Referenced Documents vs. Uncontrolled Documents - Differences?
F
Faith123
How will i classify referenced documents from uncontrolled documents?
What's the difference between the two(2)?
(***wondering... ***thinking.... whew! still can't convinced myself with the thoughts running in my head)
Hope someone could clearly differentiate my inquiries between the two....
Lots of Thanks,
Faith
F
fireonce
Re: Difference between Referenced and Uncontrolled documents?
A referenced document,I think, is totally or partly mentioned in some documents of your QMS,such as manual, procedure,etc.If you want to see it, you can find it easily and quickly.
An uncontrolled document is out of your QMS.
Helmut Jilling
Auditor / Consultant
Lots of Thanks,
Faith
It should be noted, the standards do not mention "Reference" documents as a category. It simply says documents used for your quality system must be controlled.
Therefore, "Reference" documents are an idea many companies have basically invented. No formal definition, so let's do a process of elimination to determine a definition.
Important documents for the QMS must be controlled. So, if it is necessary for a document to be accurate, current and approved, it should probably be controlled. That control would include controlling distribution.
I recommend that if a document meets those 4 criteria, they should be controlled. If it doesn't meet those criteria, it can be "not controlled."
"Not controlled" is generally marked as "Uncontrolled" or "Reference Only." There is really no distinction between those two, unless you create the distinction in your QMS. Docs either are being controlled, or are not.
P
potdar
I agree and I differ.
A controlled document is well defined by you. By controlling distribution, the controller is taking a guarantee that any copy stamped as 'controlled' will always be accurate, current and approved.
An uncontrolled copy basically means that there is no such guarantee given by the controller.
Reference documents are not defined in the standard. Unless otherwise defined in your QMS, they are taken to mean documents which are external to your QMS, which are not approved by you but there are cross references to them in your QMS. Simplest example - ISO 9001:2000. The controller needs to ensure that these are correct and up to date.
Ajit Basrur
Potdar, I agree to both your individual "agree" and "disagree"
CliffK
The theory behind, and appeal of, the reference document is that it can somehow exist outside the document control system. If there's a big stack of documents to be brought under control, the reference document approach can be very appealing indeed, as it seemingly avoids a lot of work. Just stamp the whole stack "for reference only," and you're done.
The danger lies in sticking reference labels on documents that actually describe the product or the manner of work. Documents of this kind need to be controlled because the absence of control has consequences.
For example, I know an organization that maintained several binders of "reference only" cable drawings in their manufacturing area. The absence of control caused them to build one cable incorrectly repeatedly. Each time the mis-wired cable caused a field failure. The cost of remedying the field failures was far greater than the cost of putting the documents under control would have been.
SteelMaiden
What is YOUR definition of a referenced document, Faith?
Here, referenced documents are controlled, because they are referenced as needing to be used as a part of the process. "perform testing per ASTM XXX"
An uncontrolled document might be an owners manual for some piece of equipment, or a user's guide for software. Something that comes from an outside source and there is a) little chance that there will be a revision, b) little chance that a revision would affect our process, c) something we would use as a guideline but probably "tweak" to meet our requirements d) a printed copy of our electronic document(s).
It all depends on your definition. As stated earlier, ISO 9001 does not define a reference document within its document control requirements.
andygr
Something that seemed so simple at first has me thinking now.
Referance- This is the outside basis on which you created a design, document, ect.. You’re identifying supporting data, process, information that you are not recreating/validating and using it as the basis for you’re your design, process ect.
The real crux of the mater is if this “reference” maintains any control over what you created. For example- I can extract knowledge in the form of information, formulas extra from references and include them in my internal document with out identifying the basis for how I came up with my Wild _ss Idea ( this is your education ). If the sole basis for control of the item being produced is my design/document (if the information in the references changes I would not be required to revalidate my design) then I would say that the reference is uncontrolled and should not be even be identified so to not imply that it is the basis for anything being presented.
I can not see offhand how you could honestly say that what you do is truly unique and fully self validated in most manufacturing situations and so you identify references as the basis for some aspects as the basis for your design/document. Since these sources have been peer reviewed and accepted then you save yourself some work from proving that these practices are appropriate and correct. You give them credit and include them in your document as references and once you do this then have to treat them as controlled and ensure that they in the future do not undermine the basis for your work.
:2cents:
METerry
It is a great resource to be able to read all of your postings and I thank each of you for allowing all of us to "listen in". This may or may not be off the subject, at least slightly, but how does the defined "referenced" or "reference" document relate to "documents of external origin"?
As and example, we maintain operation and/or repair manuals for equipment, and in this case let's use a gear reducer manual produced by the manufacturer of the gear reducer. We are told that this is a "document of external origin" and that we must periodically contact the manufacturer to be sure we have the most current document. This discussion makes me question if it would be better considered a "reference document".
P
potdar
What you have talked about is a document of external origin that is being used as a reference document. Here you need to have the correct document available with you. The correct document is not necessarily the most uptodate one.
If your gear box is of 1982 vintage, and since then there have been 15 modifications introduced in the design by the manufacturer, you still need the document relating to the 1982 model. If you uhave upgraded your model in 1994, you should also upgrade your reference document to suit the equipment now available with you. It is now required to tell you how to maintain and operate the upgraded version. The manual for 2007 model is irrelevant.
R Para 4.2.2 b) Referenced Documents - Adequate referencing? Copy and Paste? ISO 13485:2016 - Medical Device Quality Management Systems 5
JoCam Issue Dates/Revisions of Standards referenced in Internal Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Referenced Documents Requirements - Pointing to a specific revision level Document Control Systems, Procedures, Forms and Templates 3
E Reference Document Content and Referenced Documents Document Control Systems, Procedures, Forms and Templates 3
M Referenced Standards and/or "State of the Art"? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Is referenced content sufficient to meet record content requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Identifying externally provided services referenced by IATF16949 IATF 16949 - Automotive Quality Systems Standard 2
D Job Titles referenced in Procedures IATF 16949 - Automotive Quality Systems Standard 18
M 4 Datums Referenced in a Print (Drawing) Feature Control Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M What are FDA expectations regarding Standards referenced in the 510(k)? US Food and Drug Administration (FDA) 3
D Must Forms be referenced in applicable Procedures? Supplier Quality Assurance and other Supplier Issues 6
Marc Facebook Profiles Now cross-referenced with retail purchases! After Work and Weekend Discussion Topics 3
M Definition of "the label" as referenced in Annex I (13.3) of MDD 93/42/EEC EU Medical Device Regulations 3
D MSA Requirements for Equipment Referenced on Control Plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
Q Threads for Knurls referenced on drawing - German standard DIN 82 Other ISO and International Standards and European Regulations 3
J Cable and Harness Marking - Standard referenced on a cable drawing Design and Development of Products and Processes 14
C Standards referenced in ISO 3834-2 Welding Other ISO and International Standards and European Regulations 9
J True Position with only 1 Datum - Referenced datum is the plane the hole is on Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
W Where to buy referenced standards - ASQ Biomedical Auditor Certification - CBA exam Professional Certifications and Degrees 1
K Where do I access DCX Standards referenced in Chrysler Catia notes? Customer and Company Specific Requirements 8
S How Reliable are Published Methods (ASTM,FDA) when referenced in a lab? General Measurement Device and Calibration Topics 12
M Are Medical Policies referenced in the Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Lock-out Tag-out does is have to be a procedure in QS or can it just be referenced ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
Q MDD inclusion in Quality Policy - MDD Annex 5, 3.2 was referenced ISO 13485:2016 - Medical Device Quality Management Systems 3
C Simple four-box process model - Referenced in ASQ Process-based auditing course General Auditing Discussions 5
S AIAG's Control Plan Reference Manual - GONE from TS 16949 as a referenced document? IATF 16949 - Automotive Quality Systems Standard 9
D Quality Manual - Where the cross referenced procedures fit in? Quality Management System (QMS) Manuals 4
I Are all your forms referenced at least once in your procedures? Document Control Systems, Procedures, Forms and Templates 5
D Revising Forms referenced in the body of our procedures Document Control Systems, Procedures, Forms and Templates 10
M SOPs - Reference Documents Section Document Control Systems, Procedures, Forms and Templates 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
M Documents to be included in 1.3 Material check in PPA report APQP and PPAP 4
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
T Sharing SharePoint Documents Document Control Systems, Procedures, Forms and Templates 4
M Retention period of documents and records ISO 13485:2016 - Medical Device Quality Management Systems 1
D Offsite storage of QMS documents ISO 13485:2016 - Medical Device Quality Management Systems 9
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A QMS Overhaul - Reorganizing and Renaming Documents - Internal References Document Control Systems, Procedures, Forms and Templates 24
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
D DQ documents of new equipment - Function specification Qualification and Validation (including 21 CFR Part 11) 0
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Device Labeling - Medtronic Ventilator Files (Risk Management documents) Coffee Break and Water Cooler Discussions 2
qualprod To set frequency to review documents in ISO 9001 7.5? Document Control Systems, Procedures, Forms and Templates 13
S Mandatory documents vs shall "something" but without mandatory documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
I Reissuing documents due to missing version / issue numbers Document Control Systems, Procedures, Forms and Templates 3
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
