Received a minor for not having good measureables/goals. Need help with KPIs.
qualprod
#41
That's just it. How many metrics have a reaction point? If it's just measurement for measurement sake, then there isn't much value. We measure shipment performance. What's the difference between 97 and 98%? Not much. If it drops to 85%, I'll guarantee I'll know about it before the data is collected -- customer lines will shut down and they know where I live. :)
For this issue, I defined that according my kpi results, I take actions, for example: if my goal is 90%, then I defined ranges, if results fell from 87 to 89.9,do nothing, just to monitor the process, if fell from 85 to 88.9,apply correction or contention action, if value is under 85, an obligated corrective action is a must,also use colors, green, yellow and red in my scoreboard.
Johnnymo62
Haste Makes Waste
#42
Section 4.4.1.g: evaluate these processes and implement any changes needed to ensure that these processes achieve their intended results;
We are required to react to KPIs not meeting their goals.
RoxaneB
#43
Being required to react is not quite the same as truly wanting, needing to react. When the response is genuinely wanted, it demonstrates that people care about the process and see the value in the system beyond the piece of paper on the wall.
RoxaneB
#44
How were these ranges selected?
What if they have several consecutive yellows?
Johnnymo62
Haste Makes Waste
#45
I agree with your comments. I just want to point out that to ignore a KPI dropping lower is a risk for an audit nonconformance.
#47
It all depends on how "intended results" is defined. If you use process indicators to paint yourself into a corner, expect the inevitable.
Mikey324
#48
If a kpi drops below the target level, and meaningful kpi was selected, there should should be a want from those interested to make an adjustment. If an audit minor is the biggest concern, the kpi may not be that valuable at the end of the day.
Golfman25
#49
This is the age old question. Do we pick real metrics to monitor and use them to drive improvement or do we just set a target we can hit to avoid a non-conformance. The problem comes in with the "we are required to react" mentality. Auditors drive this, so people pick easy "goals" so they aren't bogged down trying prove to an auditor they are doing something.
My business metrics create lots of wipsaws. If we reacted to every one we would go insane. One, even two, points doesn't make a trend. We have to smooth everything out to be meaningful. If my delivery goes from 98 to 95% because we had a tooling issue created by a 50 year old tool the customer doesn't want to invest money in, I'm not going to go all root cause/corrective action as it is a waste of time. If an auditor wants to issue a NC because of it, they'll get significant push back from me.
#50
I agree completely with Golfman25. There should not necessarily be a "want" to make an adjustment. There should be a need to investigate both the impact of missing the target and whether or not the target is reasonable and necessary. It's possible to establish a "meaningful" indicator and an unreasonable target for it.
E Supplier PPAP - Section 7.3.6.3. - Our company received a minor - Help IATF 16949 - Automotive Quality Systems Standard 7
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
V Quality review Meeting with Customer for complaints we received Customer Complaints 6
Ed Panek Corona Virus impact on Supplier Audits and Received Parts ISO 13485:2016 - Medical Device Quality Management Systems 4
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
M Informational TGA – Submissions received: Regulation of software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 1
CPhelan Nonconformance opened as incorrect expiration date placed on received product. Escalate to CAPA? Nonconformance and Corrective Action 4
M We still have not received our certificate due to a 'backlog' with our auditing body Registrars and Notified Bodies 25
K Internal Audit CAR - How Long for Responses to be Received? Internal Auditing 8
W AS9100 (8.5.1 j) - Missing Parts when received back from External Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
L Supplier Revision Confirmation of Received Engineering Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Help with SCAR - Not all sub-assemblies had properly received a First Article Nonconformance and Corrective Action 2
Y Part 21-G organization - Compliance documents of received product Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
V Pre-dispensed API material received in predetermined quantities & given to production Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
K APQP requirement when a new print or spec is received from a customer - Existing Part APQP and PPAP 3
Q Recommendation for a suitable PA on a complaint received Preventive Action and Continuous Improvement 3
marmotte 510(k) "received date" discrepancy Other US Medical Device Regulations 1
R Is IMDS required for Shipping cap received from our suppliers RoHS, REACH, ELV, IMDS and Restricted Substances 7
M Should we analyse risk at the quotation phase or after the order is received? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Q Receiving Inspection - Quantity Received different from Pack List & C of C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Corrective Action - Customer Received Mislabeled Parts Nonconformance and Corrective Action 6
D We received our AS9100 Rev C. certificate! Thank you! AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Hershal This morning I received notification that I have my third copyright Coffee Break and Water Cooler Discussions 11
J Internal Audit Reports - Is it acceptable if received after due date? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Received 510K Market Approval - Use in Advertising US Food and Drug Administration (FDA) 5
M "As Found" (aka "As Received") Calibration Data - ISO 13485 Requirements ISO 13485:2016 - Medical Device Quality Management Systems 8
C Contaminated Sharp Medical Devices received by mail - Biohazard? Other Medical Device and Orthopedic Related Topics 2
K Ts-16949 certification received! IATF 16949 - Automotive Quality Systems Standard 8
Ajit Basrur Laboratory Monthly Report template needed (samples received, samples tested, etc.) General Measurement Device and Calibration Topics 2
R On/OFF switch received from supplier - No CE marking but with Certificate CE Marking (Conformité Européene) / CB Scheme 1
Stijloor Consultants, have you received calls from Registrars lately? Registrars and Notified Bodies 9
J Received TS 16949 Certification Today! IATF 16949 - Automotive Quality Systems Standard 19
C Notice Received from Customer Regarding PPAP's & FAIR's APQP and PPAP 8
C (DDR) Delivery Discrepancy Report received from customer for late delivery Nonconformance and Corrective Action 3
R UL Requirements - Received a variation notice - Safety caution text Various Other Specifications, Standards, and related Requirements 3
P I Received an AQL questionnaire from a customer - Comments? AQL - Acceptable Quality Level 3
L ISO 9001-2000 Registered - We received our ISO 9001:2000 certificate yesterday ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
S Purchasing Procedure - Purchasing process is not complete until product is received? IATF 16949 - Automotive Quality Systems Standard 11
L Registrar Quotes - Quality of Responses Received - Discussion Registrars and Notified Bodies 29
R Has anyone received the ASQ publication of the DIS for ISO9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Is it possible to control Customer Drawings (Prints) by a "Received" Date Stamp? QS-9000 - American Automotive Manufacturers Standard 16
M IEC 62304 Software changes - Minor labeling changes on the GUI IEC 62304 - Medical Device Software Life Cycle Processes 3
M Major vs. Minor for Internal Audits? Internal Auditing 10
C Fact or fiction - Repeat minor becomes a major IATF non-conformance IATF 16949 - Automotive Quality Systems Standard 7
Q ISO 14001:2015 accredited but import most product - CB Raised minor NC on Life Cycle Perspective ISO 14001:2015 Specific Discussions 2
G Timing allowed by IATF to close a Remote Site Minor Nonconformance IATF 16949 - Automotive Quality Systems Standard 2
J EU ISO 13485:2016 Recertification Audit - Effect of 10 Minor Nonconformances EU Medical Device Regulations 2
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 12
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
D Minor non-conformance for not receiving a CofC from a heat treater Manufacturing and Related Processes 10
