Refreshing an old and boring topic - Job descriptions and Roles vs Process Documentation
Sidney Vianna
Post Responsibly
#21
The audit was going slow, as the MR did not understand the requirements.
Is this a non-conformance or no?
Under the assumption that you are conducting a 3rd party audit...the issue to me is NOT that the audit is going slow, but the implication that the organization has nobody with the KNOWLEDGE (and, thus the competence) to ensure their system complies with ISO 9001. It is NOT the job of the 3rd party auditor to ascertain the system complies. It is THE ORGANIZATION's responsibility to do so, prior to offering the system to an external party's assessment to verify the conformance to the standard. If the organization does not have anyone with the KNOWLEDGE required to develop and maintain a system in conformance with the standard, they OBVIOUSLY have a BIG PROBLEM. In the ANAB Bill of Rights & Responsibilities, they state, appropriately: "...The client organization, not the certification body, has the responsibility for conformity with the requirements for certification. .."
The issue is much graver than simply complying with the job description; it is the lack of a fundamental competence in the organization. Based on what I understood, this seems to be a clear violation against 9001:2015 5.3.a), 7.1.2 and 7.2.b).
Kronos147
#22
What does "versed" mean?
The job description was more specific. It's been a while but I recall something similar to "completed a course..." and "5 year experience of relevant experience".
Whatever the specifics of the job description, it just wasn't verifiable with this person
Under the assumption that you are conducting a 3rd party audit...the issue... the organization has nobody with the KNOWLEDGE (and, thus the competence) to ensure their system complies with ISO 9001.
I agree.
Sidney Vianna
Post Responsibly
#23
I understand that, but, if you write up the nonconformity against lack of compliance with the job description, then, their "corrective action" could be to delete the requirement from the job description. And then, what? The fundamental problem of not having someone at the organization with an understanding of ISO 9001 STILL EXISTS.
Kronos147
#24
That is why the organization will have to submit an action plan including the root cause. The assessor should not accept a plan that addresses correction without cause. What was the cause that would to lead to a correction of deleting the requirement in the job description?
One thing the organization may consider is they may have an issue with change control. They may have an issue with hiring. They may have an issue with training.
Findings are simply symptoms of the larger issue.
Sidney Vianna
Post Responsibly
#25
The CB auditor HAS to PROPERLY identify the problem. The organization has a FUNDAMENTAL competence missing in their rankings.
Just to play the game that you suggest, organization could list the cause of the problem as: misunderstanding that job descriptions were necessary. Corrective Action: eliminate all job descriptions.
And then, what?
Kronos147
#26
Actually, the auditor has to confirm that the objective evidence reviewed meets the requirements of ISO 9001, the customer, where known, and the organization itself.
The organization has an internal requirement (from Job Description) - MR has to have experience or training. NC - He did not.
And then, what?
I wouldn't accept that root cause. It is almost a restatement of the problem. I would ask the organization "why did you misunderstand the job description."
Sidney, please let me know if I should drop this right here. It seems we may be at the point that we agree to disagree. There is enough stress in the world. If I am being less than helpful, I should refrain.
Respectfully,
Kronos
P.S. in the thread about "what should be changed in the next ISO 9001?", I should add please bring back the requirement for an organization to have a documented method as to how it will determine root cause. That was a bad decision to take that out, IMO.
Sidney Vianna
Post Responsibly
#27
Either one of us can "drop" the exchange anytime. From my perspective I see this as an exchange of ideas and I am trying to make a point that CB auditors have to ADD VALUE to their work by being able to CLEARLY IDENTIFY the problems/weaknesses/nonconformities during the audits, so the registrant can work on a meaningful solution.
Linking the problem to a "requirement" in a job description just adds to the much maligned misconception that ISO 9001 is achieved via the say-what-you-do-do-what-you-say baloney.
Implementing a system (any system) requires knowledge. Lack of knowledge is lack of resources. The fact that a job description loosely requires such knowledge is totally redundant and we all should know that the first step in problem resolution is the CLEAR identification of the problem.
Ralba
#28
My 2¢, the "Job Description" serves a role at two different points.
  • First, it is a record of the criteria used to hire or promote someone for the job described, which both provides a very soft guarantee of their capability and protects the organization from accusations of incompetence by having a record.
  • The other is to track the functions performed by each job/person in the organization and make sure none are left un-owned in the case of filling a newly vacant position.
The first is a hard requirement for most standards, the second is just darn useful. Note that it can only be really serve both purposes if your revision system allows for intact old revisions. By updating the job description at each annual/regular review, you can make sure the trifecta of Responsibility/Authority/Recognition is intact across all jobs and make sure nobody is getting overloaded with too many responsibilities. It is pretty common to see someone hardworking get overloaded with various tasks because they are just so darn eager or good at everything given to them that their name comes up every time a task is needing an owner.
"You know who would be great for this? XXXX, she has great attention to detail, an eye for quality, and..." ect ect
Peter Fraser
#30
Sounds like a big RASIC.
I prefer RACI, but what is in an extra letter! Best to avoid ARSCI, though!
If you define your processes using RACI (or similar) and hold the details in a database, you should automatically be able to generate a Role Involvement report which picks out all the tasks in all the processes where a selected role is involved (if you can also limit it to those tasks for which the Role is (only) Responsible then you are closer to what might appear in a Job Description). Whether this corresponds to what HR think that the job entails is another matter entirely...
It also means that as soon as you update any Process Description, the Role Involvement report is updated at the same time. Even better if you can flag up the competencies required for each task, and the risks identified for each task. Just another couple of ways to analyse your process definitions.
A "Refreshing" a Company Ideas scheme Lean in Manufacturing and Service Industries 8
C Refreshing Class II Exempt Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P Refreshing Graphs and Minitab Templates Using Minitab Software 5
M Why are EU harmonized particular standards so old & out-of-date? IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
Q New QMS...Old Projects ISO 13485:2016 - Medical Device Quality Management Systems 5
M Old Master Schedules - How Long to Keep? Document Control Systems, Procedures, Forms and Templates 4
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
I Old Time Scatter diagrams for defect type and location- software Quality Tools, Improvement and Analysis 7
Q Old products new class - Dental Devices - Choosing tests EU Medical Device Regulations 2
K Old medical devices -> 7.3.7. Design and development validation ISO 13485:2016 - Medical Device Quality Management Systems 1
M Interesting Discussion Curious old drawings about electrical shock and safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Marc Interesting Discussion The periodic table is 150 years old - March 2019 Coffee Break and Water Cooler Discussions 3
Marc Old Registered Visitors "Pruned" from the Database - 20180916 Forum News and General Information 0
Marc 200-year-old museum in Rio de Janeiro Destroyed by Fire - 2 SEPT 2018 World News 2
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
Marc Adventures in Design Quality Assurance - Two-week-old Pixel 2 XL displays World News 0
A Training Program Help - Old docs, new docs, so many docs... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Canada License Amendment - Old Product to New Product Canada Medical Device Regulations 2
B Old GD&T Symbol "~" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L Sources for Searching Old Electronic Parts Specs (Counterfeit Inspection) Quality Manager and Management Related Issues 3
Q Modifying an old printed record? ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Customer wants PPAP on Old Parts to New Standards APQP and PPAP 8
A Technical File Maintenance - Old generation product EU Medical Device Regulations 4
A PUWER (Provision and Use of Work Equipment Regulations) and old machines (UK rules) Occupational Health & Safety Management Standards 4
E I'm looking for old publications of European Quality in pdf Book, Video, Blog and Web Site Reviews and Recommendations 2
J How to Retrofit an old, manual CMM Calibration and Metrology Software and Hardware 5
C Upgrading an old Supermicrometer General Measurement Device and Calibration Topics 3
S Old Medical Device Software Submission Guidance from 1998 Other US Medical Device Regulations 8
G Not quite old news: Statement of Applicability IEC 27001 - Information Security Management Systems (ISMS) 3
R IMDS time frame submission for a very old product APQP and PPAP 1
M Old software and EN 62304 - ECG software for the display of ECG IEC 62304 - Medical Device Software Life Cycle Processes 2
W Where to find the Daimler DBL 6992 10 new (old) standard Customer and Company Specific Requirements 1
P Performance Qualification of old Rapid Mixer Granulator Qualification and Validation (including 21 CFR Part 11) 2
Q IQ Requirements for Old (10 yrs) Commissioned Equipment Qualification and Validation (including 21 CFR Part 11) 2
R Covegratulations to The Cove: 18 years old! Covegratulations 3
N FDA Aspects - No Improvements to 12 Year Old Software ISO 13485:2016 - Medical Device Quality Management Systems 4
T Software that will overlay Old Revision and New Revision Print and Compare Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Old MSDS Sheets vs new HCS Standard - Format Requirements Manufacturing and Related Processes 18
H Digging Up Bones - Inspector Retrieving Very Old Inspection Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
V Old 510(k) with no Indication Statement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
K Retrospective DHF for an old non-registered device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
F Receiving a new Gage Block Set with an old Certificate Calibration Frequency (Interval) 3
Randy Looky here - Check out my 9-month old Great-Grandson Hayden Coffee Break and Water Cooler Discussions 4
G Help with an old Spectrum 1000BX FTIR unit - User Manual wanted Manufacturing and Related Processes 2
M AS9100A (old revision) - Required C=0 sampling plans if sampling was used? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Using Curve Fits and Predictions in place of good old Measurements General Measurement Device and Calibration Topics 3
N What to do about very old MSDS Sheets Occupational Health & Safety Management Standards 24
C Hazards of Old Electronics Quality Manager and Management Related Issues 9
D Registrar Requesting Copies of Old Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
V We put Old plating spec on supplier prints and need to PPAP to Customer. APQP and PPAP 1
