Re-validating revised Medical Device and Aerospace Product COTS software
RCW
(Company background: Medical devices and aerospace products)
My company is using a QMS software suite that contains CAPA, Document Control, Nonconforming Material Handling, Training, etc. For the previously installed version, a colleague and myself performed a validation on the software. I just recently installed the latest version of the software which had 3 previous releases that I did not install.
The software company provides a "readme" pdf for each revision which goes through the enhancements and bug fixes. I was going to use this information to re-validate the software to the latest revision. However upon reviewing the pdf, some of the bug fixes don't makes sense to me as a user most likely because I am not aware of the problem that required these fixes.
I contacted the software company and to make things even more confusing to me they said that some of the fixes would not even apply to my software as they were system dependent (ex. another customer was using a different server setup that caused the problem on their system only).
I am trying to figure out the best way to re-validate the software. I don't want to go through a whole validation again but it almost looks like that is the most efficient way to address the validation process as it is difficult if not impossible to determine what bug fixes actually apply to my system.
Any suggestions or comments on how to go about re-validating COTS software given what I have laid out above?
yodon
At least on the medical device side (can't comment if aero is different), you can limit the scope of the re-validation based on a documented risk assessment. I'll certainly commend you for contacting the vendor and trying to get specific information!
If you can't isolate changes to modules, maybe consider a staged re-validation. Do a "happy path" (very limited) validation just touching each module. If any of the modules are specifically affected or if they are particularly high risk, maybe expand the testing a bit in those areas. Evaluate the results and if all is good, call it re-validated; otherwise, investigate any anomalies and expand the testing accordingly.
As a further risk mitigation, maybe conduct spot reviews after you deploy the new release and see if all is working well. You can define that as a time period or set of activities. Kind of a parallel re-validation. Of course, if you found any anomalies during this period, you'd need to do a deep dive.
Of course, all this is predicated on your procedures allowing it. If your procedures require a full re-validation then that's what you should do.
Document your decisions and provide the rationale, do some level of testing, and document any monitoring you do. I would think that would demonstrate due diligence.
yodon
Oh, be sure to document your analysis of the issues as part of the validation report.
D Seeking help in validating a cleaning process. Manufacturing and Related Processes 5
M Validating a 'kit' Other Medical Device and Orthopedic Related Topics 3
C Practical experience validating CNC Mills Medical Device and FDA Regulations and Standards News 11
B Validating calibration certificate as per API Q1 General Measurement Device and Calibration Topics 9
D Validating Operating system Qualification and Validation (including 21 CFR Part 11) 4
N Validating Software before getting approved as Class 2 device US Food and Drug Administration (FDA) 5
Ed Panek Validating Excel (XLS) formulas 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
A Validating my own application developed with Agile Qualification and Validation (including 21 CFR Part 11) 5
T Risk analysis of QMS software - Validating software we use for QMS ISO 13485:2016 - Medical Device Quality Management Systems 7
H Validating Nondestructive leak testing machine Qualification and Validation (including 21 CFR Part 11) 3
S Validating a Bonding Process Qualification and Validation (including 21 CFR Part 11) 3
M FDA's expectation for validating OTS software updates Other US Medical Device Regulations 8
J Validating a stopped test due to never finding any defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Validating multiple injection molding machines efficiently ISO 13485:2016 - Medical Device Quality Management Systems 5
J Grouping Products and Testing Sterile and Biocompatibility - Validating Products Other Medical Device Regulations World-Wide 3
G Validating a Process Based on Lot Release Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Meeting the Requirement of Clause 7.5.2 on Validating Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Validating a Product through Tool Control and Tool Inspections Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
G Validating a Sandblasting Process - Any pointers? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
G Testing and Validating a New Vertical Milling Machine AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Q Validating Tape Measures used to Measure Product Conformity to Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Protocol for Validating Pull Tester and Force Gage Qualification and Validation (including 21 CFR Part 11) 9
T Validating Supplier Statement - Rusty shield that supplier denied responsibility Manufacturing and Related Processes 7
M Validating 3rd Party Software which Tracks Archived Samples Qualification and Validation (including 21 CFR Part 11) 2
Q Validating ESD (Electrostatic Discharge) Flooring ISO 13485:2016 - Medical Device Quality Management Systems 2
M Procedure for Validating Laser Marking & Electropolishing of Orthopedic Implants Other Medical Device and Orthopedic Related Topics 13
Q Validating the AOI process (Automated Optical Inspection) Reliability Analysis - Predictions, Testing and Standards 9
K Validating a gage/fixture in-house under TS 16949 - Need information General Measurement Device and Calibration Topics 2
C Validating Custom adaptations of Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 11
C Validating a Gage R&R spreadsheet - Defining Formulas in spreadsheet cells Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
G Software Validating Adobe Professional according to Part 11? Quality Assurance and Compliance Software Tools and Solutions 10
D Validating software in materials testing - Integrated system of individual components General Measurement Device and Calibration Topics 3
D Validating Multimeters (how to) General Measurement Device and Calibration Topics 8
M Revised documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Should DoC be updated every time Technical Documentation is revised? EU Medical Device Regulations 2
William55401 21 CFR 11 Password Aging - What does "periodically" revised mean in your org? Qualification and Validation (including 21 CFR Part 11) 3
M 6.1.2.3 Contingency plans SI 3 revised and reissued July 2021 IATF 16949 - Automotive Quality Systems Standard 7
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 7
Ed Panek Compliance with Standards? When a standard is updated/revised CE Marking (Conformité Européene) / CB Scheme 3
G New CAPA Work Flow with Revised 8D Approach Process Maps, Process Mapping and Turtle Diagrams 35
M Informational EU – EMA revised guidance – Questions & Answers on Implementation of the Medical Devices and In Vitro Diagnostic Medical Devices Regulations ((EU) 201 Medical Device and FDA Regulations and Standards News 2
M Informational Several revised or updates USFDA guidance - 9/9/2019 Medical Device and FDA Regulations and Standards News 12
J Revised MDSAP Audit Model - Health Canada - October 30, 2017 ISO 13485:2016 - Medical Device Quality Management Systems 7
Sidney Vianna SCMH Awareness Webinar Focused on the revised Advanced Product Quality Planning APQP AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Marc Release of New or Revised Procedures Document Control Systems, Procedures, Forms and Templates 5
V Revised ISO std vs ISO13485:2003 - Help Please!!! ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Evalaution of the On Market Device to a Revised Standard Other ISO and International Standards and European Regulations 4
bio_subbu NBOG Publishes revised best practice guidance documents (Nov 2014) EU Medical Device Regulations 1
V Is MHLW Std No.169 - 2004 being Revised in Nov 2014? Other ISO and International Standards and European Regulations 5
