Recomendations to build a complete quality management system - Documentation Way
O
oooomri
Friends,
:thanks: This is my first post. As start, I would like to thank all of you. I really like this site. It looks like i found something missed. I hope to add value to this cove.
Actually, we start documenting our processes to build a complete quality management system. We want to write applicable, understood and efficient processes.
I would like to know if there is standards or recommendations that can help to achieve this issue. If not I need your recommendations based on your experience.
Madfox
Starting point
Figure out how your organization works first!
Believe it or not, I start with an organizational chart!
apestate
documented, formalized management
ISO 9001:2000 is probably the most understood, common, and valuable quality management system standard.
The process approach and broad scope of ISO 9000 is what allows people to use this standard whether they are barely meeting the requirements, or blowing away the competition. I highly recommend ISO 9000 as a basis and suggest that this is the best starting point.
I really don't know what ELSE should be better suited. While there are other methods and forms, ISO 9000 is the documented, formalized management system that performs and is dynamic with the changes and needs of the company. The difference between ISO 9000 and TQM and Baldridge criteria and Six Sigma is that you can have your management system internationally recognized as up to the ISO 9000 standard, and this has sales clout.
Therefore, I suggest the following starting actions:
1. purchase a copy of the ISO 9000 standard from your country's standards body or quality association
2. obtain a quote for registration and auditing services IF that's what you want or need.
3. research, produce, and refine a map of the processes within your company and how these processes interact. use ISO 9000 guidance at www.iso.ch for guidance.
Wes Bucey
oooomri said:
Friends,
Welcome to the Cove!:bigwave:
I agree with the two previous posters to the extent
  1. You need to have a good idea of the "big picture" of your company (what do you do? who are your customers? what regulators and regulations do you have to face? Is there a special Quality Management System specifically for your industry? [there are special Standards for automotive, medical devices, communication equipment, aerospace, etc.])
  2. Current good practices for management systems suggest you consider "processes" (using flow charts is a good start to understanding the processes in an organization.)
Tell us more about your company and what you make and we can help you focus on what you really need to do first. I'm unfamiliar with the abbreviation KSA - what is your location?
Coury Ferguson
Moderator here to help
Wes Bucey said:
Welcome to the Cove!:big wave:
I agree with Wes. There is a little more information you need to properly develop a QMS (which ever Standard your Company chooses). The other posters also have provided you with a good starting point. ISO9001 is the most likely candidate that you may want to start with, but again it depends on the type of product or service your company provides.
I have designed and developed QMS from the ground up and all of this information was very important in developing the QMS.
Coury Ferguson
Madfox
ISO standard
I think the ISO standard is greatly MISunderstood, and poorly written for the layperson! Thus, I recommend to companies to get a self-generated, holistic view of the organization, then overlay ISO!
(Here's an example in support of the first statement above: I've reviewed hundreds of quote requests, and scores of applications, and you wouldn't believe how many organizations seek to exclude all of 7.5 'cause "we don't provide service after the sale!" That's not the org's fault, it's the wording! I've lobbied to have 7.5 title and verbage changed to simply "Production," and omit "Provision" and "Service.")
mshell
All of this advice is very good.
In addition, I would recommend documenting your current practice(have the operators, supervisors, managers, etc.. help), performing a gap analysis using the standard and adding anything that you are not already doing.
O
oooomri
Thanks to all of you. I think that several points should be clarified by me.
I am working in a telecom company consists of 25000 employee. The project will be implemented on one Admin.. which is consists of about 600 employee. In the other hand this is my research to get master's degree in TQM. This Admin contains the following departments: Planning - Design - Implementation - Operation & Maintenance - Quality Assurance.
I was looking to use something called eTOM since the organaization is a telecom based. If anyone of you have heard about eTOM, he might be able to help me. You can check this web for more info www.tmforum.org
eTOM aims to enhance telecommunication operations map. Actually, it is comply with ISO standard but it goes further to enhance the processes. I will upload an example just to show you how it looks like. This will be on the quality department in our Admin.
I need your opinion on this format.
Madfox: I totally agree with you regarding OG chart, but usually there are some politics which can not be eleminated.
Atetsade / Wes / Coury / Mshell : Thank you for your advice. I allready have a copy of ISO requirements, I can recite them, but ISO does not tell you how to document your system, which i am asking for.
Warm regards
NOTE: The formerly attached file - Support Quality Assurance-v0.1.xls - was removed as it would not open. Removed by Marc.
O
oooomri
Dear Wes, I forgot to tell you that KSA means Kingdom of Saudi Arabia. Thanks for asking.
Coury Ferguson
Warm regards
The first step in documenting is to flow your processes. The second is determine which are critical. Third, talk with the folks that perform the work, and document it. Fourth, determine the Quality Philosophy of your company. Fifth, set your objectives. Sixth, write the Quality Policy of your company. Seventh, document the procedures on how you do business. Eighth, prepare a draft QA Policy and Procedural Manual and send it through your management for review and recommendations. Ninth, prepare final draft and get signatures.
Tenth, train the Executive Management. Eleventh, train the employees. Twelfth, perform internal audits. Thirteenth, discuss your findings (if any) with the Executive Management. Fourteenth, implement proposed Corrective Action.
These steps are just the beginning, in my opinion, and there could more or less to implement.
Coury Ferguson
J Mechanical Press Machine Foundation Requirements and Recomendations Manufacturing and Related Processes 2
L Environmental Gas Leak Detection Equipment Recomendations Miscellaneous Environmental Standards and EMS Related Discussions 2
A SPC Software Recomendations wanted Quality Assurance and Compliance Software Tools and Solutions 4
M Visual 5S Lighting Systems Equipment Vendors - Recomendations please Lean in Manufacturing and Service Industries 3
B Car GPS Navigation Unit Recomendations Coffee Break and Water Cooler Discussions 24
K New Calibration Software Recomendations Calibration and Metrology Software and Hardware 6
B CMM Software Package? Looking for recomendations on PCDMIS CAD v3.7mr1 General Measurement Device and Calibration Topics 1
T QPD (Quality Policy Deployment) reading recomendations? Book, Video, Blog and Web Site Reviews and Recommendations 1
S Looking for Quality Content to Build Medical Device Curriculum - Concept to Commercialization Training - Internal, External, Online and Distance Learning 4
B IATF 16949 - Is a Deviation required for sample components in a prototype build? IATF 16949 - Automotive Quality Systems Standard 13
S World Quality Day 2019, November 14 - Build Quality Awareness in the organization ASQ - American Society for Quality 0
A How a test flow can be build for a car electronic sunroof control Reliability Analysis - Predictions, Testing and Standards 6
G Windows 10 OS build Software Validation US Food and Drug Administration (FDA) 1
S Help me build an Excel Spreadsheet for tracking training Training - Internal, External, Online and Distance Learning 14
P VDA 6.3 - How can I build the process NTF? VDA Standards - Germany's Automotive Standards 2
F Cost of hiring ISO 17025 Consultant to Build Laboratory From Scratch ISO 17025 related Discussions 6
I Manufacturing build requests - process and form Other Medical Device Regulations World-Wide 4
I How to build a Microsoft Access MDB Database for Document Control Document Control Systems, Procedures, Forms and Templates 6
M First Article Build (FAB) Process - Build and Test Aspects AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Can a non AS9100 facility build a Aerospace product? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
O What is involved with witnessing an aerospace software build? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Build own Power Magnetic Field Test Equipment for IEC 61000-4-8 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Q What are Box Build Processes? Manufacturing and Related Processes 4
M How they build the largest ship Coffee Break and Water Cooler Discussions 0
P Configuration Management for Build to Print Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Cable Manufacturing Build Audit Checklist Manufacturing and Related Processes 6
Marc The US Manufacturing Exodus Continues - Chinese to build Cessna business jets World News 1
1 Stop Ship/Build or something like a Quality Alert template or procedure example Document Control Systems, Procedures, Forms and Templates 5
M Production Trial Run Checklist or PV Build Checklist wanted APQP and PPAP 3
P Prototype Build Process per TS 16949 Clause 7.3.6.2 and APQP IATF 16949 - Automotive Quality Systems Standard 5
Z Does a Tooling Build or Design Benefit From TS16949 IATF 16949 - Automotive Quality Systems Standard 8
Marc China to build buses that cars can drive under World News 20
V I want to build a career as an ISO Auditor - How to start Career and Occupation Discussions 11
M How to build a Document Control System from scratch Document Control Systems, Procedures, Forms and Templates 6
L Work Instructions for One Time Tool Build - Tool and Die Shop Manufacturing and Related Processes 6
D Books on How to Build Forms (Guidelines) Book, Video, Blog and Web Site Reviews and Recommendations 5
L Can you help me build the perfect Quality Room? Quality Manager and Management Related Issues 27
Q Procedure for New Product Introduction (NPI) - Build to print shop Various Other Specifications, Standards, and related Requirements 6
B Quality Plan for ISO 9001-2000 - Assembly and Custom Build process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S How to Calculate BCS (Build To Customer Schedule) Metric? Lean in Manufacturing and Service Industries 3
T Control of Customer Supplied Material - Build to Print Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Machine Build Records Retention Requirements Records and Data - Quality, Legal and Other Evidence 1
S Do Product validation samples have to come from your PPAP build? APQP and PPAP 9
Marc Fiat and Ford forge car alliance to build a new car on the Panda platform World News 0
C Checking fixtures - How to build it and are its dimensions the same as the part? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Q In Need of Safety Advice - Design and build of a safety program Design and Development of Products and Processes 22
G How many hours does it take the big 4 to build an auto? IATF 16949 - Automotive Quality Systems Standard 9
D How to build an SPC control chart in an Excel .xls spreadsheet Excel .xls Spreadsheet Templates and Tools 8
A Is there a better way to do a complete assessment of our QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
