the results are (always) accurate (your diagnosis is correct based on the data). Thus, you shouldn't have to keep any of the data. Regarding the CYA tack @Ninja suggested, maybe you can add something to the report that supports the diagnosis (some or all of the raw data values)?
Managing what I presume would be protected health information (albeit probably de-identified) brings a heavy legal burden and greatly increases the controls needed to protect. Make sure you understand that first before saving any. (I tend to be quite paranoid regarding health info.)
V Additional Controls for processing the raw data on different computers (processing system) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
C Informational CFR 21 Definition for Data or Raw Data Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
I 510k Performance Testing Studies (Raw Data) - What does the FDA expect 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
I 510(k) Raw Data from Studies - 21 CFR Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 4
S Use of Published IMDS Data from our Raw Material Supplier RoHS, REACH, ELV, IMDS and Restricted Substances 6
Q Is Handwritten Raw Data required to keep with Electronic Records? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L Arima Output - Relationship between my raw data and the residuals generated Using Minitab Software 1
M 21 CFR Part 11 & Control of Raw Data Records used as input into Validated Spreadsheet Qualification and Validation (including 21 CFR Part 11) 2
B No editable (alterable) raw data from outside calibration laboratory? General Measurement Device and Calibration Topics 20
D Calculating Metrics from the bunch of single/raw data for certain purposes Benchmarking 5
D Life of the part - How long should I keep processing data, powder, raw material tests Document Control Systems, Procedures, Forms and Templates 3
S Skipped/Reduced testing in Pharma for Raw materials and Intermediates Manufacturing and Related Processes 0
M Preparing a document for Raw Material of Medical Device EU Medical Device Regulations 1
D Raw Material Expirations Manufacturing and Related Processes 2
E Record Retention - Raw Material (Steel Certs) Records and Data - Quality, Legal and Other Evidence 3
S Use of raw materials by two supplier CE Marking (Conformité Européene) / CB Scheme 2
Q Change the shape of the raw material FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Anonymous16-2 Dietary Supplement Raw Material/Component Storage and Production Manufacturing and Related Processes 1
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
J Raw material certificates - CC - Safety products - Sheet metal stamping IATF 16949 - Automotive Quality Systems Standard 1
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Production of raw materials in university labs? Lean in Manufacturing and Service Industries 11
C Clean room injection molding, raw material mixing requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
C Raw material Mixing / Preparation for clean room class C injection molding Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Raw stock material testing discrepancy using an XRF (x-ray fluorescence) analyzer Manufacturing and Related Processes 7
A Reduced Testing of Pharmaceutical Raw Materials Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
K ISO 9001 Requirements for Raw Material Supplier Assessment and Approval ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Material selection - How do we select a raw material? Bolt made of SAE J994 grade 2 Customer and Company Specific Requirements 3
S CQI-12 - Applicability to Raw Materials Customer and Company Specific Requirements 1
D Raw Material chemical/Tensile Requirements Specifications (QQ-A-250/4, etc) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Are Medical device Raw material suppliers required to be ISO 13485 certified ISO 13485:2016 - Medical Device Quality Management Systems 13
D DFARS (Defense Federal Acquisition Regulation Supplement) Raw Material Information Various Other Specifications, Standards, and related Requirements 2
Q Do we have to prove a link between the mill and our raw material supplier? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
C Approval of raw material suppliers which do not manufacture the material ISO 13485:2016 - Medical Device Quality Management Systems 7
R AS9100D Cl. 8.4.2 - Identify Raw Material as a Significant Operational Risk AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J AS9100 - Validation of Test Reports for Al 304 Raw Material AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Nonconformance Raw Material Treatment in ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C What is considered a "Critical" Raw Material? (Re: DNA Synthesis) Misc. Quality Assurance and Business Systems Related Topics 3
Z How to Contractually Agree on Specifications for Raw Material Purchases Supplier Quality Assurance and other Supplier Issues 15
J IMDS: How to manage same Raw Material from Two Suppliers? RoHS, REACH, ELV, IMDS and Restricted Substances 2
V Study About Raw Materials (Polymers) - DSC, FTIR,TGA, and SEM Images Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
P FDA On-Site Inspection - Raw Material Manufacturing (Medical Devices) Other US Medical Device Regulations 5
N Raw Material Supplier Approval (Inks, Resin, Masterbatch etc) Supplier Quality Assurance and other Supplier Issues 4
N Receiving Inspection - Who should receive raw material Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
K TS 16949 Planning Phase: Raw Materials purchased from Distributer and the PPAP impact IATF 16949 - Automotive Quality Systems Standard 3
E Pallets need to be changed when raw materials are transferring from WH to MFG area? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
Gman2 Identification of Raw Material being used In-Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Archiving IVD Test Kit Raw Materials 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T AS9003 7.4.3 Critical Raw Material Verification Advice AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
