Reducing Variation through Multiple Readings - MSA 3rd edition Chapter 5d
cyberjyothi
Hi friends,
can some body help me !
During Audits I'm facing lot of queries with the external auditors(ISO/TS16949)
,What is the corrective action u h've taken while the GRR is exceeding >30%.
For this i found one alternative, i.e In MSA 3rd edition Chap-V -sec-d under reducing variation through multiple readings.
They given one Ex :% of Tol GRR variation is 25.5%, With a 6 Sigma spread equal to 0.24 ,If we reduce this fig. to atleast 15%,Which would have an equivalent 6 sigma spread of 0.14.
Pl. can anybody explain how the figure(0.24&0.14) arrived .
Thanks,
Jyothiswar:thanx:
cyberjyothi said:
Hi friends,
Thanks,
Jyothiswar:thanx:
Those numbers are just examples, although I'm not sure where the examples came from. On page 175 of the 3rd Edition MSA manual, under Example, it says,
In the XYZ Corporate example, the percentage of tolerance GRR variation is 25.5% with a 6 sigma spread equal to 0.24. The customer wants to reduce this figure to at least 15%, which would have an equivalent 6 sigma spread of 0.14.
The reference to "the XYZ Corporate example" is unclear; I did a brief scan and couldn't find such and example in the manual, but perhaps I missed it. Nonetheless, you can use the information and formulae by just plugging in your own data.
There is a simple relationship between the measurement error and the sample size. Take the existing measurement error in StdDev and divide by the square root of the sample size.
For example, if you take a sample size of 4 and use the average as your measurement, you will reduce your measurement error by half.
measurement error / SQRT(4) = mesaurement error / 2
mos_mos
Re: Reducing variation through multiple readings - MSA 3rd edition Chapter 5 d
If grr to tol value s say 130%, can this method allow me to do a capability study through multiple meas however painful?
If you were to take a small number of individual measurements, you could take the average of 16 measurements to reduce the error by 4 (SQRT of 16). However, I am guessing that you do not want to measure 1600 pieces for a capability study.
A better, less painful option, follows:
  1. Perform 100 pieces capability study, calculating mean and standard deviation
  2. Square standard deviation to calculate total observed variance
  3. Find Repeatability and Reproducibility standard deviation from your R&R study
  4. Square standard deviation to calculate total R&R variance
  5. Subtract total R&R variance from total observed variance to calculate product variance
  6. Take square root of product variance to calculate product standard deviation
  7. Use mean from step 1 and standard deviation from step 6 to calculate Cp and Cpk as appropriate.
bobdoering
Stop X-bar/R Madness!!
The other option is to review the resulting data from your gage R&R, and determining the various within- and between- errors and try to eliminate as many of the causes of error as possible - either by improving the technique (such as fixturing, etc.) or at least using another gage that will eliminate the most significant contributors of the error by its design.
mos_mos
Thanks for the fast reply!!. What assumptions underlie plan B in terms of variation proportion? What do i need to check in order to close the loop? Thanks!!!!
bobdoering
I suggest reviewing page 53 through 54 of 3rd ed. MSA and look for those issues during the Gage R&R study. After identifying them, look to reduce them to improve Gage R&R. Reducing the variation will reduce the GRR as % of tolerance, as the tolerance remains the same.
mos_mos
I understand how you sort the measuring system but in this case it is not easily/timewise etc/cheaply done, and historical we want to bookend. Right now we no choice but to use the existing and modify to improve measurement through repeated meas and also do capability with it.
Hence my reason for asking the previous questions. Thanks for the information very much appreciated.
B Reducing variation through multiple readings Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Reducing Variation via Multiple Readings Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Reducing Within Part Variation during a Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 26
N Reducing Equipment Variation - Appraisal Variation - Newly developed product Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
D Strategies for reducing software documentation burden IEC 62304 - Medical Device Software Life Cycle Processes 10
M Methods of reducing/eliminating the systematic component of error General Measurement Device and Calibration Topics 0
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
M Reducing Cost of Poor Quality - Your opinion requested Quality Manager and Management Related Issues 14
B EMC Repeat Justification - Reducing NRTL testing required after modification of ME IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Reducing cost of IEC 60601 3rd edition testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
9 Ideas for reducing Human Error during Order Receipt Quality Manager and Management Related Issues 4
O Reducing a Cpk which is higher than 1.33 Capability, Accuracy and Stability - Processes, Machines, etc. 12
Q Reducing the Frequency of Audits - Internal Audit Programme 2012 Internal Auditing 13
T Reducing End of the Line Skipped Rabbit Testing Reliability Analysis - Predictions, Testing and Standards 3
S SMED on Punching Machine - Reducing Set-Up Time Lean in Manufacturing and Service Industries 4
Q Reducing the Frequency of a Production Line Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
M What is your most significant experience in Reducing Injection Moulding Cycle Time? Manufacturing and Related Processes 18
P ROI (Return on Investment) for Reducing Order to Fullfillment Lead Time Manufacturing and Related Processes 1
A Operation Control for Reducing Electricity Consumption Miscellaneous Environmental Standards and EMS Related Discussions 18
W Reducing Documentation for In-Process Inspections ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Reducing Material Handling Costs - In-Floor Tow-Line Conveyor System Lean in Manufacturing and Service Industries 7
R Chain Sampling Plan explanation and help - Reducing sample sizes (compared to Z1.4) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Reducing paperwork and placing in Systems electronically - Electronic documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Reducing Engineering Change Orders Document Control Systems, Procedures, Forms and Templates 16
P Traffic, Distribution, Imports - Reducing Cost, Traffic Process Manufacturing and Related Processes 28
J Reducing Inspection Costs - Sampling Plans and Producer's Risk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T One Work Instruction instead of Many - Reducing Documentation Document Control Systems, Procedures, Forms and Templates 7
V Six Sigma Project on Reducing Plastic Injection Molding Rejects Six Sigma 10
K RPN reduction - Occurrance Reduction - Reducing occurance of defect on line FMEA and Control Plans 1
S Environmental Management Program - Reducing electric and fuel use, waste management Miscellaneous Environmental Standards and EMS Related Discussions 25
A Reducing The Amount Of Time Spent While Improving The Effectiveness Of Meetings QS-9000 - American Automotive Manufacturers Standard 4
D Reducing gaging frequency/High Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Reducing both Detection and Occurance in a Design FMEA WITHOUT a Design Change FMEA and Control Plans 8
D Reducing the Number of SPC Charts used: We have many highly capable processes Statistical Analysis Tools, Techniques and SPC 6
S Strategies for reducing Sampling on incoming bulk material - low volume, ingots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Traceability - Reducing final inspections on separate lots QS-9000 - American Automotive Manufacturers Standard 3
D Corrective Action Process Review - Reducing the scope of our NRS Nonconformance and Corrective Action 6
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
N Post registration variation to medical device Other Medical Device Regulations World-Wide 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Variation between Faro Arms Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E Changes to medical device submitted through a variation? EU Medical Device Regulations 1
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
D "It depends on the Auditor" Is excessive variation jeopardizing system certification? Registrars and Notified Bodies 40
Q What does % study variation of 20% mean in GRR? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
