Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources
Ajay Akole
In Clause No. 7.1.5.1 :
"The organization shall retain appropriate documented information as evidence of fitness for purpose of
the monitoring and measurement resources."
Which records shall me maintained to demonstrate this requirement as we are in to machining activity ? Please help.
Thanks in advance.
Bran
Is not "Fitness for purpose" different than "Fitness for use"?
"Fitness for use" is easily demonstrated through calibration records for a device.
Wouldn't "Fitness for purpose" be a record that demonstrates a device is correct for the application? Calibration records would not cover this. MSA records seem to address this better, but may not go far enough. (For example, a tape measure may pass a GRR study, but that does not mean it is the correct device to measure very small linear distances better suited for a micrometer)
somashekar
Without applying much English knowledge to the standard's words, what is not fit for purpose is not useful.....
Tagin
'Fitness for purpose' is essentially referring to "are you using the right tool for the right job?" This has nothing to do with calibration status per se.
On our tool records, we have a field enter a text explanation of why that tool is suitable. In some case, it might be customer-directed or customer-supplied; in other cases, it could be to say that the tool can 1) perform xyz test within spec of customer reqmts, and 2) can be calibrated, and 3) can perform a self-test.
It doesn't have it be too complicated, unless the conditions that qualify that tool for that job are complicated.
dwperron
Bran raised a great point on this.
Go up a couple of lines in 9001:2015 7.1.5.1:
"The organization shall ensure that the resources provided:
a) are suitable for the specific type of monitoring and measurement activities being undertaken;
b) are maintained to ensure their continuing fitness for their purpose."
This is nice and clear... until you get into the mud of the question in the original post.
"evidence of fitness for purpose ", though poorly written, applies to b) and would be the calibration / maintenance records.
AMIT BALLAL
AMIT, could you please upload example of "Sample inspection report" in respect of topic discussed?
Any inspection report would be able to conform to this requirement of the standard. An inspection report will be able to to tell whether the measuring instrument is fulfilling the purpose i.e. Inspection (Measurement). You just need to check whether the instrument is correct one considering the purpose (Inspection/testing/ monitoring, etc.).
The requirement of calibration is addressed in clause 7.1.5.2.
S What records are required to show compliance to ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 1
K List of procedures and forms or records required by ISO 15189:2012 Document Control Systems, Procedures, Forms and Templates 2
H Is "Master Documents and Records list" required per ISO 9001 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
drgnrider Informational Required Documents/Records in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 80
R Required artifacts (records) for ISO 27001 Auditing IEC 27001 - Information Security Management Systems (ISMS) 9
J Records Required by ISO 9001 - Audit Nonconformance - No record for 7.5.4 Records and Data - Quality, Legal and Other Evidence 13
P Control of Records - Is a List of Records Required by ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
K What Records are required by ISO 22000? Food Safety - ISO 22000, HACCP (21 CFR 120) 4
T Level of Documentation and Records required for ISO 9001 in a Small Business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D List of Mandatory Records required by ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 16
Ajit Basrur ISO 17025 - Required Procedures and Records ISO 17025 related Discussions 11
D Control of Records limited to ISO 9001 Required Records - ISO 9001 Clause 4.2.4 Records and Data - Quality, Legal and Other Evidence 1
A Records Required for ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 8
S Who can confirm the 21 mandatory records (clauses) as required by ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N Clarification of Required Records by ISO 9001:2000 Records and Data - Quality, Legal and Other Evidence 10
M Required to keep records of all expedited freight? ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J ISO 9001:2000 Clause 7.1d - What Records are Required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Minimum Quality records required by ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
L ISO 14001 4.4.4 d) - What exactly are the documents and records required by ISO 14001 ISO 14001:2015 Specific Discussions 4
I ISO 13485 - List of required / needed procedures and records attached ISO 13485:2016 - Medical Device Quality Management Systems 59
D ISO 13485 - Part 11: Electronic Records - Small Biotech Company - What is required? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
M Required Records - ISO 9000 - 7.1 d), 7.5.2 d), 8.2.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Why not just audit the required 21 records - ISO 9001 Clause 4.2.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
Marc List of Quality Records (Categories) Required by ISO 9001:2000 Records and Data - Quality, Legal and Other Evidence 1
L ISO 14000 - Required Quality Records Records and Data - Quality, Legal and Other Evidence 2
F Distribution Records required by FDA - 21CFR820.160 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Is Handwritten Raw Data required to keep with Electronic Records? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D FDA required (mandatory) Signed Records Qualification and Validation (including 21 CFR Part 11) 1
BHobbs_Busche TS 16949 - Records required for No Quotes IATF 16949 - Automotive Quality Systems Standard 3
Q List of Records required in AS9100 standards AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Are all In-Process Quality Records required in final QA Batch Record Review. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
armani Records Required for Clause 7.3 in Service Organizations ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Are records required for excluded AS9100 clauses? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q Drawing Review Records Required for every Drawing (Print)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Required Internal Audit Records & Forms Internal Auditing 4
Q AS9100 Rev B List of Required Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
S Record Retention Log - What Records are required in a Record Retention Log Records and Data - Quality, Legal and Other Evidence 7
N Master List of Records Required? ISO9001:2008 Clause 4.2.4 Control of Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
H Inspection Reports Required? Records are kept in a different country ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
H Are Tooling Design Records required by TS 16949 Design and Development of Products and Processes 2
S MSDS Records - Is a hard copy required if I have a scanned copy? Miscellaneous Environmental Standards and EMS Related Discussions 14
M Is a Records List Required for ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
N Records required by TS16949 - I have identified 26, are there more? Records and Data - Quality, Legal and Other Evidence 29
Crusader Preventive Maintenance - Electronic Records Deleted/Erased OR Are Records Required? Records and Data - Quality, Legal and Other Evidence 62
M What are the Mandatory Records required by AS9100b Clause 4.2.3 / 4.2.4 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Required records destroyed - Secretary cleaned it out and threw everything away Records and Data - Quality, Legal and Other Evidence 7
O What are typical records of different documents required by ISO9001? Records and Data - Quality, Legal and Other Evidence 2
S Training Requirements for Senior Management - Are training records required? Training - Internal, External, Online and Distance Learning 16
S Is FMEA training records required?? Our internal auditor made this a nonconformity. IATF 16949 - Automotive Quality Systems Standard 9
A Here is a List of Records Required by TS 16949 Records and Data - Quality, Legal and Other Evidence 3
