Receiving inspection and Internal Audit schedule
Jason PCSwitches
#11
...don't forget what's effective, Ron. They may have written down dumb stuff and be doing it, all in the name of 'ISO' so be sure to audit the process for RESULTS!
Spot on - Spot on.
You may have a well documented procedure, but if that procedure is not effective than all you have is a poorly written document.
Audit the process, not the paper!!
bill6
#13
Jason and Andy you correct. You got me thinking. i checked the standard it dose not say to cover them all. So i check my companies QM and it say "All elements of the quality system are audited regularly (as a minimun annually)" .... So, thank you for the observation. i am thinking now that my company is tieing itself to somthing we really dont want or need. We do alot of our work for the military and i will check our contrat or SOW maybe its required there. Thanks again, and i will be more carefull with my my words next time.
Ron Tollett
#14
Correct me if I am wrong, but typically the procedure has been written by the department who performs the day to day functions. We then take the procedure and make a checklist based on the written procedure, and take questions from the procedure. Is this not auditing the process? Hope this makes sense.
#15
I tell folks that this is a good starting point. However, to get the maximum out of an audit, you need to look at more than just if they are following their process. I recommend you look at process input, outputs, metrics and any contols not found in the procedure (errorproofing, safety, etc.) The object for internal audits should be less about conformance, and more about improvement.
Jason PCSwitches
#16
In part. However you are then just auditing a procedure, not a process. The procedure, important as it may be, should serve as a guideline so that the process flow is outlined. In order to audit a process you need to review the associated procedures and be somewhat familiar with the actual process. A checklist is also a guide and should serve as such. You can ask specific, text book questions and get the right answers but still have an ineffective process/audit. The point of an internal audit is to not just ensure compliance it's to ensure effectiveness. That is what should be focused on. It's also what adds value.
#17
Basically, Ron. As Dave says there's a lot more to it than that, if you are to determine if the process is effective. For example, if we take Purchasing, I always audited to see how many purchase reqs sat on the buyers desk because they weren't filled out with the correct minimum information, causing delays in placing the PO etc while the buyer had to 'sort them out' (not their job, obviously).
If the process was effective, the buyer should be able to pick up the req and place an order (well, pretty much). Instead, the percentage of 'right first time buys' is often low, although they do 'follow the process', they also cause problems. This is often because the people who write the purchase reqs don't know how much info is needed, because the procedure etc doesn't tell them (the standard says 'criteria' - under 4.1 c)
Stijloor
#19
Re: inspection and Internal Audit schedule
Is this a requirement or a good practice?
Not a requirement. Good practice? It depends. The standard states that audits must be planned taking into consideration the status and importance of the processes as well as the results of previous audits. In short: "risky" processes are audited at a higher frequency. Processes that are very mature and effective are audited at a lower frequency. Be smart with your audit process and its resources. :yes:
Stijloor.
K
keres
#20
I know that and agree :) I've just asked Bill6 to explain from where knows that.
R Internal Subcontractor Certification Program - Eliminate Receiving Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
I Receiving Inspection Requirement in IATF IATF 16949 - Automotive Quality Systems Standard 3
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
V Receiving Inspection AQL - Am I allowed to just pick a AQL? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
J Receiving Inspection for Metal Strips & Wires Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Objectives for Receiving Inspection (Resources) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Hardware Receiving Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
N Receiving Inspection - Who should receive raw material Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
kedarg6500 Use of safety glasses at receiving inspection Occupational Health & Safety Management Standards 7
L How do you specify your receiving inspection parameters? Misc. Quality Assurance and Business Systems Related Topics 2
D Receiving Inspection Training Materials Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S So Annoyed with Receiving Inspection! Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
R Minimum Essential Receiving Inspection (M.E.R.I.) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M Definition Receiving Inspection of Parts, finished products, service parts etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
kedarg6500 Receiving Inspection Documentation Best Practices Supplier Quality Assurance and other Supplier Issues 2
L Must we do Receiving Inspection for everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
M Does 21 CFR 820.80 (b) require a Supplier to have Receiving Inspection? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
M Calculating Adequate Receiving Inspection Sample Size Statistical Analysis Tools, Techniques and SPC 2
L How to define R & D Receiving (Incoming) Inspection Plan Design and Development of Products and Processes 18
M Receiving Inspection of Customer Owner Property IATF 16949 - Automotive Quality Systems Standard 5
M Partial Incoming (Receiving) Inspection Delivery Inspection. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
alonFAI Establishing a Receiving Inspection Procedure Document Control Systems, Procedures, Forms and Templates 5
S Ensuring Print Dimensions are in Control Plans, WI's and Receiving Inspection Document Control Systems, Procedures, Forms and Templates 3
S How to calculate Supplier PPM at Receiving Inspection Document Control Systems, Procedures, Forms and Templates 2
C Supplier Management and Receiving Inspection Improvement Statistical Analysis Tools, Techniques and SPC 20
Q Receiving Inspection - Quantity Received different from Pack List & C of C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C Receiving Raw Materials, Inspection, Release Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
G Reduced Receiving Inspection - Now What Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
M Incoming (Receiving) Inspection Procedure - Please Review Supplier Quality Assurance and other Supplier Issues 7
P Random Sampling at Receiving Inspection: A Practical Implementation needed Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
M How to Eliminate Receiving Inspection Supplier Quality Assurance and other Supplier Issues 10
A Receiving Inspection - One drum leaks - Should entire lot be rejected? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
V Measurement Reports for Receiving Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
K Incoming (Receiving) Inspection for Commodity Items used in Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 11
S Inspection Forms - Receiving Inspection on Buses that will get Refurbished Document Control Systems, Procedures, Forms and Templates 7
C Medical Device On The Floor Receiving (Incoming) Quality Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
I Medical Device Receiving Inspection AQL AQL - Acceptable Quality Level 5
T How do I Reduce Frequency of Receiving Inspection Testing for Quality Control Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P How you do Receiving Inspection for Chemicals? Supplier Quality Assurance and other Supplier Issues 9
E Measuring Receiving Inspection Process Effectiveness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
T Is 'Supplier Part Batch' a Root Cause - No Receiving Inspection Problem Solving, Root Cause Fault and Failure Analysis 11
U What Legal Documentation is required for Receiving Inspection of Parts Federal Aviation Administration (FAA) Standards and Requirements 1
T Should the pFMEA start with Receiving Inspection? FMEA and Control Plans 18
S How to maintain 0 Rejections for Quality Receiving Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Is Material Certification Required for Incoming Material (Receiving) Inspection? Supplier Quality Assurance and other Supplier Issues 10
N How to apply Incoming (Receiving) Inspection to Customer Supplied Material? IATF 16949 - Automotive Quality Systems Standard 18
L Critical Characteristics in Incoming (Receiving) Inspection - Inspection Levels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
P Implement FAI process in my Incoming (Receiving) Inspection Procedure ISO 13485:2016 - Medical Device Quality Management Systems 6
