WikipediaBrown
I am currently working on a procedure for my company to create an FMEA for a new medical device. It is my understanding that the Hazard Analysis conducted per ISO 14971 should be our "top level" risk documentation, and then the FMEA will serve as a sort of supplementary resource, particularly when we start getting into the Process FMEA stuff later down the line.
Unfortunately I've run into a snag where the RPN ratings (green, yellow, red) are not aligning perfectly with our established Risk Matrix (Low, Medium, High). For instance, a harm might be rated as a "5" in severity, and a "2" in occurrence on our Risk Accetpability Matrix. If I was to multiply these numbers together like you would with an RPN, I would get "10", and this would be considered a high level of risk. However, if I had a harm that was rated as a "4" in occurrence and a "3" in severity, the product of those numbers is 12. The problem is, our Risk Matrix would still only designate that harm as having "medium" risk. Here's a visual aid to help describe what I'm talking about:
I would really prefer to stick to the tried and true method for calculating RPN with scales of 1-10 in occurrence, severity, and detectability. Should I just include a clause in my SOP which clarifies that the RPN rating does not necessarily correlate to Risk Acceptability?
I appreciate any guidance you guys can offer, this is my first time learning this material.
