Rechargeable Battery in Medical Device - Controling and Maintaining Batteries
Arie0712 - 2010
Hi
Our company is about to add rechargeable battery to the device configuration. We did not need to deal with this isuue before...
What recommendations do you have for controling and maintaining batteries in device (when still in the warehouse) and those which are intend to serve as spare parts.
Thanks, Arie
SteveK
Re: Rechargeable battery in medical device
Arie,
I think you had better contact your battery supplier for advice. How batteries behave depends on the type e.g. lead acid, lithium, metal hydride etc (which is yours?). One thing is for sure, you do not want them (regardless of type) to fully discharge for what ever reason – which could happen in prolonged storage with exposure to high temperatures etc. I do not know whether this helps, but we supply a medical device with rechargeable batteries (Nickel Hydride) – though not specifically as spares (though they can be). Before the battery is placed in the device and shipped out, we run it through 5 charge/discharge (not fully) cycles then fully charge it (using an e-Station BC8 unit, which is suitable for all battery types). This ‘conditions’ the battery prior to use.:2cents:
Steve
Arie0712 - 2010
Thanks, Steve
We're going to use lead acid batteries.
I realize that the first step should be keeping the batteries out of the devices in stock and maintain them until they need to be assembled to the device (for shipment).
As it seems, we should establish maintenance procedure which will include treatment when in stock and treatment before getting into the device for shipment.
Best Regards, Arie
medic61
There are shipping regulations for batteries as well. I have attached a recent document I was reading and I know it does not pertain to the lead batteries you will use but perhaps you can find some references in it as a starting point.
I know the TSA at our airport has regulations on batteries going by plane.
Good luck, sorry I don't have more info.
Medic
S Rechargeable NiMH Battery Life in Medical Devices - Replacement Intervals Other Medical Device and Orthopedic Related Topics 2
N Nickel Metal Hydride Rechargeable Battery Service Life - IEC 61436 ISO 13485:2016 - Medical Device Quality Management Systems 3
M UDI - Rechargeable Batteries and Charger Other US Medical Device Regulations 5
M Advice for choosing Rechargeable Lithium Batteries to be used in a Medical Device Other Medical Device Related Standards 16
R Is reversed charging protection necessary for Rechargeable Batteries IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
L EN 62368 (In an Annex - M.4.2.1) Secondary Lithium Battery Charging Safeguards CE Marking (Conformité Européene) / CB Scheme 2
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q EU Rep for Packaging waste, WEEE and Battery disposal CE Marking (Conformité Européene) / CB Scheme 0
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 11
B Need For BIS Standard Mark? Imported OEM's Power supply,Li-Ion Battery Other Medical Device Regulations World-Wide 0
T Battery Powered Device - MOP and Patient Auxiliary Currents IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
F IEC 62133 cell vs. Battery Pack - Certification on the cell only IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E IEC 60335-1 li-ion battery requirements Other ISO and International Standards and European Regulations 0
E CB scheme applicability for battery powered medical devices CE Marking (Conformité Européene) / CB Scheme 0
F MOPP in battery powered device with metal enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G Assembly of cells into battery - Medical Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Leakage Current test and Dielectric strength for Battery operated ECG device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Battery Enclosure Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
C Lithium battery powered Medical Device - 15.3.3 Impact test, broken enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Classification of a device that uses an existing battery IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Dielectric Test of Battery Powered Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E Electrical safety (battery-powered medical device) EU Medical Device Regulations 1
L Battery requirements for medical device (US/Canada/EU) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Testing ME equipment powered by Battery EU Medical Device Regulations 0
K IEC 62133 Test Report for Lithium Battery Certification IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S IEC 60601 Main requirements for Lithium Ion Battery Powered Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M Testing a Low Current (Battery) DC Medical Device Other Medical Device Related Standards 4
M Battery Powered Measurement Equipment and Low Voltage Directive CE Marking (Conformité Européene) / CB Scheme 1
B Primary lithium battery protection and vented gas IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Measuring LiON Battery State of charge - Transporting batteries by Air RoHS, REACH, ELV, IMDS and Restricted Substances 1
W EMC, ESD for battery operated apparatus Other Medical Device and Orthopedic Related Topics 1
A IEC60601-1 - Battery Charger Requirement - Home Healthcare Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
F Ambulance Battery Isolation - IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M IEC 60601 Charger requirement for Lithium Ion Battery Powered Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 16
C Battery Powered Beauty Products minimum Legal Certifications Requirements CE Marking (Conformité Européene) / CB Scheme 7
E Requirements for primary battery powered ME with BF-applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E Requirements for Using Lithium battery instead of Alkaline IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
X IEC60601 Battery powered devices intended for measuring bio-impedance IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Is IEC 60601-1-2 compliance/testing required for battery powered Class I Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Demonstrating battery safety in 510(K) submission for the FDA Other US Medical Device Regulations 9
D Battery Powered Medical Device Battery Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B Flammability Ratings for Internal Battery & Hand-Held ME Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
thisby_ Medical Device Battery Powered Equipment connected to Charger IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
T Polymer Lithium Ion Battery and Ventilation Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
M IEC60601-1 Battery Powered Body Worn Device Leakage Currents IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M IEC 60601-1 testing for device with its own 2V battery power supply necessary? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T IEC 62133 Certified Battery Manufacturers Other Medical Device Related Standards 3
