Redundancy between Process risks and Process Performance indicators
Ragnarok
Hi
We have a process document that contains the following tabs :
* process risks
*process Opportunities
*Process performance indicators and targets
my problem is I am not sure we don't have a redundancy between the process risks and process performance indicators and targets tabs
I mean , if i select for the support process ,"Risk of having response time not according to SLA" ,and current likelihood is 15% , impact is High , and i want to REDUCE the likelihood of the risk to less than 10% ,
Should i then mention that one of my process performance indicators is number of cases outside sla and set a target for it in the "Performance indicators and targets" tab?
I feel it's redundant and needlessly complicating things ...but i would like other opinions
Thanks for the help
Mark Meer
If the objectives/performance-indicators derive from risk assessments, then I don't see there's a problem with documenting the way you've described.
A couple comments though:
1. Curious: How do you arrive at such a specific likelihood ("15%") for risk? How would you know if the likelihood has decreased to 10%?
2. Wouldn't a better performance indicator be specified in terms of the rate at which response times meet/exceed SLA requirements?
Risks always involve estimates, but your performance-indicators should reflect ACTUAL collected data.
qualprod
I don't see the need to mix kpis.
For the case of the the risk, treated directly, if you detected a risk in one in a process, act on it, put to work mitigation plans to minimize the risk.
Do not measure the performance of the risk, measure the performance of the processes.
Into the MR sessions, revise status of risks and effectiveness.
Hope this helps
Mark Meer
Agree with the "Do not measure the performance of the risk, measure the performance of the processes" statement.
...but as far as not relating risk & kpis at all, I could certainly see cases where you'd want to.
It may be beneficial to select certain indicators to support risk assessments, or monitor the effectiveness of risk controls.
Ragnarok
Well we are doing like this:
we grade our likelihood of risk : 1=<10% occurence,2=10-30%,3=31-50...etc
we then do a rating of impact: 1=no impact ,2=minor impact,=moderate impact
Seriousness of risk=Likelihood * impact
in 2017, 15% of our cases were out of SLA
so in the case of SLA , likelihood=2 , Impact =4 ...so seriousness of risk =8
We want to reduce the likelihood to <10% so EXPECTED risk after control actions is 4 ,(likelihood 1* Impact 4)
This allows us to verify that our actions are effective or not
Mark Meer
So, to summarize, you:
1. Evaluate risk (based on estimates derived from current available data)
2. Assign/implement controls (to reduce risk by reducing likelihood of occurrence)
3. Re-evaluate risk (based on how much you anticipate the controls reducing likelihood)
4. Set performance-indicators that would be necessary to verify the the controls are as effective as anticipated.
5. Proceed to gather data
6. Analyse data as a measure of how effective the risk controls are.
7. Re-assess risk based on data analysis
Sounds good to me. I don't see that there's unnecessary redundancy...
qualprod
Well , maybe to assign a % of compliment, say at least the 80 % of risk were treated effective, ok sounds good.
isolytical
IMHO, you are correct a 'redundancy' seems to exist. To me the PPI/target is the mitigation and/or measure for the mitigation.
Perhaps too much is placed into the SLA - which may be limited to targets.
A risk exists in failure to meet a process objective. So an internal document identifying process objectives, as failures, may remove redundancy.
Ragnarok
Can you please give an example of what that internal document would contain ? any example would do
isolytical
What I can do and keep within my established constraints is this.
Very generally, before letting an SLA a/o contract an internal document exists to define the SLA a/o contract (sub) processes. It identifies opportunities, risks, and failures in those (sub) processes. It quantifies operational risks with an aim to develop responses, mitigations, or accept, as is risk. The overall risk impact on service provision results when purposely applied.
In the original question, risk applied to targets, rather than to processes. And, the results were not expressed in terms that management understands.
The importance of understanding the above-described process rises above viewing a completed document.
x-files Necessary or Unnecessary Redundancy in Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R Redundancy in PFD and Control Plans? APQP and PPAP 3
T Relation between ISMS and QMS for a SaMD Medical Information Technology, Medical Software and Health Informatics 3
K What are the differences between the certificates required for home and medical medical equipment? US Food and Drug Administration (FDA) 1
L Assignment on the link between Quality Gurus & ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
X Difference between the Figure J.6 and J.7 insulation examples IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Difference between Appliances and Parts according EASA EASA and JAA Aviation Standards and Requirements 0
X Insulation between opposite terminals of battery IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
M FMEA Severity Scores Between Two Sister divisions? FMEA and Control Plans 6
S Disparity between Job Descriptions in QMS & Contract ISO 13485:2016 - Medical Device Quality Management Systems 7
A Difference between general PMCF and PMS EU Medical Device Regulations 3
F Difference between "misuse" and "off-label use" EU Medical Device Regulations 12
placebo_master What is the difference between "Fitness for Purpose" and "Calibration/Verification"? General Measurement Device and Calibration Topics 6
S Link Between Essential Performance Requirements and Essential Design Outputs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
G Similarities between format of technical file for CE and ASEAN common submission dossier template (CSDT) CE Marking (Conformité Européene) / CB Scheme 2
B For professionals from an amateur: What are the differences between some plans and procedures? EU Medical Device Regulations 5
Y Relationship Between Appendices to Annex XVII and Annex XVII of REACH regulation REACH and RoHS Conversations 0
T ISO 27001 - 4.3 c - Interfaces and dependencies between activities - how to consider these? IEC 27001 - Information Security Management Systems (ISMS) 2
C Need to understand difference between an actual Calibration vs. a Calibration check General Measurement Device and Calibration Topics 3
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
M Procedure for communication between authorized rep and distributor Other ISO and International Standards and European Regulations 0
J Impact Testing--Is conversion between Izod and Sharpy Possible? General Measurement Device and Calibration Topics 3
lanley liao Confusion between national standard and API related standard. Oil and Gas Industry Standards and Regulations 8
T Is there a direct relation between surface roughness and gloss? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
gohyl Printed Circuit Board - Unusual sighting between pads, is it normal. Manufacturing and Related Processes 19
A What is different between Field Safety Notice and Advisory Notice in U.S and EU? Document Control Systems, Procedures, Forms and Templates 7
R Whats different between these position CE Marking (Conformité Européene) / CB Scheme 10
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
U How to pick between ANSI Z1.4 vs. ISO2859-1 for AQL Inspection? What are the major differences? AQL - Acceptable Quality Level 4
H Independence between the development and testing IEC 62304 - Medical Device Software Life Cycle Processes 6
N R&R for Differences between 2 measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 3
I Сorrespondence between hazards and risks ISO 14971 - Medical Device Risk Management 2
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
L MRA between EU and Switzerland - 1/2021 EU Medical Device Regulations 2
D Difference between Test Method Validation and Gage R&R Qualification and Validation (including 21 CFR Part 11) 20
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
C Is my software an accessory? Telecommunication between HCP and patients EU Medical Device Regulations 11
K Verify Software Architecture - supporting interfaces between items IEC 62304 - Medical Device Software Life Cycle Processes 2
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
DuncanGibbons How is the arrangement between Design and Production organisation envisaged? EASA and JAA Aviation Standards and Requirements 4
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
