Real Time Electronic SPC/Control Charting
Recently there is a direction to move away from paper based SPC and do electronic charting of the control charts.
Can some one wiht the experience explain an easy way to do this.
We have tensile testers which uses a MTS software. The software saves a file that is printed and a paper based charting is done in the current system.
My preference is to use Minitabs ODBC feature to have a real time SPC by pulling the data from a data base.
Can some one share their experience in some thing of this nature.
QE.
Matt33
One caution is that your MTS software will likely save the output in a file and each time a test is ran, it is likely to put the data into a NEW file. If this is how the output is saved, ODBC would not be a good solution since you would only be able to look at one output file at a time.
I am straddling the line of promoting a product (SQCpack) developed by the company I work for and providing an unbiased answer.
I think you should consider a solution that puts the tensile test results in a database where control and other charts can be done easily.
Likes: QE
Ninja
Looking for Reality
I would suggest that you have two different things going on here:
1. an output file of data from your tensile tester
This is likely used for base calculations
2. a summation of that data into one or two points of interest (Mean, Median, Range, etc.)
This is likely used to determine P/F against tolerance or spec limits.
While there may be some value doing more analysis on each tests output file, SPC will likely give you a better read if done on the summary data lot to lot.
By all means, use electronic SPC...but consider using the Mean, Median and Range lot-to-lot for your SPC (or whatever constitutes acceptance criteria) rather than the raw output files.
...or both...
:2cents:
qualprod 7.1.6 Lesson learned real focus? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
J Using real time shelf life study as accelerated ISO 13485:2016 - Medical Device Quality Management Systems 1
T Simulate Tolerance Range with Real Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Biological testing at the end of the real time of MD Other Medical Device Related Standards 3
S Sterile Disposable Cardiac Guidewire 3yr Real Time Sterility Failure When Confirming Accelerated Aging / Labeling US Medical Device Regulations 3
Miner Reported content: Post in thread 'Form of real time study for establish shelf time' Document Control Systems, Procedures, Forms and Templates 1
A Form of real time study for establish shelf time Reliability Analysis - Predictions, Testing and Standards 4
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
S Stability accelerated vs. real-time Other Medical Device Related Standards 3
S Standards for real time stability for medical devices Other Medical Device Related Standards 2
optomist1 DFMEA - Real Life Drama FMEA and Control Plans 25
R Real Example of a currently marketed Procedure Pack CE Marking (Conformité Européene) / CB Scheme 1
M FDA News FDA Safety communication – Interim Results of Duodenoscope Reprocessing Studies Conducted in Real-World Settings Medical Device and FDA Regulations and Standards News 0
A Accelerated aging and real time study EU Medical Device Regulations 2
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
M Real-time-aging Validation - ISO / ASTM Standard - Class 111 Orthopedic Implant Other Medical Device and Orthopedic Related Topics 1
shimonv Storage Conditions of 5-40 Celsius - Accelerated and real time aging - Dilemma EU Medical Device Regulations 3
P Is ISO 13485 of November 2016 Real? ISO 13485:2016 - Medical Device Quality Management Systems 4
Ninja What is the most useless {real} documented procedure you've seen? Coffee Break and Water Cooler Discussions 4
I How to sample in a real time release process? AQL - Acceptable Quality Level 4
M Is a Real Time Stability Study required to determine Expiration Date? EU Medical Device Regulations 9
O Medical Devices - Legal Manufacturer and Real Manufacturer EU Medical Device Regulations 5
R Self-Certification Is Not a Real Thing - an IAF article Registrars and Notified Bodies 13
L How to represent the ?real? or ?actual? players in organizational chart? Misc. Quality Assurance and Business Systems Related Topics 3
Marc CBS Taps the Real Stephen Colbert as Letterman's Replacement After Work and Weekend Discussion Topics 1
S Stated Accuracy of Portable CMM Arm and Real World Use Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
T Classification of Real-Time Thermocycler for CE Marking CE Marking (Conformité Européene) / CB Scheme 3
B Permissible Exclusion for Clause 7.5.2 in a Real Estate Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Real World Example of Document Control Failure Needed Document Control Systems, Procedures, Forms and Templates 5
Crusader Real World Continuous Improvement Examples for Accounting Personnel? Quality Tools, Improvement and Analysis 3
B Any swimming tips before I dive into the pond? Real estate development business Document Control Systems, Procedures, Forms and Templates 20
S What is real Innovation? (as described by ISO 9004, 2009 edition) Philosophy, Gurus, Innovation and Evolution 5
Y Advice on this real case on AQL (Acceptable Quality Level)? AQL - Acceptable Quality Level 3
S Pulling Data In Real Time From Excel using Minitab 15 Using Minitab Software 2
Sidney Vianna Mutually Beneficial Supplier Relationships in the real world - GM learned a lesson? Quality Manager and Management Related Issues 1
C Do you implement real SPC not just a paper work? Statistical Analysis Tools, Techniques and SPC 18
D Real Life Testing related to Relevance or Quantification of Test Duration Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Capability Analysis in the Real World Capability, Accuracy and Stability - Processes, Machines, etc. 7
optomist1 Real World SPC Dealing with Outliers Statistical Analysis Tools, Techniques and SPC 22
J Rotating operators through experiencing Inspection - A real eye opener... Training - Internal, External, Online and Distance Learning 6
P DFX & DFLSS (DFSS) Techniques & Processes - Real world example of the usage Six Sigma 1
A SPC Software Packages - Real Time and can link to Databases including Oracle Statistical Analysis Tools, Techniques and SPC 7
M Tracking Materials and Tooling - Evolving to Real Life Misc. Quality Assurance and Business Systems Related Topics 8
R Customer Rquest for Real Ppk? Get Real... APQP and PPAP 2
Marc Green Building: A Real Estate Revolution? University Of Michigan Banks On LEED Sustainability, Green Initiatives and Ecology 1
S Real-Time Production Location Technology Lean in Manufacturing and Service Industries 6
Kales Veggie Shop Floor Real Time SPC Inquiry Statistical Analysis Tools, Techniques and SPC 15
A How do you obtain real Management Commitment Quality Manager and Management Related Issues 18
O Project Documentation Submission Guidelines for Real Estate Construction Document Control Systems, Procedures, Forms and Templates 4
