Recording of First Piece Inspection to meet 21 CFR 820.80e and ISO 13485 7.5.1.1
jkuil
In order to meet 21CFR820.80e and ISO 13485 7.5.1.1 requirements, how would you record the results of a first piece inspection, i.e. an inspection performed at the start of a run to confirm the system suitability for manufacturing (intermediate) products that meet specifications?
a) Record te results of any inspection performed until the system settings are final.
or
b) Only record the result of the last inspection performed upon which the run is started.
Q
Qualqueen
Re: Recording of first piece inspection
Are you just looking for an inspection form to enter your data?
jkuil
I am not looking for a form specifically, however it may answer the question.
The above question was meant to be a multiple choice question with two possible answers. How much data do you need to collect to record a first piece inspection?
bobdoering
Stop X-bar/R Madness!!
a) Record the results of any inspection performed until the system settings are final.
or
I vote for 'B' - the rest of the info is 'set-up', and really should be inspected 100% or scrapped, but suspect in any case. You should have a procedure for handling set-up parts, as they are one of the highest cause of rejects from a well controlled system!
This choice is also my vote for the first SPC plotted data point.
Q
Qualqueen
I'm still not sure I understand but I'll tell you what we do at my shop and have never been questioned by it.
Our 1st piece article is completed and consists of every dimension on the print taken from a sampling of parts prior to production. Once the samples are approved, we have an in-process inspection which consists of any major dimensions or something that we know can change during the run. This can consist of 2-3 or even 15 dimensions depending on the complexity of the part. As our final inspection, we take a handful (marked as final piece) and perform the inprocess inspection stating that it's the final piece and approve or not. Pretty basic but it works.
If you're looking for a multiple choice than I believe you're leaving yourself open for a problem. If it's not documented then there's no proof that it was ever done:
a) Record the results of any inspection performed until the system settings are final and b) Only record the result of the last inspection performed upon which the run is started. I'd take out the word Only .
bobdoering
:agree1:I agree - this is very typical and a good benchmark. Many will AQL (I guess a little more specific than a handful:tg:) for final and measure all dimensions, too (unless otherwise specified by their customer.) AQL is appropriate for final inspection, and often cited on purchase orders.
How this is done is really a need for a set-up parts procedure. Do all set-up parts need inspected? 100% of the dimensions? All documented? Or only the one affected by the adjustment? What was the problem with the system that it was not yet ready for first piece? It is so tenuous of a part of the process that many folks just scrap them rather than bother with them. It is just too risky.
Q
Qualqueen
I agree. What I was talking is actually a first piece submission of the part by the set-up operator after all adjustments are satisfied. I also agree with measuring all dimensions for final - but we know our jobs so well that we're able to just take the criticals, at a minimum - and yes - that's how we have it written in our procedure. :rolleyes:
Bunny
Regarding performing 1st article inspections for product ordered by a critical vendor. How do you document the inspection? Do you use a non-specific inspection form and note on it that it is a 1st article inspection? Do you notate anything on the drawing?
RCW
One option, among many, is to not reinvent the wheel. You can find FAI (First Article Inspection) forms that meet AS9102 requirements on the web. While these were developed for aerospace, they can be easily used and/or modified to fit other fields.
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R Question on determining defective units - I am not recording fixture to part rejected Statistical Analysis Tools, Techniques and SPC 5
V Recording CMM dimensional results on CFG-1003 APQP and PPAP 3
Marc Informational Apple Tells App Developers To Disclose Or Remove Screen Recording Code World News 0
B Easy Software Needed for Recording Mainly Attribute Data Quality Assurance and Compliance Software Tools and Solutions 2
N Where I can find an Excel sample/template for recording Delivery Time and Cost Excel .xls Spreadsheet Templates and Tools 2
chris1price Error in data recording - Recording measurements in SAP Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Consumer or Medical Grade Tablet to Receive Data from a Recording Module via WIFI IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
R Recording Control Plan Changes Document Control Systems, Procedures, Forms and Templates 3
M SAE AMS 2750E Relocation Hot or Cold Recording Sensor Manufacturing and Related Processes 1
A Recording Data and Data Analysis 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
L What is, and the purpose of, ISO STATS recording ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Recording of In Process Data to Meet FDA QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Does the recording of wrong entries amount to a nonconformity? Records and Data - Quality, Legal and Other Evidence 7
V Quality Plan (Inspection, Recording and Corrective Actions) Records and Data - Quality, Legal and Other Evidence 2
T Recording of Measured (Variables) Inspection Data vs. Check Boxes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
M Recording True Positioning (Geometric Tolerances) on an FAI Report Records and Data - Quality, Legal and Other Evidence 15
C Recording "nature of non-conformities" - Any way out of this?? ISO 13485:2016 - Medical Device Quality Management Systems 7
S Computer Screen Video Capture and Recording Software with Audio After Work and Weekend Discussion Topics 5
K Recording Weight Values on Calibration Certificates General Measurement Device and Calibration Topics 13
K Is Video Recording an Inspection allowed by Auditors? Records and Data - Quality, Legal and Other Evidence 5
K Supplier Performance - Recording Supplier Performance for long term trend reporting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Recording Scrap - Problems in the Medical Device Manufacturing Sector ISO 13485:2016 - Medical Device Quality Management Systems 4
F Save Excel file with Date for Recording Weekly Test Samples Records and Data - Quality, Legal and Other Evidence 11
A Validation of an Excel Spreadsheet used for Recording Test Results Qualification and Validation (including 21 CFR Part 11) 14
G ISO 14001 - Recording Competence, Training and Awareness in Existing Staff Training - Internal, External, Online and Distance Learning 8
J Simpler Method of Recording In-Process Inspection Data - Machine Shop Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Defect Recording Software recommendations Quality Assurance and Compliance Software Tools and Solutions 4
Jen Kirley Have you tried recording vinyl to MP3s and or CDs? Turntable with USB port? After Work and Weekend Discussion Topics 22
P 1st Article Part - Recording All Dimensions vs. Critical Dimensions - AS9100B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
T Recording Inspection Data - Best Practices - What do you folks do? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
M Inspection Results - The FDA's interpretation of recording inspection results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Grave 'aide memoire' from a Cockpit Voice Recording (CVR) transcript AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
N ISO9001:2000 Documentation/Activities Recording Software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Recording the results of Supplier Evaluation Supplier Quality Assurance and other Supplier Issues 16
G Recording Monitoring and Measuring Readings - Record inspection gages we use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Data Measurement - Where can I purchase a data recording system? Records and Data - Quality, Legal and Other Evidence 2
D Recording training of staff in new/revised procedures Records and Data - Quality, Legal and Other Evidence 7
D Does every piece of equipment used in a laboratory need to have an IQ protocol written and executed? ISO 13485:2016 - Medical Device Quality Management Systems 1
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
S "X-MR charts do not separate piece-to-piece repeatability of the process" Statistical Analysis Tools, Techniques and SPC 2
J AS9100D Sections related to 1st Piece and In-Process Inspection Manufacturing and Related Processes 15
S Setting up the process - First piece inspections Statistical Analysis Tools, Techniques and SPC 3
S If a piece of software receives approval as part of a medical device system Canada Medical Device Regulations 5
I First Piece Inspection classified as a Key Process Input FMEA and Control Plans 2
5 First Piece Inspection (Primarily Standard Machining) Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
K Gage R on a 10 Piece Sample with a CMM using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Q Effective 1st Piece Inspection Sign Off Procedure Quality Manager and Management Related Issues 8
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
M Example of a typical First Piece Inspection Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
