Black arrow
We made a MSA recently and the tolerance is "one sided" and the tolerance limit is 0.020 mm. I can see that the variation of the present measurement system is not acceptable so if we measure parts that are close to upper tolerance limit we can have some problems to know if the parts are within spec are not. I would like to determine a sorting limit based on the variation from the measurement system.
The data from the MSA are:
6 standarddeviations: 0.008 mm => 3 standarddeviations 0.004 mm
My approach to this is to decrease the tolerance limit by 3 times standarddeviations => 0.020 -0.004= 0.016 mm.
If we measure the detail and gets 0.016 mm, the part should be ok.
BUT if we get 0.018 mm? I know that we can reduce the variation by measure it once again, (6s)/√
Do someone have some good guidelines to follow when it becomes multiple readings when a result is above the sorting limits such in my case above?
Thanks for your support here.
