Reagent Status Identification - 7.4.3 Verification of Purchased Product
Mandy
We are a small R&D company developing an LDT, that we hope one day to market. We are in the process of becoming ISO 13485 compliant.
My question is regarding reagents:
The ISO Standard stipulates:
7.4.3 Verification of purchased product
The organization shall establish and implement the inspection or other activities necessary for ensuring that purchased product meets specified purchase requirements.
I have not seen in ISO 13485 a requirement to identify (label) the status of reagents after receipt inspection.
When I worked in pharmaceuticals all raw materials were labeled with their status (quarantine, approved, rejected).
Is this necessary in such a small company that I'm currently working in?Reagents are not tested before use, we fill in a Receipt Inspection form, and I think that is sufficient.
Responses .....
Mandy
Hi
Since I got no responses, I thought I'd give my post a bump.
Hoping to hear from you.
Mandy
Ronen E
Problem Solver
Moderator
From ISO 13485:2003
7.5.3.3 Status identification
The organization shall identify the product status with respect to monitoring and measurement requirements.
The identification of product status shall be maintained throughout production, storage, installation and servicing of the product to ensure that only product that has passed the required inspections and tests (or released under an authorized concession) is dispatched, used or installed.
(Emphasis is mine)
Cheers,
Ronen.
Mandy
Thanks for your response.
My question relates to the reagents used to create the product.
Do these need to be identified (for example with green/yellow/red labels)?
Again - we don't test any reagents before use, but rely on the COC.
somashekar
To test or not is your call. If the CoC verification is good for you, its fine.
The reagents are perhaps identified by the distinct name on the label itself. This will serve as your identification. There is no need of any color label.
How are the reagents stored and handled up to the point of use ?
How are the shelf life of the reagents known at the point of use ?
Is there a chance that a wrong reagent or an expired reagent will be used for the lack of its proper identification ?
Your answers to this must set up your identification method.
Ronen E
Problem Solver
Moderator
S. 7.5.3.3 is usually interpreted to apply to components / ingredients of the product too (i.e. intermediate stages in creating the finished product). If your reagents are ingredients of the product (i.e. remain in some part and form in your finished product) then their status should be identified along the production process, IMO. If they only catalyze some reactions then perhaps they should be looked at as tools.
Ajit Basrur
Responses .....
Yes, it is required to label all reagents to ensure that expired reagents are not used. Its upto your organization to address this requirement either by use of colored labels or used of bar code labels etc.
Following quality systems is irrespective of the size of the company and thus though you are a "small" company, you have to follow the standard requirements.
R Re-Use of Diagnostic Reagent Solution Labels - Buffer Solutions for Internal Use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Reagent tracking in an ISO 17025 laboratory ISO 17025 related Discussions 2
L IVD Reagent Techncial File Review Requirements (IVDD Annex III) EU Medical Device Regulations 4
I IVD products that are labeled as Analyte Specific Reagent (ASR) US Food and Drug Administration (FDA) 2
M Replacing Components in an IVD Reagent Kit ISO 13485:2016 - Medical Device Quality Management Systems 2
P Risk Management Files for IVD (Invitro Diagnostic Reagent) Kits ISO 14971 - Medical Device Risk Management 3
D 510K Approval Guidelines and Marketing in the US - CD4 Count Reagent 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Diagnostic Reagent Stability Studies - Final Product Packaging EU Medical Device Regulations 8
B Urine Reagent Strips - Which directive should I put on the declaration? EU Medical Device Regulations 1
K Microbiological State of a Reagent Kit - Enquiry Regarding ISO 18113 Other Medical Device Related Standards 1
B Is Liquid Reagent Volume Underfill a Recall Requirement? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
N Reference Standard for Acceptance Criteria for Validation of a Reagent Various Other Specifications, Standards, and related Requirements 2
F Ancilary device status in Panama and Dominica Other Medical Device Regulations World-Wide 0
C UDI Enforcement Status in Egypt Other Medical Device Regulations World-Wide 0
A LEDs in the system to indicate a status or fault IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Travel in Thailand status, Aug 2022 Travel - Hotels, Motels, Planes and Trains 3
V Product naming: Same name - different perfume & status CE Marking (Conformité Européene) / CB Scheme 0
S When to change the status of a GTIN from "Premarket" to "In Use" ? US Medical Device Regulations 2
U Is Initial Importer Status Required if a Medical Device is Manufactured and Sterilized by an OEM in the US Other US Medical Device Regulations 1
John C. Abnet Special Status Notification IATF 16949 - Automotive Quality Systems Standard 1
Z Proving REACH/RoHS status for electronics components from Digikey/Mouser REACH and RoHS Conversations 7
R Getting harder to track the status of each one of the contracts Contract Review Process 0
S Changing revision status of a reviewed document Manufacturing and Related Processes 12
Q Project Tracker - Something that shows the status of each project Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
S PPAP Progress - Visual Status Board APQP and PPAP 0
M Status of Medical Device Regulations in UK Post-Brexit Other Medical Device Regulations World-Wide 10
F Is there such a thing as 'Critical supplier' status under the Dept. of Health (UK)? Medical Device and FDA Regulations and Standards News 2
M Informational TGA – Current status of breast implant products in Australia Medical Device and FDA Regulations and Standards News 0
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
JoshuaFroud The withdrawal of Lloyd’s Register MDD & IVDD Notified Body Status CE Marking (Conformité Européene) / CB Scheme 1
M Informational Medtech Europe presentation – – Industry Perspective on the Implementation Status of the MDR/IVDR Medical Device and FDA Regulations and Standards News 0
M Informational Medtech Europe – Open letter to the European Commission on the implementation and readiness status of the new Medical Device Regulation (MDR) Medical Device and FDA Regulations and Standards News 0
D The Status of ROHS for Medical Devices - April 2019 REACH and RoHS Conversations 3
R Visually impacting graphics for Nonconformance status metrics for Management Report Nonconformance and Corrective Action 5
S VW Special status condition IATF 16949 - Automotive Quality Systems Standard 3
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
S Checking status of Medical device Other Medical Device and Orthopedic Related Topics 2
qualprod SAI Global Status as of July 2018 Registrars and Notified Bodies 2
S Status products when/if the QMS ceases to function? EU Medical Device Regulations 1
S Financial status of critical vendor IEC 27001 - Information Security Management Systems (ISMS) 7
H IS there any database for list of CE marked Medical devices and there current status EU Medical Device Regulations 8
Marc The Voynich Manuscript - Status as of January 2018 After Work and Weekend Discussion Topics 0
T Customer special status and initial IATF certification IATF 16949 - Automotive Quality Systems Standard 12
M Measurement Equipment - Identification of Calibration Status General Measurement Device and Calibration Topics 25
B Calibration Status of Gauges for Training Only ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Determining the Status and Importance of the Processes and Areas to be Audited Internal Auditing 7
T EASA TAG Block 11 Status/Work issue Quality Manager and Management Related Issues 1
Sidney Vianna First AS9100:2016 certificate issued, March 2017 - Status of Transition Sept. 2018 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 117
E Status of proposed changes to Medical Device Directive EU Medical Device Regulations 0
S ISO 9001 Audit Checklist - Red, Yellow and Green status Quality Manager and Management Related Issues 10
