Reduce occurrence rating based on the PMS data and customer complaint data
HI
I am conducting PMS for class IIB DEVICE per EUMDR requirement. Last year I had a change in occurrence for a defect in my risk file based on customer complaint data. This shifted the occurrence to a higher level which resulted in a medium level or risk resulting in a benefit risk assessment.
based on the PMS data and customer complaint data..our occurrence levels have actually gone down without us taking any corrective actions. The occurrence level calculation is based on a complaints per million rate. If I use the lower occurrence to do my risk evaluation, I get a low risk and my risk is now acceptable.
My question is: can I use this occurrence data to now reduce my risk to an acceptable level which was unacceptable an year ago?
thanks
yodon
Let me be sure I understand.
You did an initial risk analysis and assigned what you thought would be a reasonable likelihood of occurrence to a particular risk. You got some complaints that led you to believe you needed to increase the likelihood of occurrence but you conducted a benefit-risk analysis and concluded no changes (no additional controls / no corrective actions) were necessary. Subsequently now, you are not seeing data to indicate that you should have raised the likelihood in the first place?
Without knowing more, it would be, well, risky, to advise that the score be lowered. It's not completely clear that you have enough data to justify. Have you done a thorough analysis of the failures? We don't have enough data to understand why you apparently saw a spike (causing you to raise it) and then it hasn't occurred (or is occurring at a much lower rate).
Is it possible that the original increase in Occurrence was due to a "special cause", or something that does not reflect an increase in failure rate? A few years ago, my company had a "spike" in occurrence based on complaints, but when we dug deeper we found that one customer was entering a complaint each time a problem occurred, on the same unit. There was one defect, but it was reported multiple times. In the end, though, only one actual failure. (It's important to recognize "device failure" and "opportunity for harm" can be slightly different...)
As @yodon said, more data may be necessary. Maybe telling the whole story will give you good justification to return the occurrence rating to the lower value.
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
PQ Systems 5 Ways to Reduce Stress on Your Next Audit Using GAGEpack Software 0
C Can I reduce P1 to zero? ISO 14971 - Medical Device Risk Management 15
L Reduce risks as far as possible - Quartz Crystal ISO 14971 - Medical Device Risk Management 11
S Advice on how to reduce overhead of handling non-conforming material Nonconformance and Corrective Action 7
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
adir88 Information of safety can reduce risk now? ISO 14971 - Medical Device Risk Management 12
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
W Duplicated Gauges want to reduce calibration General Measurement Device and Calibration Topics 2
S Methods to reduce relative humidity in Datacenter IEC 27001 - Information Security Management Systems (ISMS) 3
O How do reduce the risk of suppliers having similar problems? Supplier Quality Assurance and other Supplier Issues 4
R Employee diet to reduce absenteeism and increase productivity Hospitals, Clinics & other Health Care Providers 24
B Proactive efforts to reduce risk - PFMEA risk reduction activities IATF 16949 - Automotive Quality Systems Standard 8
N How to reduce RPN of Visual Inspection Process FMEA and Control Plans 6
2 High-tech medical equipment to reduce medication errors Medical Information Technology, Medical Software and Health Informatics 5
M Is That Plating Wave Washer will reduce its stiffness? Supplier Quality Assurance and other Supplier Issues 1
C How to Reduce Inspection Frequency in Metal Stamping Company Quality Manager and Management Related Issues 4
C Design of Experiments to Reduce Variation in a Lathe Operation Quality Assurance and Compliance Software Tools and Solutions 9
D How to reduce the number of Quality Inspectors Quality Manager and Management Related Issues 7
S Using ANSI/ASQ Z1.4 to Reduce Impact of Field Service Campaign AQL - Acceptable Quality Level 17
P How to reduce or shut off Compressed Air for Painting Robots Manufacturing and Related Processes 3
P How to Reduce or Eliminate Inspection on an Assembly Line Quality Tools, Improvement and Analysis 10
Sidney Vianna ISO 14006 - New Standard to Reduce Environmental Impacts of Products and Services Miscellaneous Environmental Standards and EMS Related Discussions 1
D How to Reduce Sampling and get the same MTTF (Mean Time to Faliure) Reliability Analysis - Predictions, Testing and Standards 4
J Reduce 50 Work Instructions into 12 Key Processes Process Maps, Process Mapping and Turtle Diagrams 8
A Can we reduce documents checking percentage on supplier certificates? Supplier Quality Assurance and other Supplier Issues 3
T How do I Reduce Frequency of Receiving Inspection Testing for Quality Control Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
S What to do if no further control possible to reduce the OHS risk? Occupational Health & Safety Management Standards 16
S How to Reduce the Cost of Broken Measurement Equipment Quality Tools, Improvement and Analysis 8
M Plastic Mold Approval - What are the ways to reduce mold approval cycle? Manufacturing and Related Processes 8
A How to Reduce Printed Paper Waste Sustainability, Green Initiatives and Ecology 47
P Does Six Sigma Project have to Reduce Variability? What about a mean shift to target? Six Sigma 6
M Does Disciplinary Action Reduce Operator Errors? Misc. Quality Assurance and Business Systems Related Topics 80
A Control Chart to Track Effectiveness of Actions to Reduce Scrap Rate Six Sigma 7
P Attempting to reduce sample size - The "best" statistical technique to use Statistical Analysis Tools, Techniques and SPC 10
Sidney Vianna ISO Guide 64 will help reduce environmental impacts of products Other ISO and International Standards and European Regulations 1
B On Time Delivery Question - Project to reduce late shipments Lean in Manufacturing and Service Industries 7
T Using SPC Control Charts to Reduce AQL Sample Size AQL - Acceptable Quality Level 16
R CMM Machine upgrade - Ways to reduce CMM inspection cycle time Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D Project to Reduce Destructive Sampling in Crimping Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J Customer wants to Reduce GD&T Tolerances on Sheet Metal Subassemblies Manufacturing and Related Processes 8
Y Can I reduce the Sample Size? Sampling check of more than 1,000 pieces daily Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
Douglas E. Purdy Classification of Suppliers & Control Plans to Reduce Receiving Inspection FMEA and Control Plans 6
R Tool Kits to Reduce Direct Time on Milling Machine Manufacturing and Related Processes 15
D When do you reduce SPC sampling? And How? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Cost Down! - Reduce Manpower Misc. Quality Assurance and Business Systems Related Topics 7
R 100% Visual Inspection - Would you Remove or Reduce the Visual Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
S TPM increasing employee overtime costs - How to reduce costs? Quality Tools, Improvement and Analysis 6
