qualprod
Hello everybody
I need some advice on the next:
In a manufacturing company, ISO 9001 certified, it was implemented to record everything, yes what I said, "everything"
This happens in the production processes.
For example, by using forms, people describe, when the work order started, time spent in each process, (there are up to 5 processes)
responsible person, quantity of raw material for all the work orders (ink, paper,bags) , which machine, raw material for setup, non conformity pieces, etc.
So the people, spend a lot of time to perform the job, and apart to spend time in filling out the forms.
The original idea of doing this was to capture all data in order to be analized for the improvement of the processes.
I was proposed to implements improvements in this company and after some evaluation of the way they work.
As first option to start the improvement, I defined the next practice,
To stop the recording of everything, and just to record what is really important, considering complying to ISO, the customer, and the company requirements.
The point is to spend more time in production, not in the recording of data.
And of course in order to have data for improvements, I´ll run lean analysis when is needed, maybe quarterly or twice a year.
By applying resources (people, computer, etc.) we will start to analyze when Work order is received, how long did it take to start to work, how long was the setup process, raw material used in the WO, defective pieces, time spent in changing a tool, etc.
After Lean is finished, it will trigger improvements projects with all the follow-up required.
One point, for sure a lot of time will be saved when workers/operators in machines will record only what is needed, thus
work orders will take less time to be released to customers.
Please advice on this, is it good my decision? is this a normal practice in manufacturing companies.
Thanks for your time.
