Received a minor for not having good measureables/goals. Need help with KPIs.
AMIT BALLAL
#21
First thing... an medium sized organization may have over 200 processes. And sometimes they can have subprocesses, themselves, depending on the granularity of the mapping. And also sometimes those processes can be grouped into macro processes.
ISO is not very clear on the level of granularity you should map and control your processes. Maybe you should map them "on the basis of what is best for the organization and stakeholders to understand it".
that said, macro processes are difficult to do KPIs because they involve too much things... too many outputs. They are just processes agglomerations. ALMOST (but not exactly) departments.
But 200 processes are just impossible to measure, despite the whole PDCA cycle being almost like a core thing at ISO.
Some stuff are almost impossible to measure without too much bureaucracy and lost time compared to the GAIN of measuring it's output.
KPI's should be required based on the strategic planning of the organization, as well individual processes objectives, some coming from risk analysis, some objectives coming from some CAR or PAR, etc.
Plus some for the processes in the chain that outputs for the client.
But creating KPIs (and then collecting, calculating and analyzing the data) for 200 processes? How many bills has the treasury delayed? How many invoices has the accounting processed on time?
It gets worse when you discover that some of those KPIs are always perfect... so they are even more useless. And time-wasting.
200+ processes? Not possible. You might be including individual activities as a process. I never came across more than 15 processes.
Can you give example of what processes you've included?
rogerpenna
#22
an activity is atomic.
any medium sized company will have at least 5, probably up to 10 departments. Are you telling me whole departments will have at most 2 processes?
that is VERY LOW granularity during process mapping, more likely a macro process.
Just the Quality Department of my company has several processes which it is responsible for (most of them quite cross departamental, of course)
- Risk Management (includes sub processes Risk Discovery, Risk Analysis, Risk Monitoring, Risk Re-Assessment)
- Internal Audit Management (includes sub processes Audit Planning, Auditor Evaluation, Audit Execution, Audit Result Meeting)
- Change Management
- Opportunity for Improvement
Activity
Processes can be sub-divided into smaller and smaller units or sub-processes. We define activity as the smallest sub-process that a given business process team decides to illustrate on their process diagrams. (We could reverse that and say that a process is made up of one or more activities.) Activities can consist of a single step, like approving a purchase request or placing a cap on a bottle passing on a production line. Other activities involve multiple steps, like filling out a form, or assembling a chair. There is no consistency about how the various methodologies use terms like task and step, but, increasingly, the term activity is reserved for the smallest unit of analysis. A given activity could be performed by one or more employees, by a software system, or by some combination
Process
A set of activities and transactions that an organization conducts on a regular basis in order to achieve its objectives. It can be simple (i.e. order fulfillment) or complex (i.e. new product development), short-running (i.e. employee on-boarding) or long-running (i.e. regulatory compliance), function-specific (i.e. proposal management) or industry-specific (i.e. energy procurement). It can exist within a single department (i.e. billing), run throughout the entire enterprise (i.e. strategic sourcing), or extend across the whole value chain (i.e. supply chain management).
appian.com/bpmbasics/bpm-glossary/
Look at the example of process in that definition. New Product Development, Employee On-Boarding, Regulatory Compliance, Proposal Management, Energy Procurement, Billion, Strategic Sourcing, Supply Chain Management.
Any department of a medium company will have a dozen processes, some even more.
here, several definitions of process and activities (
businessprocessglossary.com/9121/process
businessprocessglossary.com/7779/sub-processes
businessprocessglossary.com/13598/activity
businessprocessglossary.com/13341/atomic-activity
Let's not overdo it however. (but this also proves that companies have TONS of processes)
https://www.mckinsey.com/~/media/Mc...DFs/Getting_ruthless_with_your_processes.ashx
at page 2 of the PDF above, it's said a specific oil company had 30 processes for the simple act of folding a seat on an oil rig.
obviously, that is quite ridiculous and bad process mapping.
But even if we reduce those 30 to 1, we still have a process to fold seats on an oil rig.
AMIT BALLAL
#23
- Change Management
Activity
Process
Of course, you can identify as number of processes as you want. But no need to complicate things.
The term "Department" is not being used anywhere in IATF / any QMS standard. The departmental approach is obsolete and went a long time back. And instead, the process approach is being used, since things don't work in silos as we all are aware. Processes are dependent on another process in order to produce desired result. And interaction is where problems occur most of the time.
That is the reason to identify process (Instead of departments) and determine the interaction between these processes. In order to determine interaction, subprocesses need to be determined eg. "Calibration management" is a subprocess of "Quality control & assurance" process because the higher level of process won't directly interact with other process but its subprocess will.
And measurables / KPIs will be defined on these higher level of processes. Eg. for Quality control & assurance process.
Now it is up to you whether you want to simplify or complicate things. Both ways system will conform to the requirements of IATF16949 / ISO9001 standard. Keep in mind, we are not developing a system just to comply with the requirements of a particular standard, but so that it can benefit the organization and help achieve a particular objective.
If you make a system that is difficult to understand and follow, it will not be followed and ultimately it will fail.
qualprod
#24
Putting objectives to all these things is NOT what the standard requires. Frankly, putting objectives to things like management review, document control and other is a waste of time. I'd go back and look at the business and what those objectives are. Wasting time on measurable for records, documents, internal audits etc is not going to garner support from management.
Andyn
I think What they relate to, is to use such kpi for the monitoring of the objective goal. These kpis help to evaluate how the objective is running.
But shuch tasks are not the objective.
Hope is explained well.
rogerpenna
#25
From a BPM perspective, it is not.
The number of processes is at it is. Calling it a subprocess or a process won´t change the complexity of the system, the only thing you are doing is making it easier to escape the auditor asking for KPIs for every process.
a quote from "Fundamentals of BPM"
"The question is whether an overly coarse-grained view on processes, without any further subdivision, is useful for an organization that strives to become processcentered. Remember that the idea of process management is to actively manage business processes in the pursuit of satisfying its specific customers. If one selects business processes to be such large entities, then the result may be that these cannot be easily managed separately, both in terms of scope and speed of action. Consider, for example, how difficult it would be to model or redesign a process when it covers half of all the operations within an organization. A realistic model of such a business process would take a very long time to develop and could become extremely complex. Also, redesigning such a large process would be a time-consuming affair, let alone the implementation of such a redesign. Depending on the situation, an organization may not have that time "
Even outside of BPM, a Process definition is usually that a Process transforms an input into an output.
when you have such coarse granularity, you will have MULTIPLE inputs and outputs., thus not really a process.
I agree with you that showing a high granularity from the start is complicated. Too much info.
Which is why BPM is not about modelling everything at once. It's a whole method of prioritizing, modelling the AS-IS, analyzing, simulating, testing TO-BE to created improvements on processes... and again... PRIORITIZATION of processes. According to the Value Chain. According to ROI.
Which is the whole point of this thread... having KPIs for every process? That's nonsense. There is no need to it. The cost of having KPIs to every process is too high, too little return.
Either ISO is wrong about requiring all processes to be measured, or ISO is wrong about the nature of processes (if it really considers such macro processes as "processes") or we are wrong about what ISO asks.
One should create KPIs to be able reach objectives, from Quality or from Strategic Planning...
or for specific processes that were targeted as important for the value chain and that need to be improved.
AMIT BALLAL
#26
No one here is trying to escape from having KPIs for every process whether for high-level processes or subprocesses. And IATF16949 doesn't require to have KPIs for every process. It depends on the organization and its context to determine whether a KPI is required. And IATF16949 doesn't even use the word "KPI", instead, it uses "Effectiveness and efficiency measures".
The objective of IATF16949 and BPM are different. Although BPM tools can be integrated into IATF16949 based QMS, let's not forget we are discussing IATF16949 here.
I would like to ask whether your organization is IATF16949 certified? And have you specified 200 processes in your list of processes and do you internally audit 200 processes? Of course, your process map can include 200+ processes, but I am not asking about the process map.
rogerpenna
#27
well, the thread started along those lines, on discussion about if all processes needed kpis, etc.
no, we do not audit 200 processes.
we do not have that much, but we certainly have more than 15 (which you talked as the biggest number you ever saw in any company).
we do not audit all of our processes. Of course not. It would make no sense. Just as we do not create KPIs for every process.
AMIT BALLAL
#28
Of course, your organization can have number of processes based on its size, complexity, operations, etc. factors.
Sebastian
#29
CQI-16 says generally up to 10 Customer Oriented Processes might be observed in every company.
In my opinion we need to add 6 more and that's all.
I don't see any reason to go beyond that number.
If someone struggles with identification of KPI for process, there are two options.
One - look for another job.
Two - it is not worth of managing it as high level process.
P
patricks
#30
"Top Management shall ensure that quality objectives to meet customer requirements are defined, established and maintained for relevant functions, processes and levels throughout the Organization. "
So I recieved a minor on this clause. I need to get some measureables & goals together for out processes. So far, I have:
Training - Goal of 2 employees crosstrained in other areas outside of their day to day duties per year.
Manufacturing - Goal of Cost of poor quality not to exceed $3,000 per year.
Quality Planning/Safety - Goal of 0 safety incidents per year.
Quoting - Goal of 0 RFQ's not being processed within 3 days of recieving them.
Process Design - Goal of $3,000 in savings from process design improvements per year.
Shipping - Goal of 100% on time delivery (not sure if this is even atainiable)
Outsource Process - Goal of 0 supplier defects per year.
Now, Im stuck on the following:
Corrective & Preventitive action
Doc & Record control
Internal Auditing
Management review
Receiving
Purchasing
Maintenance
Calibration
Any ideas of what I could track for those? We are a small (less than 50 employees) prototype shop that does 3 & 5 axis laser, machining, and welding.
Corrective & Preventative action KPIs: Time to closure (Ideally < 14 days), Number of (trending down), Recurrence (%)
Internal Auditing: Percentage completion, Frequency, Time to closure (days) for mitigations
Management review:
Frequency, Objectives (i.e. what is discussed in management review? Answer: All these KPIs)
Maintenance KPIs:
Uptime (% or hours), Unscheduled maintenance (hours), Percentage completion of scheduled maintenance, Critical parts inventory
Calibration KPIs: Some sort of calibration tracking method i.e. spreadsheet or a software. Evidence of MSA during PPAP and periodically.
E Supplier PPAP - Section 7.3.6.3. - Our company received a minor - Help IATF 16949 - Automotive Quality Systems Standard 7
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
V Quality review Meeting with Customer for complaints we received Customer Complaints 6
Ed Panek Corona Virus impact on Supplier Audits and Received Parts ISO 13485:2016 - Medical Device Quality Management Systems 4
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
M Informational TGA – Submissions received: Regulation of software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 1
CPhelan Nonconformance opened as incorrect expiration date placed on received product. Escalate to CAPA? Nonconformance and Corrective Action 4
M We still have not received our certificate due to a 'backlog' with our auditing body Registrars and Notified Bodies 25
K Internal Audit CAR - How Long for Responses to be Received? Internal Auditing 8
W AS9100 (8.5.1 j) - Missing Parts when received back from External Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
L Supplier Revision Confirmation of Received Engineering Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Help with SCAR - Not all sub-assemblies had properly received a First Article Nonconformance and Corrective Action 2
Y Part 21-G organization - Compliance documents of received product Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
V Pre-dispensed API material received in predetermined quantities & given to production Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
K APQP requirement when a new print or spec is received from a customer - Existing Part APQP and PPAP 3
Q Recommendation for a suitable PA on a complaint received Preventive Action and Continuous Improvement 3
marmotte 510(k) "received date" discrepancy Other US Medical Device Regulations 1
R Is IMDS required for Shipping cap received from our suppliers RoHS, REACH, ELV, IMDS and Restricted Substances 7
M Should we analyse risk at the quotation phase or after the order is received? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Q Receiving Inspection - Quantity Received different from Pack List & C of C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Corrective Action - Customer Received Mislabeled Parts Nonconformance and Corrective Action 6
D We received our AS9100 Rev C. certificate! Thank you! AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Hershal This morning I received notification that I have my third copyright Coffee Break and Water Cooler Discussions 11
J Internal Audit Reports - Is it acceptable if received after due date? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Received 510K Market Approval - Use in Advertising US Food and Drug Administration (FDA) 5
M "As Found" (aka "As Received") Calibration Data - ISO 13485 Requirements ISO 13485:2016 - Medical Device Quality Management Systems 8
C Contaminated Sharp Medical Devices received by mail - Biohazard? Other Medical Device and Orthopedic Related Topics 2
K Ts-16949 certification received! IATF 16949 - Automotive Quality Systems Standard 8
Ajit Basrur Laboratory Monthly Report template needed (samples received, samples tested, etc.) General Measurement Device and Calibration Topics 2
R On/OFF switch received from supplier - No CE marking but with Certificate CE Marking (Conformité Européene) / CB Scheme 1
Stijloor Consultants, have you received calls from Registrars lately? Registrars and Notified Bodies 9
J Received TS 16949 Certification Today! IATF 16949 - Automotive Quality Systems Standard 19
C Notice Received from Customer Regarding PPAP's & FAIR's APQP and PPAP 8
C (DDR) Delivery Discrepancy Report received from customer for late delivery Nonconformance and Corrective Action 3
R UL Requirements - Received a variation notice - Safety caution text Various Other Specifications, Standards, and related Requirements 3
P I Received an AQL questionnaire from a customer - Comments? AQL - Acceptable Quality Level 3
L ISO 9001-2000 Registered - We received our ISO 9001:2000 certificate yesterday ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
S Purchasing Procedure - Purchasing process is not complete until product is received? IATF 16949 - Automotive Quality Systems Standard 11
L Registrar Quotes - Quality of Responses Received - Discussion Registrars and Notified Bodies 29
R Has anyone received the ASQ publication of the DIS for ISO9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Is it possible to control Customer Drawings (Prints) by a "Received" Date Stamp? QS-9000 - American Automotive Manufacturers Standard 16
M IEC 62304 Software changes - Minor labeling changes on the GUI IEC 62304 - Medical Device Software Life Cycle Processes 3
M Major vs. Minor for Internal Audits? Internal Auditing 10
C Fact or fiction - Repeat minor becomes a major IATF non-conformance IATF 16949 - Automotive Quality Systems Standard 7
Q ISO 14001:2015 accredited but import most product - CB Raised minor NC on Life Cycle Perspective ISO 14001:2015 Specific Discussions 2
G Timing allowed by IATF to close a Remote Site Minor Nonconformance IATF 16949 - Automotive Quality Systems Standard 2
J EU ISO 13485:2016 Recertification Audit - Effect of 10 Minor Nonconformances EU Medical Device Regulations 2
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 12
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
D Minor non-conformance for not receiving a CofC from a heat treater Manufacturing and Related Processes 10
