Re-Issue of Documents - Requirement to re-issue a document after so many revisions?
jonnycad
re-issue of documents
I have read that for QS-9000 you should re-issue a document after so many revisions. Is this true? If so, and the document is identified with an I.D such as ABC - 1234 Rev 5, What does the Id. become after Re-issue. Does it become ABC-1234 Rev 1 or do you have to obsolete that I.D. and issue a new i.d. to the document
SteelMaiden
Jonnycad,
I have used the "Re-issue" method for the last 5 years. We were at the point where so many documents had been revised so many times that they bore little resemblance to the original. We changed policy on revisions and stated that after 10 revisions the document COULD be re-issued as new, or if the process had changed significantly (going from a manual process to an automated, etc.). The standard practice included review of the document to assess how much had actually been changed, and basing the decision on that review.
All re-issued documents showed: Re-Issued and the date instead of our standard Issued and the date. Our master file also showed that the document was re-issued along with a statement of why we chose to re-issue.
It worked well for us, passed the QS audits and made it a lot easier to wade through the master files. I really can't say that I have ever heard anyone say you had to re-issue documents in QS. We just found that it was easier in our business.
Best of luck!
Al Dyer
Re: re-issue of documents
1: Where did you read this?
2: Does the word re-issue appear in QS-9000 text?
I don't think we need to take it too deep and make it too hard to follow, when you revise a document you keep some type of record (your system and choice) that notes the reason for change and new revision level.
I have never in my career heard of a reason to re-issue a document, every new revision is a "re-issue".
Taking into consideration the inter-relationship between documents, keep it as simple as possible.
As an example,
I have document QS-131-A
It refers to document QS-234-B
As a method to reduce future labor on document QS-131-A, when I refer to QS-234-B, I leave off the revision level (B) and just refer to QS-234.
This way, if I change QS-234-B, I don't have to revise QS-131-A because it does not refer to the revision level.
I Reissuing documents due to missing version / issue numbers Document Control Systems, Procedures, Forms and Templates 3
N Documents in different languages - Revision and Issue Number Document Control Systems, Procedures, Forms and Templates 7
A Effective Date (of Documents) issue outlined in 21 CFR Part 820.4 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
JoCam Issue Dates/Revisions of Standards referenced in Internal Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Revision Levels on Documents - First Issue Revision Level Document Control Systems, Procedures, Forms and Templates 9
T Approving documents prior to issue - What guarantees their adequacy? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P MedWatch Report from a hospital due to a quality issue US Food and Drug Administration (FDA) 5
Marc Media Gallery Issue? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
R Problem solving activity - Three hours to fix the issue Manufacturing and Related Processes 15
Marc Fuel tank issue (FOD) hits Boeing’s 737 MAX - Feb 2020 World News 19
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
Ron Rompen 2D matrix issue - Parts (machined steel) returned from the customer Design and Development of Products and Processes 0
G PolyWorks Alignment Issue - How to align the part General Measurement Device and Calibration Topics 1
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
A External Auditor issue with Internal Audits Internal Auditing 7
V Every good documentation practice observation is an data integrity issue US Food and Drug Administration (FDA) 7
V What is the criteria to cite an good documentation practices observation as an data integrity related issue US Food and Drug Administration (FDA) 6
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
J Control of nonconforming product issue (AS91000) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C TL-9000 Certifying Body Issue - Auditor failed to find an issue for 10 years TL 9000 Telecommunications Standard and QuEST 16
E Determining what is good and what is bad can be subjective - when is it a quality issue? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Ed Panek Sensitive Supplier Issue - Single source supplier ISO 13485:2016 - Medical Device Quality Management Systems 6
B NB won't issue CE Certificate or return phone calls CE Marking (Conformité Européene) / CB Scheme 3
A Drawing Issue with Supplier - xb file did not match that of the pdf drawing Nonconformance and Corrective Action 4
J MAG 6 and EASA Part-145 Issue 005. EASA and JAA Aviation Standards and Requirements 0
A ISO/IEC 27001 - Issue during implementation of system IEC 27001 - Information Security Management Systems (ISMS) 3
M Saturated salts issue - Humidity Chamber General Measurement Device and Calibration Topics 5
N Do I need to approach galvanized steel sheet flatness issue with DOE? Problem Solving, Root Cause Fault and Failure Analysis 9
Sidney Vianna ASQ apparently doesn't know ISO does not issue ISO 9001 certificates? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
D Can an AS9100 auditor issue an NCR a month after the audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
K Class II Medical Device Compatibility Issue - Removal or Market withdrawal? US Food and Drug Administration (FDA) 2
J Can you stock parts without an 8130 and issue one at time of sale? Federal Aviation Administration (FAA) Standards and Requirements 2
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
K NCR or CA? We're taking any issue we have and saying its a nonconformance Nonconformance and Corrective Action 11
R DCMA QAR Service Issue - Resident Inspectors absent from the plant AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Wet Signature Document Attachments in SAP - Risk on Data Integrity issue? Records and Data - Quality, Legal and Other Evidence 6
Mikishots Definition Issue - "Issue" vs. "Risk" in ISO 9001:2015 and AS9100 Rev D (Definitions) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
F Power Cord Length Issue - Medical Device Electrical Safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Breach of Contract from Registrar (Auditor Payment Issue) Registrars and Notified Bodies 18
T EASA TAG Block 11 Status/Work issue Quality Manager and Management Related Issues 1
M Issue with CAPA system - Should Over Due CAs warrant a CAPA? Nonconformance and Corrective Action 17
S Could I issue major finding for Inadequate Procedures Supplier Quality Assurance and other Supplier Issues 17
G IEC 60601-1-2 Sample Size issue Other Medical Device Related Standards 1
M Repeatability issue in Gage R&R study for inner diameter of a bushing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
G Out of Dimensional Tolerance - MRB Audit Issue Nonconformance and Corrective Action 11
P Cross Section Issue - Dissecting a plastic part for measurement Manufacturing and Related Processes 4
