Reference part calibration or verification
I would like to ask you about one issue. In our production we use test station for checking printed circuit board
for corect capacity of condensator. On the begining and on the end of the shift we release this station with reference parts.
We have 3referene part 1-OK, 2-capacity is under the limit, 3-capacity is above limit and station must evaluated correctly.
We check these reference parts 1x/year with measuring capacity 3x, then calculate avarage and uncertainty and check if this is in spcification.
I would like to ask you if this process of checkikg reference parts (measuring capacity 3x, then calculate avarage and uncertainty)
is calibration or verification.
And how we can do MSA for these reference parts.
Thank you for your support.
Martin
Jen Kirley
Quality and Auditing Expert
Welcome Marvin!
I want to better understand how you confirm these reference parts are adequate as verification devices. I am not clear on what industry you supply for, or what standard you are subject to. Can you tell us?
I am also wondering what is your process for checking these reference parts:
  • What is your process tolerance?
  • What are your limits?
  • Can you explain for us what you mean when you say "We check these reference parts 1x/year with measuring capacity 3x, then calculate avarage and uncertainty and check if this is in specification."
Thank you for your help!
Hello Jen,
thank you for your response. We are involve in consume industry according ISO 9001.
We assembled printed circuit boadrs.
At one board we check if capacity of assembled condesator is in the specification. This is done by test station, which measured capactiy.
Nominal value is10nanoFarad, limits are 9 - 11nF.
We have 3 reference parts:
1 - OK part (capacity is cca 10 +/-0,5nF),
2 - NOK part (capacity is less than 9nF, cca 8,0 +/-0,5nf)
3- NOK part (capacity is higher that 11nF, cca 12+/+0,5nF).
With these reference part we do release of the test station. OK part must be evaluated as OK, NOK part must be evaluated as NOK parts.
It means that we have to check if capacity on the reference parts is still according specification.
Therefore we measure capactiy of refence parts 1/year to known if capacity on the reference part is still in specification. This check is done by calibrated RLC meter.
And would like to know if process of checking refenrece part by multimeter is called calibration or verification.
Thank you.
Sidney Vianna
Post Responsibly
From an ISO 9001 perspective, what you propose is perfectly acceptable. The "golden" boards OK and Not OK are being verified, so is the test station. But why an MSA? MSA's are not an ISO 9001 requirement.
dwperron
From what I am reading the reference parts are calibrated when you make traceable measurements of the values of the capacitors on them.
You then are using these calibrated reference boards to perform a verification on the test station.
John Predmore
Measuring your reference parts is verification. If you made adjustments to your test station based on measurement of the reference parts, that would be closer to the idea of calibration.
One measurement system analysis you can do is to measure the reference parts more often than once/year, maybe weekly, and compare separate Statistical Process Control charts of the results for each reference part. I suggest you purposely measure your reference parts at different times of the day, and if you have more than one test station, keep traceability so you know which readings come from which station. When you average your readings now, you lose potentially valuable information about the influence of warm-up time or between different stations. By charting measurements over time, you will see an early warning if the reference parts drift, maybe with air temperature, or there is some unwanted interaction between one reference part and a particular test station.
Thank you. MSA is required by customer. But I do not know how I should do MSA for reference "golden" part.
You don't have to because it's not calibration. It's verification. Explain to the customer you're doing verification and MSA doesn't apply. If they insist, charge them for doing an MSA study, by increasing the price.
Thank you. I will try it. But if MSA will be nessesary, could I ask you how the MSA for reference part should be done?
I Supplier Using Reference Part for PASS/FAIL Inspection Supplier Quality Assurance and other Supplier Issues 8
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C KAPPA index Reference Value for Visual inspection IATF 16949 - Automotive Quality Systems Standard 1
G GD&T applied to reference dimension. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C IVD Metrological traceability without a reference measurement procedure General Measurement Device and Calibration Topics 11
G Need journal and reference of abnormal bar chart SPC Statistical Analysis Tools, Techniques and SPC 4
W Do Reference materials for IATF need to be 17025? IATF 16949 - Automotive Quality Systems Standard 15
W What is okay to use as a reference material for ISO 17025? ISO 17025 related Discussions 4
M SOPs - Reference Documents Section Document Control Systems, Procedures, Forms and Templates 4
B Reference to IEC 60950-1 in Amendment 2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 1
T CSE 5.01 reference on drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
R ASQ reference material clarification - Spiral bound materials allowed in ASQ Exam? Professional Certifications and Degrees 1
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
G Customer complaint over a Reference Dimension Manufacturing and Related Processes 9
G Measure 3 times, for calibration report? Customer Owned Reference Standard General Measurement Device and Calibration Topics 4
I Data Backup Plan - Document Reference ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q How to efficiently and compliantly reference external standards/regulations Other Medical Device Related Standards 2
S Lot assignment for secondary reference standard - Pharmaceuticals Manufacturing and Related Processes 0
V Inspection with 3D Scanning - Reference Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
E Ethylene Oxide Sterilization Validation-Reference Load Other Medical Device Related Standards 8
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Purpose of Reference Section in SOPs Document Control Systems, Procedures, Forms and Templates 6
M Quality Policy - Standards and reference numbers ISO 13485:2016 - Medical Device Quality Management Systems 14
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
S Reference calibration tools (traceable to NIST) that are not used in production ISO 13485:2016 - Medical Device Quality Management Systems 4
S Contract Manufacturer Question - Whether or not the reference to the ex-CMO ISO 13485:2016 - Medical Device Quality Management Systems 6
B Need to convert Reference Only M&TE to a calibration schedule General Measurement Device and Calibration Topics 3
M Looking for Cross reference of AS9100:2016 to ISO13485 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
V QMS / QSR - Reference to Framework - Templates - Procedures for Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
E IEC 60601-2-25 Reference to 60601-1 2nd Edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Visual Inspection with No Visual Reference General Measurement Device and Calibration Topics 2
M AS9100 Rev. D - Can anyone recommend a good reference book? Book, Video, Blog and Web Site Reviews and Recommendations 7
B When to use "For Reference Use Only" on documentation Document Control Systems, Procedures, Forms and Templates 4
G BCARs/EASA to ISO9001/AS9100 cross reference matrix/table wanted EASA and JAA Aviation Standards and Requirements 1
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Use of Certified Reference Materials for Quality Assurance General Measurement Device and Calibration Topics 6
A Reference Source for Polarity Symbol Other ISO and International Standards and European Regulations 1
Q Multiple Quality Standards - AS9100 and ISO13485/9001 Cross Reference Matrix Quality Manager and Management Related Issues 3
E Reference Only on Gage or Visual Aid Calibration Frequency (Interval) 4
F Quality Objective Reference Chart Customer Complaints 4
V Good Documentation Practices - FDA Reference US Food and Drug Administration (FDA) 9
