Redundant Component DFMEA Severity & Occurrance
  • Thread starter Disciple of Quality
  • Start date
Disciple of Quality
What is the proper SEV & OCC to assess on a component DFMEA, for a component that is redundant at the subsystem level?
Consider a subsystem DFMEA that reflects a high SEV effect of a failure caused by failure of all of the redundant components. It seems reasonable to base the OCC rating of the cause of the subsystem failure on the combined likelihood of failure of all of the redundant components, which would be substantially less than the likelihood of failure of any one of the redundant components.
Since the subsystem relies on each component to back up all of the others, it seems reasonable to characterize the component requirements accordingly; Each component is therefore required to perform a certain function in the absence of all of the others. For this reason, it seems reasonable to cascade the same high SEV from the subsystem DFMEA to the component DFMEA.
The problem is the OCC rating on the component DFMEA. This OCC rating is supposed to be based on the likelihood of the cause of the component failure, which could be substantially higher than the likelihood of the cause of the subsystem failure. It seems that this would tend to drive recommended actions on the component DFMEA, potentially leading to an over-designed component, while at the subsystem level it appears that no recommended actions might be needed.
An example would be a subsystem consisting of five lug nuts (redundant components), a wheel, & a hub assembly (where the hub assembly includes five threaded studs). Consider the subsystem function, "Support the weight of the vehicle at one of 4 corners".
Assumptions
1) The wheel will be adequately retained if any one lug nut is functioning (for simplicity)
2) On the corresponding component DFMEA, the lug nut FM, "Failure to retain wheel to hub assembly" has as it's only PC, "Lug nut threads strip due to USL of the specified lug nut torque range in excess of thread strength" (for simplicity)
3) P(Lug nut threads strip due to USL of the specified lug nut torque range in excess of thread strength) = 10% (just to put some numbers to the example)
It follows from assumptions 2 & 3 that P(Failure of any 1 lug nut to retain wheel to hub assembly) = 10%.
Subsystem DFMEA:
FM: Does not support the weight of the vehicle at one corner
EFF: Corner of vehicle drops to the ground while under way, leading to loss of control & injury or death, without warning
SEV: 10
PC: All 5 lug nuts fail to retain wheel to hub assembly
OCC: 1; P(All 5 lug nuts fail to retain wheel to hub assembly) = 0.01^5 = 1E-8
Component DFMEA:
The lug nut function is "Retain wheel to hub assembly"
FM: Does not retain wheel to hub assembly
SEV: 10
PC: Lug nut threads strip due to USL of the specified lug nut torque range in excess of thread strength
OCC: 7; P(Lug nut threads strip due to USL of the specified lug nut torque range in excess of thread strength) = 0.01
According to the subsystem DFMEA, the design is probably adequate based on OCC = 1. But the component DFMEA seems to suggest that a recommended action is called for, based on SEV = 10 & OCC = 7.
Did I properly assess SEV & OCC in the subsystem & component DFMEAs in the example above? If so, then how should the high SEV / high OCC item be addressed on the component DFMEA? If not, then how should SEV & OCC have been assessed & why?
Bill Ryan - 2007
Welcome to the Cove :bigwave:
I'm afraid I'm not going to be much help to you as I don't have "hands on" experience with DFMEAs. I'm sure some other Covers do and they will, hopefully, chime in. I'm also not the strongest in probability statistics but the OCC ranking of 1 in your subsystem DFMEA just doesn't seem right with a component failure rate of 10%.
Disciple of Quality
The OCC of 1 in the subsystem DFMEA comes from the assumption that all 5 lug nuts must fail in order for the system function to fail. If even one lug nut continues without failing, then the wheel will be retained. Since there are 5 lug nuts, then I think the likelihood of all 5 failing is 1E-8; Therefore OCC = 1.
Admittedly, it is not realistic that one lug nut would suffice, but I hope this assumption will simplify my query, and I think any guidance based on it can be easily extrapolated to more realistic cases, (i.e. wherein more than 1 lug nut would be required to retain the wheel).
smryan ISO 9001:2015 8.6 & 8.5.1.h) - Redundant or different? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R ISO 9001:2015 Transition Quality Manual Update - Redundant Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Device Identification (UDI): How to avoid redundant info? Other US Medical Device Regulations 5
D Redundant BOMs - Maintaining a Reference Only BOM on our Top Level Assembly Drawings Document Control Systems, Procedures, Forms and Templates 7
W Redundant Documents - A version of the document that was in pre-revision status Document Control Systems, Procedures, Forms and Templates 5
J Redundant Checklist for Lean Lean in Manufacturing and Service Industries 12
S Company Scope stating Automotive has been deemed redundant and asked to remove...? IATF 16949 - Automotive Quality Systems Standard 14
E Internal Audit procedure - redundant? Document Control Systems, Procedures, Forms and Templates 9
D Redundant Oversight - Supplier assessment questionnaires Supplier Quality Assurance and other Supplier Issues 5
M Management Review: "Powerful Tool" (ISO 9004 5.6.3) or Redundant Piece of Paper? Management Review Meetings and related Processes 17
F Component maintenance qualification - Regulation (EU) No 1321/2014 Article 5 EASA and JAA Aviation Standards and Requirements 6
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
D Relabelling a component that will be sold as a spare part - Do I become legal manufacturer? EU Medical Device Regulations 2
Anonymous16-2 Dietary Supplement Raw Material/Component Storage and Production Manufacturing and Related Processes 1
S PSW - Requirements for "off-the shelf" component that has multiply manufacturing locations Off the Shelf Item Manufacturing and Related Processes 1
V Process, component or full product re-qualification: leaded to unleaded solder Qualification and Validation (including 21 CFR Part 11) 8
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R When does the FDA consider a component a medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
G Control Plan - Include the processes for each sub component? APQP and PPAP 2
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
M Informational US FDA – URGENT/11 Cybersecurity Vulnerabilities in a Widely-Used Third-Party Software Component May Introduce Risks During Use of Certain Medical Dev Medical Device and FDA Regulations and Standards News 0
D Standard guide for shelf life determination of non sterile component with degradation materials Reliability Analysis - Predictions, Testing and Standards 1
F Component Molding and Over-molding - Handling Resin Inventory Manufacturing and Related Processes 2
S REF and CE mark symbols on multi-component device EU Medical Device Regulations 3
J EC REP information and CE Mark - Component of a system that is not a medical device EU Medical Device Regulations 2
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
R IMDS for double sourced component RoHS, REACH, ELV, IMDS and Restricted Substances 3
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
N FDA Traceability Requirements - Component lots ISO 13485:2016 - Medical Device Quality Management Systems 2
P Electronic component failure analysis turnaround time Reliability Analysis - Predictions, Testing and Standards 0
S Medical Device Supplier Component Qualification Service Industry Specific Topics 0
A Is a Manufacturing Process Sheet required for each Component? Manufacturing and Related Processes 4
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Design FMEA for a component - Should I make the following assumptions? FMEA and Control Plans 7
I Medical device manufacturer and component supplier miscommunication Other Medical Device Related Standards 5
M Methods of reducing/eliminating the systematic component of error General Measurement Device and Calibration Topics 0
B Non Applications in ISO 13485:2016 for component contract manufacturers ISO 13485:2016 - Medical Device Quality Management Systems 3
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
K Biocompatibility Testing - Component Level or Assembled Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 7
S Who compiles the Critical Component List, Insulation Diagram etc.? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
MDD_QNA What is the function of the Critical Component List? ISO 14971 - Medical Device Risk Management 2
M Cleanliness and Contamination question (Medical Device Component Manufacturer) ISO 13485:2016 - Medical Device Quality Management Systems 2
M Component Manufacturer of Food Stuffs Mfg. Equipment Parts - Eat Drink Policy ISO 13485:2016 - Medical Device Quality Management Systems 1
E Updating DHF (Design History File) to include Alternative Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S ISO 13485 Definitions - Medical Device Component Supplier ISO 13485:2016 - Medical Device Quality Management Systems 4
M ISO 13485:2016 - IQ/OQ Requirements applicable to Electronic Component Suppliers ISO 13485:2016 - Medical Device Quality Management Systems 4
MDD_QNA Medical Device PCB component change IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R Is pre-conditioning supplier component before incoming inspection tests allowed? Quality Manager and Management Related Issues 16
