Re-Evaluating Corrective Actions - Recurrence of a Customer Complaint
W
wes77
A year ago, my company issued a corrective action for its product to address customer complaint. There have not been any problems or re-occurrences of the original problem until now.
This complaint is same as the ones before, but from a new lot post corrective action.
Does this mean the corrective action has to be re-opened?
Does a new corrective action have to be opened to address new complaint and old corrective action?
Can we treat this event as an isolated incident and monitor for an identical incident before making an issue?
Any suggestions?
Marc
You say it has happened before. That means, for all intents and purposes, it is a recurring problem (even though it has been a year since the last incident).
To me an isolated incident is a 1 time thing.
Personally I'd re-open the old corrective action and add to it. You already know it is recurring (it happened again), so what ever you originally did was not effective.
You can start a new corrective action. If you do start a new corrective action you have to reference (and learn from) the original corrective action.
Key Word: Recurring Nonconformance.
Stijloor
Any suggestions?
Welcome to The Cove Forums! :bigwave: :bigwave:
Is the problem the same? Same material (although different lot)?
How many shipments (or a percentage) have you received with no problems?
Requesting corrective action from your supplier depends on the significance of the issue.
A recurrence is usual evidence of the corrective action not as robust as initially determined.
If you can share some more details, that would help us.
Stijloor.
W
wes77
THanks guys!!!
The problem is the exact same problem as before.
There have been about 500 shipments since the corrective action. It is the same material. The corrective action dealt with adding more material making the product more robust to prevent complaint from re-occurring.
Craig H.
THanks guys!!!
Sounds to me like the root cause has not been identified. What was different when the problem happened?
Time to drive down into the process.
It does not matter much if you reopen an old C/A or open a new one, referencing the old. Get to work finding out what is happening. Forget the style and go for the substance.
JaxQC
THanks guys!!!
I'm with ChrisH but I have to ask an additional question which might not be answered until you get into it a little more. Yes the problem is the same (hurt toe) but is the failure mode the same (hurt toe because it's dark, things in the walk path, hole in the ground) is root cause failure to maintain transport area while dropping brick on toe is same problem (hurt toe) but a new uncontrolled failure mode (not proper handling, root cause is too small of table to set bricks on) that might not be related to the original.
In short, open a new, reference the old, then either discount them being related (with detail why) or it was indeed not permanently correct the first time.
Any suggestions?
I agree with Marc's response (it's a recurrence and you should just reopen the previous CA) except for the bit about isolated incidents. Whether the event is properly characterized as an outlier depends on facts not in evidence at this point. Just because a phenomenon occurs twice doesn't necessarily mean that it's not an outlier.
As for your reaction at this point, was the cause of the complaint the same as the original cause? When you closed the previous CAR, did you do so because you believed that the cause had been permanently neutralized or removed, or did you close the CAR with an expectation that the NC could happen again, but you were willing to accept it within reasonable bounds?
U
Umang Vidyarthi
THanks guys!!!
As Marc has suggested, it is a recurrence so the earlier CAR needs to be reopened. You will have to go through your Root Cause Analysis with a microscope.
2. Since the problem was 'switched off' after CA/PA, and did not recur during 500 odd shipments, it is safe to presume that the CA/PA of 'adding more material' was effective.
3. Prima-facie it looks to me that the problem lies somewhere with the re-inforced material. May be the supply of the said lot was inferior, which missed detection during ICI (Incoming Inspection). If so, then re-inforcement with the proper material will resolve the problem.
Umang :D
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
R Evaluating the need for preventive action Preventive Action and Continuous Improvement 3
M Informational US FDA – FDA provides updates on the agency’s continued commitment to evaluating postmarket safety of Essure device Medical Device and FDA Regulations and Standards News 0
S Evaluating the possibilities of using qmswrapper or greenlightguru Document Control Systems, Procedures, Forms and Templates 4
C Evaluating GRR Scores %Tol vs %TV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Q Evaluating Effectiveness of a Preventive Action after Closure Preventive Action and Continuous Improvement 7
J Potential Customers Asking for EIRs / 483s when evaluating a CRO for future work US Food and Drug Administration (FDA) 2
P FDA - Evaluating Substantial Equivalence in Premarket Notifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Quality Control Procedure and Procedure for Evaluating Sub Contractor Document Control Systems, Procedures, Forms and Templates 1
M Evaluating Vendor (Supplier) Products using SQC Statistical Analysis Tools, Techniques and SPC 6
K Evaluating different Startup Options in EU and MDD ISO 13485:2016 - Medical Device Quality Management Systems 4
S Trading Company - Evaluating Supplier Performance and Approved Supplier List ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J The 510(k) Program: Evaluating Substantial Equivalence in Premarket Notifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
E Evaluating Lean Knowledge: Lean Philosophy Course for Production Engineering Students Lean in Manufacturing and Service Industries 1
A Evaluating an Integrated Management System - Dissertation Topic ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
optomist1 Evaluating Capability Indices with Minitab Using Minitab Software 7
C Trend Analysis - Evaluating Quality of Pricing - ANVOA or Std Dev? Statistical Analysis Tools, Techniques and SPC 25
D Good source for Checking and Evaluating Control Plans needed FMEA and Control Plans 4
R EMP (Evaluating the Measurement Process) Studies for Bias Effect Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Evaluating a Regression Model Using the Constant Variance Assumption Six Sigma 8
Wes Bucey "Downsizing" ramifications - Evaluating and Interpreting the News World News 0
A Methods of evaluating compliance to ISO 14001 ISO 14001:2015 Specific Discussions 6
M Evaluating my QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G 100% Sort Verification - Statistical Method for Evaluating Suspect Material Statistical Analysis Tools, Techniques and SPC 19
J Evaluating and Reporting the Results of Layered Process Audits Document Control Systems, Procedures, Forms and Templates 9
G Evaluating Software for GMP Criticality? Software Quality Assurance 3
M Evaluating adverse effect on device tested with out of tolerance instrument General Measurement Device and Calibration Topics 3
Q Evaluating Internal Audit Results Internal Auditing 24
P Rockwell, Brinell, Vickers Conversion - Evaluating Aluminum 6061-T6 and 6063-T6 General Measurement Device and Calibration Topics 11
U Evaluating the aspects... All judgement based or is there a more objective way? Miscellaneous Environmental Standards and EMS Related Discussions 1
D Evaluating competence on training for new ISO 13485 standard for employees ISO 13485:2016 - Medical Device Quality Management Systems 7
Q "Service" Vendor (Supplier) Evaluation - How are you evaluating suppliers? Supplier Quality Assurance and other Supplier Issues 5
N Evaluating Process Stability - Unstable Processes - Cpk/Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
Z Seeking GM standard GM9684P - Procedure for evaluating parting lines Customer and Company Specific Requirements 2
S Metrics for Evaluating Design process Design and Development of Products and Processes 2
C Evaluating software that measures Ppk, Cmk, Cpk, PPI, etc. Capability, Accuracy and Stability - Processes, Machines, etc. 4
H Good starting point for a new QC Manager? Evaluating Existing Procedures Document Control Systems, Procedures, Forms and Templates 21
Gman2 Evaluating training, needed for office personnel? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
G Evaluating Processes - Cycle Time Concepts - Three Levels for any process Manufacturing and Related Processes 3
C Evaluating the Effectiveness of Internal Audit Process Internal Auditing 16
Marc Evaluating 5.3 c - Quality Policy - Framework General Auditing Discussions 1
T Evaluating Customer Satisfaction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B Risk Anlysis for Evaluating then Voiding or Not Issuing CPAR's Nonconformance and Corrective Action 1
M ISO 9001:2000 - Evaluating Training Effectiveness and Why ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
C Can anyone suggest a means of evaluating a suppliers performance? Supplier Quality Assurance and other Supplier Issues 4
Raffy Evaluation Form - Re-evaluating suppliers for their performance Supplier Quality Assurance and other Supplier Issues 8
G Evaluating Training Effectiveness - 6.2.2 Competence, Awareness and Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 55
S Supplier Evaluation - Evaluating transport suppliers and equipment suppliers Supplier Quality Assurance and other Supplier Issues 2
D What exactly is needed on the subcontractor list for evaluating subcontractors QS-9000 - American Automotive Manufacturers Standard 4
D Evaluating Subcontractor On-time Delivery Misc. Quality Assurance and Business Systems Related Topics 3
