Raw Materials verification - Melt Flow Test - Resins: Customer not Satisfied
Carl Keller
Ran into an interesting one recently.
A customer audited and was concerned because we completed a melt flow test on every 5th lot of resin. They felt we did not have a satisfactory raw materials verification procedure.
They will probably really be upset now because since then, I have completely eliminated melt folw testing for the following reasons:
1. We have never received a melt flow outside the stated range and hence, have never rejected a lot of resin for melt flow.
2. Melt flow for different resins can be within the same range, so what is it telling you?
3. We use major resin suppliers which provide resin certs and state the resin, lot number and melt flow.
So my question is, what would the FDA think? AND how do others verify that what is in the box is the same as what is stated on the incoming cert. because melt flow is definitely not conclusive.
Carl-
Al Rosen
The FDA has no specific requirement and leaves it to you to determine what is required to accept incoming product. But depending on the application you would need more or less stringent controls. You didn't state what the material is being used for. Will it be in contact with the body? Will it be used in an implant? This could affect how the FDA views acceptiong the material based on a suppliers cert.
To assuage your customer's concerns you could periodically (annually or a some reasonable period) send a sample of the material to an independent lab for analysis to verify your supplier's certification.
Carl Keller
Al,
Thanks for the insight.
Materials are used for Pharma packaging and one medical device that is not an implant (dosage delivery)
Resin analysis is very costly and I would like to avoid even annual checking.
I am not sure the credentials of the lab would be any better than our resin suppliers anyway. We deal with the major players for the most part.
Thanks,
Carl-
V
Vincnet
Well Carl,
in my opinion the whole story revolves around the risk analysis for the use of the resin in the final product. In other words what are the essential properties of the resin you need to control to ensure that your final product will not be affected by modification of these properties in one batch.
I have to deal with this nightmare every single day. :bonk:
My R&D dept and my manufacturing dept are not abble to tell me what are the essential specifications of the raw material we need to monitor to make sure that the final properties of our products are not altered. :whip:
The way I found to go round that, is that we do not consider a raw material as being OK until it has been used for manufacturing a product that passed the final functional QC before release. The assumption being there that if the final product is ok then the raw material is. The economic issue being if the QC is not good then we have to track back which component is not ok.
I did not felt completely confortable with that i reccently met with a company specialised in process validation. Those guys told me that in our field (Biotech) it is becomming more and more common to do so.
We have a 13485 pre audit on the 21st of this month, I'll let you know if my auditor killed me :mad: or not :agree1:
V
Carl Keller
Vincent,
Thanks.
We are 13485 registered, but the auditor has not taken issue as yet. The customer did an audit "based on FDA regulations".
I think I am on pretty solid ground with my thinking.
We get a Cert from the Manufacturer
I can show evidence of past history
We use SPC for dimensional stability
We have final QC checks for dimensional measurements
Good luck on your audit.
Carl-
S Use of raw materials by two supplier CE Marking (Conformité Européene) / CB Scheme 2
A Production of raw materials in university labs? Lean in Manufacturing and Service Industries 11
A Reduced Testing of Pharmaceutical Raw Materials Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
S CQI-12 - Applicability to Raw Materials Customer and Company Specific Requirements 1
V Study About Raw Materials (Polymers) - DSC, FTIR,TGA, and SEM Images Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
K TS 16949 Planning Phase: Raw Materials purchased from Distributer and the PPAP impact IATF 16949 - Automotive Quality Systems Standard 3
E Pallets need to be changed when raw materials are transferring from WH to MFG area? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
S Archiving IVD Test Kit Raw Materials 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Cleanliness Requirements for Raw Materials Used in a Controlled Environment Quality Manager and Management Related Issues 4
pittmatj CFDA Requests Biocompatibility Evaluation for Raw Materials ISO 13485:2016 - Medical Device Quality Management Systems 6
T SOP for How to Write a Specification for Raw Materials and Finished Good ISO 13485:2016 - Medical Device Quality Management Systems 3
J Deciding what Raw Materials we should require CofCs for ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
V Analysis of Raw Materials, as per pharmacopoeia ... of target OR originating country US Food and Drug Administration (FDA) 1
M Ensuring Continuous Quality Raw Materials from Suppliers Quality Manager and Management Related Issues 8
C Receiving Raw Materials, Inspection, Release Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
AnaMariaVR2 Excel - Sorting by Product or Raw Materials [need Help] Excel .xls Spreadsheet Templates and Tools 4
N Same Raw Materials, different composition Canada Medical Device Regulations 4
J Does ITAR regulate the import of Raw Materials used in Machining AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K Raw Materials from 3rd World Countries vs. Finished Products from 1st World Countries Philosophy, Gurus, Innovation and Evolution 23
M Commercial Measurement of Raw Materials/Production etc. Manufacturing and Related Processes 2
K Establishing Item Codes for Production Raw Materials Misc. Quality Assurance and Business Systems Related Topics 2
D Samples from Lots of Incoming Raw Materials - Sampling Protocol Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
J Risk Assessment of Raw Materials? Medical Device product ISO 14971 - Medical Device Risk Management 2
W No-No List of raw materials in medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 4
N Customized sampling plan - Acceptance sampling plan for the raw materials Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Raw materials as bulk materials (polymer, adhesive, etc) for PPAP IATF 16949 - Automotive Quality Systems Standard 1
Q 7.3.6.3 Product Approval Process - Raw materials and sub-contactors or all suppliers? IATF 16949 - Automotive Quality Systems Standard 2
R Expiry Date of Sutures based on Shelf Life of Raw Materials ISO 13485:2016 - Medical Device Quality Management Systems 9
J Specification of Raw Materials - Can I accept one based on an earlier Revision? Various Other Specifications, Standards, and related Requirements 1
A Certification of Raw Materials for RoHs Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 3
K PPAP Requirements for Raw / Bulk Materials? APQP and PPAP 6
J Endotoxin testing - Raw materials and components of a Class III medical device ISO 13485:2016 - Medical Device Quality Management Systems 6
B MSA for Application Test Results - Supplying liquid raw materials to foam producers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
J Test method validation on raw materials, intermediates and final device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
A Can anyone tell how do we do inprocess inspection of raw materials Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
W How do I manage Suppliers of raw materials, parts and/or assemblies? Supplier Quality Assurance and other Supplier Issues 17
S Anyone have a Chemical Laboratory Accredited to 17025? Raw materials used as fuel ISO 17025 related Discussions 2
C Skip-Lot Testing and the FDA - Reduced Testing Plan for Raw Materials Statistical Analysis Tools, Techniques and SPC 8
A Crack Testing of Raw Materials - Steel Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
M Traceability of Raw Materials - Requirements QS-9000 - American Automotive Manufacturers Standard 11
E Record Retention - Raw Material (Steel Certs) Records and Data - Quality, Legal and Other Evidence 3
Q Change the shape of the raw material FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Anonymous16-2 Dietary Supplement Raw Material/Component Storage and Production Manufacturing and Related Processes 1
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
J Raw material certificates - CC - Safety products - Sheet metal stamping IATF 16949 - Automotive Quality Systems Standard 1
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C Clean room injection molding, raw material mixing requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
C Raw material Mixing / Preparation for clean room class C injection molding Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Raw stock material testing discrepancy using an XRF (x-ray fluorescence) analyzer Manufacturing and Related Processes 7
