Definition Reference Standard vs. Working Standard - Differences
Raffy
Hi to everyone,
I'm new in ISO17025 and I was thinking what could be the difference between a reference standard and working standard. :confused:What is the effect in a calibration services if they are using a working standard instead of a reference standard? :frust: Is it a requirement that whenever you calibrate one should refer to a reference standard? Please advise.
Thank you very much in advance for the usual kind attention you will give this request.:thanx:
Raffy:cool:
Jerry Eldred
I've been in metrology/calibration nearly 30 years and I still get confused by some of these terms (and I don't like them very much).
I just looked in the ISO definitions (Guide 99:2007) and found that a reference measurement standard is normally used to calibrate other standards; and a working measurement standard is usually used to calibrate equipment.
However, for most smaller labs, I don't believe this is an issue (in my opinion). I normally (personally) just use the term measurement standard, and select the correct standard to use for a calibration based on adequate accuracy/uncertainty. That is (for most calibration labs) the more important detail: to use an adequate standard for the calibration.
If you need the official definitions, I recommend obtaining a copy of ISO/IEC GUIDE 99:2007(E/F) "International vocabulary of metrology - Basic and general concepts and associated terms (VIM)". This gives the official definition of such terms.
Thanks for this clarification, Jerry! The purpose of a working standard is just that - used for performing the work of calibration. The master or reference standard is used not just for calibration of the working standard, but also those intermediate checks and verifications used to detect any wear/drift of the working items between times of full calibration.......
If you use the same item for both working standard and as the master (which is a bit oxymoronic) then you'll end up using an outside source to supply the intermediate checks, which may add up to more cost than a set of masters....
Ajit Basrur
Reference standard :
Standard, generally having the highest metrological quality available at a given location or in a given organization, from which measurements made there are derived.
Working standard :
Standard that is used routinely to calibrate or check material measures, measuring instruments or reference materials.
A working standard is usually calibrated against a reference standard.
Raffy
Hi Jerry,
Thank you very much for the reply. We have an in-house laboratory. Performing calibration of testers and handlers. But for measuring instrument, we outsource the service provider which, was ISO17025 Accredited. My concern right now is the calibration standard that we must put in our Calibration Certificate. One of our external auditors make a comment with regard to the Method of Calibration. Our Method of Calibration is based on the Original Equipment Manufacturer (OEM) Calibration Procedure. My concern: Is it valid to used such comment that our Method of calibration is based on the OEM Calibration Procedure? Please advise.
Hi Ajit,
Thank you very much for differentiating the meaning of reference standard against working standard.
Best regards,
Raffy
Jerry Eldred
Hi Raffy,
If I understand the question correctly, you are asking only about the correct details to enter in the a Certificate of Calibration in regard to the procedure used.
If it were my Certificate of Calibration, and I were concerned to be sure that I specifically described the method used, I might be a little more specific than just to reference OEM method (although it is very common to do that).
If you want to specifically cover that detail very well, I recommend entering the exact procedure used. If it is the OEM method, perhaps enter the document number and revision date (or revision number/letter). As far as describing method used, this is the most unambiguous description (in my view). This does not guarantee it is the correct or adequate procedure. But in my view, does fully meet the requirement to tell what method is used.
saq2k1
Please don't get confused, it's very simple.
Reference standards and working standards are same thing and reference standards are of higher quality or precision and we use these standards very little whereas working standards are of lower precision and we use them in our daily routine.
Normally, reference standards are used to calibrate the working standards.
:confused: How can they be the "same thing" if they have different precisions and are used differently?:confused:
K
karenchen
How to get the Working Standard ?
Have any methods when I standardize the working standard without the reference standard?
J Frequency of Re-Testing Working Standards (Secondary Reference Standard) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
G Measure 3 times, for calibration report? Customer Owned Reference Standard General Measurement Device and Calibration Topics 4
S Lot assignment for secondary reference standard - Pharmaceuticals Manufacturing and Related Processes 0
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
Q Control of Standard Operating Manuals used as Reference AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Calibration Reference Standard for Mass Weight Calibration General Measurement Device and Calibration Topics 2
J Looking for reference to Electronics Industry's Standard Scrap Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
howste Determining Calibration Uncertainty with Unknown Reference Standard Uncertainty Measurement Uncertainty (MU) 8
F Moisture Analyzer Calibration Reference Standard General Measurement Device and Calibration Topics 7
E Reference Standard for Shelf Life Testing of Packaging for Sterilized Medical Device Other US Medical Device Regulations 3
E Using Customer Unit as Reference Standard General Measurement Device and Calibration Topics 14
L Calibration of Dial Thickness Gauge - What reference standard need I follow? General Measurement Device and Calibration Topics 5
M Reference Standard for Clean Air in Food Production Areas Food Safety - ISO 22000, HACCP (21 CFR 120) 5
R Use of Reference standard in Calibration of measuring Tools General Measurement Device and Calibration Topics 1
R Reference Standard for the Calibration of Dimensional Measuring Tools General Measurement Device and Calibration Topics 2
P MIL colour standard G383 - Looking for a corresponding pantone or RAL reference Various Other Specifications, Standards, and related Requirements 4
N Reference Standard for Acceptance Criteria for Validation of a Reagent Various Other Specifications, Standards, and related Requirements 2
A Definitions in ISO 17025 - Standard reference, Certified reference material, etc. ISO 17025 related Discussions 1
A AS9006 Standard Reference AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C What is reference standard and reference materials as per clause 5.4.5.2 note 2? General Measurement Device and Calibration Topics 1
Manix Automotive Headunit Sizes - Standard Numbers - DIN size with No Document Reference Other ISO and International Standards and European Regulations 2
J Does anyone have information on standard reference DIN 936? Other ISO and International Standards and European Regulations 4
S Does QS-9000 reference a specific drawing standard? QS-9000 - American Automotive Manufacturers Standard 1
M SOPs - Reference Documents Section Document Control Systems, Procedures, Forms and Templates 3
B Reference to IEC 60950-1 in Amendment 2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
T CSE 5.01 reference on drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
R ASQ reference material clarification - Spiral bound materials allowed in ASQ Exam? Professional Certifications and Degrees 1
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
G Customer complaint over a Reference Dimension Manufacturing and Related Processes 9
I Data Backup Plan - Document Reference ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q How to efficiently and compliantly reference external standards/regulations Other Medical Device Related Standards 2
V Inspection with 3D Scanning - Reference Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
E Ethylene Oxide Sterilization Validation-Reference Load Other Medical Device Related Standards 2
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Purpose of Reference Section in SOPs Document Control Systems, Procedures, Forms and Templates 6
M Quality Policy - Standards and reference numbers ISO 13485:2016 - Medical Device Quality Management Systems 14
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
S Reference calibration tools (traceable to NIST) that are not used in production ISO 13485:2016 - Medical Device Quality Management Systems 4
S Contract Manufacturer Question - Whether or not the reference to the ex-CMO ISO 13485:2016 - Medical Device Quality Management Systems 6
B Need to convert Reference Only M&TE to a calibration schedule General Measurement Device and Calibration Topics 3
M Looking for Cross reference of AS9100:2016 to ISO13485 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
V QMS / QSR - Reference to Framework - Templates - Procedures for Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
