Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002"
dickgent
#11
You may want to break out the "R" from the GR&R. Take a single part with a single operator and measure it 10 times at the same dimension. Do this for each operator and calculate the variance. This will give you a proportional variance that you can use to narrow contributors down. This is based on producing an Anova to measure the interaction effects.
Ninja
Looking for Reality
#12
Ninja:
The total spec range was .002"
You've got great advice and questions up above.
FWIW, I make a slightly compressible material that (sometimes) has a spec range that large (+/- 25um = +/- 0.001")...usually it's smaller (+/- 5um)
I have thrown out all of our micrometers after they failed trial after trial. Micrometers were simply not up to the job for a spec range as tight as 0.002".
While you are considering the questions and suggestions above (and posting data so we can look into it further), you may also want to start considering what other tools might be used for this measurement.
Micrometers reading in inches typically have a resolution of 0.0001". That gives you only 21 discrete values in spec. While this can work, you might be better off with a gage with higher resolution (and equivalent or better accuracy).
My product is flexible and can be laid flat...so I use a vertical drop gage now with resolution to 1um and accuracy of 1um. Passed GRR with flying colors (%GRR = 0.6 on a spec range of 50um). For X-Y measurements I use a CMM.
All the same, if you are measuring machined metal (not really compressible) ...micrometers may be appropriate.
HTH,
5
57jeeper
#13
Good morning all,
Thanks for all the advice.
Would someone have a list or site with standard expect gauge RR values with total tolerance from .0005" to .005" for 0-1" micrometers, comparators (25x), 0-1" blade micrometer, vision system (flash 5000) and CMM?
The gauge RR was performed with a 0-1" micrometer to match the customer's inspection method. I'm trying to avoid using a CMM or vision system due to the lack of resources and time compared to a mic.
The ten parts used were from a 30 piece lot, and had little variation and didn't cover the .002 total tolerance.
I attached a copy of the data. Using your suggestions I could get the gauge RR under 10% thanks.
Also I attached a copy of a second gauge RR performed on a CMM with a total tolerance of .001". 3 operators, 10 parts (same lot) 3 trails. The parts were removed from the fixture and reloaded. Total gauge RR %tolerance was 19.72 and I don't think I can get it under 10%.
At what point is the total tolerance too tight that getting under 10% not realistic?
shorttimeQE
#14
What do you do when you cannot get parts that are "bad", out of the upper and lower tolerance zones?
Roscoe Splevins
#17
Open Question on R&R results.
Please consider my comments below. My interpretation of the results may be flawed. Normally we use an X-R method to calculate R&R. ANOVA adds interaction calculations I cannot beging to calculate (or appreciate).
Your results have two (2) distinct categories. That may indicate very good consistancy in parts OR insufficienct distrimination. You've measured to 4 decimial places so there should be sufficient discrimination for justification of the instrument used. But may be going to the fifth decimal may be needed.
Looking at the 16.42% and the formula (SV/Toler); That tells me your gage error is 16.42% of your tolerance. Would that give 46.46% as GRR? Repeating the same set of calculations without entering the 0.002" tolerance into the MiniTab set-up yeilds a similar set of calculations but with % Study Var as end result. Is this not your GRR?
Try the same MiniTab set-up but with the X-R method and compare results.
The AIAG has a book to explain all this. I don't have it and the company won't spend the 150.00 to buy it. I'd like to compare my interpretation of the MiniTab explanation to my observations.
M What is a reasonable MDSAP cost? ISO 13485:2016 - Medical Device Quality Management Systems 9
S Scheduling a Crisis Management Audit? Reasonable Request? Internal Auditing 2
D What is a reasonable consulting fee for preparation of a complete traditional 510k? Consultants and Consulting 11
C What is a reasonable level of QA Editorial Control? Quality Manager and Management Related Issues 20
A CAPA - Reasonable Timeframes for Effectiveness Evaluation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
N What is a ?Reasonable? failure rate for an electronic device in the 1st year? Quality Tools, Improvement and Analysis 7
S What is a reasonable Bioburden limit? ISO 13485:2016 - Medical Device Quality Management Systems 13
S Packaging Specification template and Reasonable dppm target for printed material? Document Control Systems, Procedures, Forms and Templates 1
F Travel Expenses for Assessors - Registrar states we pay "reasonable travel expenses" Registrars and Notified Bodies 27
Hershal Cutoff - Discussion regarding a reasonable break-even point for calibration General Measurement Device and Calibration Topics 3
G Reasonable time for ISO 9001:2000 implementation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Icy Mountain Reasonable calibration? 50 foot measuring tape and other basic M&TE General Measurement Device and Calibration Topics 25
M Six Sigma - Where to get a 'reasonable' certification? Training - Internal, External, Online and Distance Learning 3
D What is a reasonable time frame for a system to be 'mature enough' to audit? Miscellaneous Environmental Standards and EMS Related Discussions 11
F Definition Reasonable - Defining a Reasonable Amount of Time Close Out CPAR's Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
A Cg, Cgk and GRR of a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
J Question on very low NDC number with tolerable GRR ratio's Capability, Accuracy and Stability - Processes, Machines, etc. 7
C Evaluating GRR Scores %Tol vs %TV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S GRR on ID with set of pin gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q What does % study variation of 20% mean in GRR? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
C %GRR <10% not possible. How to get approval by auditor? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
V GRR Study on a Finished Product - Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Hypothesis test for Bias, not for GRR. WHY ?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Calculating part variation from historic data for GRR study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S GRR (Gage Repeatability and Reproducibility) for Material Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P New Part - How to choose what needs GRR (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K The basics of GRR (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Need MSA %GRR Interpretation Advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M GRR approach for off line Measuring Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Does anyone have the GRR Formula? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T MSA - Should I compare my GRR to tolerance or to my sample? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
D What the impact is of a high %GRR/TV Capability, Accuracy and Stability - Processes, Machines, etc. 6
V Sample Range for a valid GRR using ANOVA in Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
F GRR (Gage R&R) with Different Scales Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
R New to MSA - I was told to use ANOVA for the GRR's Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Type 1 GRR (Gage R&R) on a One Sided Specification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Analysis of GRR studies, MSA 4th Ed, Chapter III section B - Rigid Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Strange PT Ratio on an Excel spreadsheet for variable GRR ANOVA Method Excel .xls Spreadsheet Templates and Tools 2
A Customer Demands (MSA=Bias + GRR/2). Can somebody explain what it means? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R ndc=0 and GRR=14% ??? Interpretation - basic question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I Minitab ANOVA Gage R&R Error (vs. EXCEL ANOVA GRR Calculation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R MSA - GRR (Gage R&R) Requirement for CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
Rameshwar25 What is the significance of Spread in Calculating GRR (Gage R&R)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
