Record Retention Verbiage Needed for "Lifetime" Retention
Minda
Good morning, Elsmar friends! I have a question about a document retention period called out in our retention matrix. We have certain records that used to have the record retention period defined as "Forever", but a Notified Body auditor at one point suggested we change it to "Lifetime of the Corporation" as "Forever" cannot be adequately defined. Having "Lifetime of the Corporation" has worked for a couple of years, but now we are getting our EU MDR certification and we have been told that the wording "Lifetime of the Corporation" is not appropriate as it does not ensure retention when the "corporation" changes in the form of business, if the "corporation" is acquired or changes names, or if the "corporation" is closed down at an earlier stage.
Has anyone had any similar feedback from their Notified Body, and how did you handle this? The auditor did not give any suggestions, only the input summarized above, and I would like to get this rectified before it becomes an observation for inadequate document retention period. We toyed around with "Lifetime of the Device Design", but we keep records from older, obsolete designs as well just in case we need to pull anything for any reason. Thanks so much in advance for your expertise!!
Tagin
For our small company 9001 system, I recently changed our document retention life on 'forever' records (I think I used the word "Indefinite" instead) to a symbolic term, like MAXRETENTION. At the top of the document control section, I state something like:
MAXRETENTION = 15 years
We do not have a regulatory retention requirement for max retention, but instead customer requirements, where we use the longest such customer requirement. So, I also specify along with the above retention definition where that number comes from, so:
Note: MAXRETENTION is per customer XYZ requirement.
So, if another customer came along with a longer requirement, we could just update the value and source of MAXRETENTION at the top of the document control doc.
Minda
We have some records that we do name a timeframe for. but others were determined that we should keep them as long as we exist as a company, hence the "Lifetime of the Corporation" verbiage. It is odd that the only fault they are currently finding is the use of the word "corporation", and I'm not sure what else I could use that would be a bit more proper without calling out a number of years. :(
Ed Panek
QA RA Small Med Dev Company
"Lifetime of the corporation" is also ambiguous; If GE absorbs you the records should not be thrown out. It could be "No less than X years after last product has been produced" but that doesn't cover bankruptcy.
I would give an X years after the last product was produced with a 2-year cushion for its shelf life/intended life.
I like Tagin's response above.
We are not medical devices, but we have retention periods like: "Life of product plus 15 years."
Ninja
Looking for Reality
Also not in medical.
I've always used "indefinitely" since they were all in dbases that didn't need culling.
Philip B
We go for the lifetime of the device (three years) plus ten years = thirteen years for everything. Has worked fur us so far.
Good Morning: Does anyone have a suggestion about software validations? We use "continuous".
Is your question pertinent to EU Medical Device Regulations (the topic of this forum)? If so, what specifically are you asking for? You use "continuous" for what? If your question doesn't pertain to the topic, please let us know what standard or standards are of concern so your post may be moved to the correct forum.
gabe2jadyn
Yes, this has to do with MDR. We are updating our record retentions and for OTS Software Validations, we use "continuous" for our retention. Do we need to be more specific or is this verbiage ok? Since we are a medical device company, we will use "10 years after discontinued and after last device ships".
K Record Retention For Manufacture of components ISO 13485:2016 - Medical Device Quality Management Systems 3
C Bulk Record Retention Review Records and Data - Quality, Legal and Other Evidence 4
E PMS record retention time for legacy devices EU Medical Device Regulations 1
E Record Retention - Raw Material (Steel Certs) Records and Data - Quality, Legal and Other Evidence 3
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
M Defining and Documenting Record Retention CE Marking (Conformité Européene) / CB Scheme 5
N ISO 13485 Quality Record Retention Period ISO 13485:2016 - Medical Device Quality Management Systems 4
Gman2 Quality Record Retention (Internal Audits, CA's) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Mobile app data privacy - Length of record retention in a software app Medical Information Technology, Medical Software and Health Informatics 1
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
K Our local sterilizer is closing - Record Retention Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Record retention for defunct customers? ISO 13485:2016 - Medical Device Quality Management Systems 11
T Record Retention Requirements - IATF 16949 Clause 7.5.3.2.1 Records and Data - Quality, Legal and Other Evidence 15
Pmarszal FDA Global UDI Database: Record Submission Retention Other US Medical Device Regulations 1
WCHorn Flowdown of Aerospace record retention requirements (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Production Record Retention Requirements Records and Data - Quality, Legal and Other Evidence 9
S Are there any new FDA requirements on Record Retention ? US Food and Drug Administration (FDA) 4
S Aerospace Record Retention Requirements Records and Data - Quality, Legal and Other Evidence 5
D Question... Record retention Prior to FDA NDA application and approval Records and Data - Quality, Legal and Other Evidence 3
C Record retention/retrieval for 30+ years? (The lifespan of the medical device) ISO 13485:2016 - Medical Device Quality Management Systems 5
N Notification Sample Regarding Record Retention ISO 13485:2016 - Medical Device Quality Management Systems 5
M Record Retention requirements for Safety Items Document Control Systems, Procedures, Forms and Templates 7
S Electronic Record Retention per FDA Requirements - Electronic Data Capture (EDC) Records and Data - Quality, Legal and Other Evidence 4
K 820.180(b) Record Retention - Does it apply here? We act as the initial Importer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B 21 CFR 820.180 Quality Record Retention Requirements Document Control Systems, Procedures, Forms and Templates 1
W Calibration Record Retention Requirements Document Control Systems, Procedures, Forms and Templates 18
T Control of Records - API Q1 8th Edition Record Retention Requirements Oil and Gas Industry Standards and Regulations 7
A Canada Importer Record Retention Requirements - Disagreement with NB auditor Canada Medical Device Regulations 5
R Record Retention Requirements per FDA 820 Regulations Records and Data - Quality, Legal and Other Evidence 10
D MDD (Medical Device Directive) 6.1 Record Retention Requirements question Records and Data - Quality, Legal and Other Evidence 2
Q US Distributor Record Retention Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P Record Retention requirements of Calibration and Verification Service Providers ISO 13485:2016 - Medical Device Quality Management Systems 11
E Approval Signature Record Retention Document Control Systems, Procedures, Forms and Templates 2
C Record Retention Time for Sterile Products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Customer Purchase Order: TS 16949 Record Retention Requirements Records and Data - Quality, Legal and Other Evidence 4
S Minimum Record Retention Period for ISO 14001 Records and Data - Quality, Legal and Other Evidence 2
S Record Retention Log - What Records are required in a Record Retention Log Records and Data - Quality, Legal and Other Evidence 7
C What is the Minimum Regulatory Requirement for Record Retention of DHR by Suppliers Records and Data - Quality, Legal and Other Evidence 9
B Training Record Retention Training - Internal, External, Online and Distance Learning 6
D Record Retention Requirements - TS 16949 Records and Data - Quality, Legal and Other Evidence 4
M Information Technology Record Retention time best practices Quality Management System (QMS) Manuals 2
Douglas E. Purdy Control of Disposition of Records - Record Retention - TS 16949 Clause 4.2.4.1 Records and Data - Quality, Legal and Other Evidence 8
T 21 CFR Part 11, "enforcement discretion" - Validation, Audit Trail, Record Retention Qualification and Validation (including 21 CFR Part 11) 4
Y Record Retention by R&D Shop After Handover ISO 13485:2016 - Medical Device Quality Management Systems 5
P ANSI NCSL Z540.1 Calibration Record Retention Period General Measurement Device and Calibration Topics 3
M Medical and Administration department Document and Record Retention policy Document Control Systems, Procedures, Forms and Templates 8
H Record Retention Time of Part Life + 1 Year Records and Data - Quality, Legal and Other Evidence 7
CarolX Record retention ideas for a sheet metal job shop supplying to a medical device mfg. ISO 13485:2016 - Medical Device Quality Management Systems 11
B Minimum retention or the date of destruction of a record - ISO 9001-2000 Para. 4.2.4 Records and Data - Quality, Legal and Other Evidence 13
J Record Control - Who are the Record Custodian and Retention Times - ISO9001 - 7.5.3 Records and Data - Quality, Legal and Other Evidence 9
