Reducing the Frequency of a Production Line Test
Q
Qualityfan34
Can anyone advice me what will be the best approach in order to determine if the frecuency of a test can be reduce?
Background: i have a test that is performed hourly but i pull out some data (about 3 month data) and in that period of time it has not been reported any failure. Based on this, i understand that an improvement on the frecuency can be perform but i want to use a proper approach in order to provide the info.
Thanks in advance,
P
pearsonow
Re: Reducing the frequency of a test
How much variation is there within the data - are the operators doing something to adjust the data and prevent bad parts?
If you are confident in the process, then you can justify a reduction in sample frequency to save time and money. If you have the authority to make this decision then simply document it in line with your Quality System and do it.
chemohd
perhap you can consider taking 1 year data & analyse it. what is the trend, variation, then your have strong evidence that you process is controllable.
hope it will help.
Q
Qualityfan34
The CPK is 5.31 and the StDev is 3.21. The operator are limited to perform the test only. With this data, are you guys think is enough to provide in a report (just attaching the CPK Graph)?
Sturmkind
I would think it would depend if the test is customer mandated. Also, I agree with chemohd that the data should be verified for a state of statistical control. If there are no trends, stratification, or other out-of-control conditions you may well be justified in cutting back on the frequency.
Q
Qualityfan34
Hi Sturmkind, thanks for your feedback. The test is not required by the customer, is just internal control. I have verified the trends (YTD) and no issues have been reported. At the moment i have the following data:
Complaints trend
NCR trends
CPK
STDEV
The question now is, am i missing any statistical fact that needs to be included in order to have a complete report to be provided to quality management?
Things I take into account are:
what is the severity of the failure resulting from a defective part? A very severe failure might require continued high frequency because we can't afford a miss should it happen. Remember that statistical control today doesn't guarantee control tomorrow...
What are the positive controls in place to maintain a stable and capable process in the future?
Are there other detection points prior to the Customer receiving a defective part?
As others have eluded to, a "Cpk graph" is probably not hte best choice. A run chart (all individual values if you use subgroups of n>1) vs spec limits is a better display of all of the data as shifts, trends and cycles are visible.
Q
Qualityfan34
Hi Bev D, very appreciate for your valuable opinion. The severity of a failure of the product is major because the product performance will be compromised. However, the occurrence is very low and i don't want to eliminate the test, my suggestion is reducing the frecuency lets say from taking 10 samples every hour to 10 samples every two or three hours.
On the other hand, i'm agree with you that a run chart will make more sense instead of a CPK graph.
Hence, what additional approach you can recommend me to include on this evaluation?
Q Reducing the Frequency of Audits - Internal Audit Programme 2012 Internal Auditing 13
D Reducing gaging frequency/High Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 4
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
D Strategies for reducing software documentation burden IEC 62304 - Medical Device Software Life Cycle Processes 10
M Methods of reducing/eliminating the systematic component of error General Measurement Device and Calibration Topics 0
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
B Reducing variation through multiple readings Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Reducing Cost of Poor Quality - Your opinion requested Quality Manager and Management Related Issues 14
B EMC Repeat Justification - Reducing NRTL testing required after modification of ME IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Reducing cost of IEC 60601 3rd edition testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
J Reducing Variation via Multiple Readings Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
9 Ideas for reducing Human Error during Order Receipt Quality Manager and Management Related Issues 4
D Reducing Within Part Variation during a Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 26
O Reducing a Cpk which is higher than 1.33 Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Reducing End of the Line Skipped Rabbit Testing Reliability Analysis - Predictions, Testing and Standards 3
S SMED on Punching Machine - Reducing Set-Up Time Lean in Manufacturing and Service Industries 4
M What is your most significant experience in Reducing Injection Moulding Cycle Time? Manufacturing and Related Processes 18
P ROI (Return on Investment) for Reducing Order to Fullfillment Lead Time Manufacturing and Related Processes 1
A Operation Control for Reducing Electricity Consumption Miscellaneous Environmental Standards and EMS Related Discussions 18
W Reducing Documentation for In-Process Inspections ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Reducing Material Handling Costs - In-Floor Tow-Line Conveyor System Lean in Manufacturing and Service Industries 7
R Chain Sampling Plan explanation and help - Reducing sample sizes (compared to Z1.4) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Reducing paperwork and placing in Systems electronically - Electronic documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
N Reducing Equipment Variation - Appraisal Variation - Newly developed product Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Reducing Engineering Change Orders Document Control Systems, Procedures, Forms and Templates 16
P Traffic, Distribution, Imports - Reducing Cost, Traffic Process Manufacturing and Related Processes 28
J Reducing Inspection Costs - Sampling Plans and Producer's Risk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T One Work Instruction instead of Many - Reducing Documentation Document Control Systems, Procedures, Forms and Templates 7
V Six Sigma Project on Reducing Plastic Injection Molding Rejects Six Sigma 10
K RPN reduction - Occurrance Reduction - Reducing occurance of defect on line FMEA and Control Plans 1
C Reducing Variation through Multiple Readings - MSA 3rd edition Chapter 5d Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S Environmental Management Program - Reducing electric and fuel use, waste management Miscellaneous Environmental Standards and EMS Related Discussions 25
A Reducing The Amount Of Time Spent While Improving The Effectiveness Of Meetings QS-9000 - American Automotive Manufacturers Standard 4
M Reducing both Detection and Occurance in a Design FMEA WITHOUT a Design Change FMEA and Control Plans 8
D Reducing the Number of SPC Charts used: We have many highly capable processes Statistical Analysis Tools, Techniques and SPC 6
S Strategies for reducing Sampling on incoming bulk material - low volume, ingots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Traceability - Reducing final inspections on separate lots QS-9000 - American Automotive Manufacturers Standard 3
D Corrective Action Process Review - Reducing the scope of our NRS Nonconformance and Corrective Action 6
M Bioburden Frequency (sterile MD) Other Medical Device Related Standards 2
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
qualprod To set frequency to review documents in ISO 9001 7.5? Document Control Systems, Procedures, Forms and Templates 13
M Defining frequency of measurement tools callibration Calibration and Metrology Software and Hardware 3
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
L Calibration Frequency for Surftest SJ-400 General Measurement Device and Calibration Topics 0
G ISO 9001 - 9.3.1 Management Review - Content and Frequency Management Review Meetings and related Processes 12
H Frequency of shelf life/sterilization/bench studies conducted on a medical device Other Medical Device Related Standards 1
