Regarding design and development requirements for a medical device
Let's say that for a medical device that I want to put in the EU market I will buy the parts A and B outside the EU market, and attach them together to make my final medical device (basically the parts would be purchased according to specifications and only a simple assembly would be done in a EU country).
Would this be considered manufacturing a medical device, considering I'd be purchasing parts A and B already finished and only putting them together? (they dont' work independently)
What would the design and development requirements look like in said product, provided the original design for the product would not be mine? Could the company producing parts A and B be classified as a supplier (they manufacture these parts for other companies in other non-eu countries)?
I was expecting that I'd have to specify design and development for the final product, including specifications for the parts A and B to which the supplier would have to comply, but don't know how it would be possible to comply with design and development for each part (since I don't have access to that data).
Thank you
You might want to take a look at EUMDR article 22. With the information presented, it sounds like you might have a "procedure pack":
Thank you for your reply. I'm aware of the different definitions, but I don't think systems and procedure packs apply because neither part A or B are a medical device of their own or are CE marked. I could be wrong though.
I can give the example of an eletrical toothbrush to try to clarify further what I meant: combine the motor part and the brush part to make the final product. A company overseas produces both parts, but lets imagine a toothbrush in EU would be a medical device and in the other countries it wouldnt. I'd be buying the motor part and the brush part and assemblying them in EU. It's more or less what would happen in this case.
EmiliaBedelia
You might want to take a look at EUMDR article 22. With the information presented, it sounds like you might have a "procedure pack": EUR-Lex - 02017R0745-20200424 - EN - EUR-Lex
It's not a procedure pack because the manufacturer is assembling the components together to create a device. A procedure pack is individual devices that are all used in one procedure packaged together. If the electric toothbrush and a floss pick were being packaged together then... maybe. TBH I think these situations add a lot of complexity so if you don't strictly have to be a procedure pack/system I would not suggest it.
Yes, you are manufacturing a device. Many, many manufacturers do not make devices in house and only assemble purchased components.
For design and development, you need to specify what the requirements are for the components and how you know that the components you selected meet those requirements. You would need some kind of verification testing to show that your assembled device meets the requirements you have set out. Even if you are not specifying all the details of HOW exactly it is designed, you need to empirically show that it meets your requirements in the context of YOUR intended use.
To continue in your example, let's say you have decided you want to manufacture a toothbrush for adults. Your (overly simplified) requirements are: brush head of 1 cm, 100 oscillations per second, materials are biocompatible, device lifetime is 5 years using it 2x/day, meets electrical safety requirements. None of those specifications would require detailed information about the design/development. Your job is to explain how you came up with those requirements, and show through V&V that the components (Brush Head A and Motor B) meet your specs.
The company producing parts A and B is, by definition, a supplier, if you are purchasing the parts from them. Reference ISO 13485 and MDR article 10 point 9(d) and point 15 for more information on supplier controls and purchasing - if someone else is making stuff for you, you need to do some due diligence to ensure that the supplier is good, and that the materials they provide to you meet your requirements for performance and for safety/quality. FWIW, if you are going to be working with a supplier to make medical device components, they will probably need to provide you with more information than they might generally provide for non medical applications. This is a part of supplier controls - if the supplier is not willing to cooperate with you and provide the information you need, they are not a suitable supplier (or, you need to figure out another way to sufficiently control their activity).
Ed Panek
QA RA Small Med Dev Company
I agree with Emelia. It also depends on your claims. After you combine these parts, what are you claiming it can do?
All these replies are very very helpful, thank you Emilia and Ed. What Emilia set out in a very simplified manner is thankfully what was already planned. Find a suitable supplier that would be willing to cooperate with the needed information, and through validation and verification show that the requirements for the device and its intended use are met, even if the design part is not exactly specified (as I don't have the design details for those parts)
So basically I'd have to set out supplier controls for the parts, and then the design requirements would relate obviously to each part to confirm that they do meet the requirements I've set out, and to the claims established to what the final device can do.
Zero_yield
"You can observe a lot by just watching."
Yup, thanks for the correction, Emilia. I honed in on the "I'd be purchasing parts A and B already finished and only putting them together" and missed the part about assembly. I was incorrectly thinking you'd just be putting them in a combo pack together (i.e., here's a needle AND the correct tubing to go with it).
D Confusion regarding design responsibility - What can arguably be excluded? Design and Development of Products and Processes 10
D What are the rules regarding coverage in internal audits? IATF 16949 - Automotive Quality Systems Standard 1
D What are the IATF rules regarding doing internal audits remotely? IATF 16949 - Automotive Quality Systems Standard 2
A Question regarding new VDA_AIAG fmea approach for process FMEA FMEA and Control Plans 0
H Regarding Double Insulation & Caution Symbol on Product according to IEC 61010-1 CE Marking (Conformité Européene) / CB Scheme 6
H Regarding UL Certification CE Marking (Conformité Européene) / CB Scheme 6
J Question regarding classification of custom made device EU Medical Device Regulations 5
H Regarding EAC-MED mark Other Medical Device Regulations World-Wide 0
I Request for information regarding remote medical monitoring software (its technical documentation and the IUD system) IEC 62304 - Medical Device Software Life Cycle Processes 2
S Question regarding AQL - ISO 3951 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
H Regarding compliance according WEEE Directive CE Marking (Conformité Européene) / CB Scheme 6
H Regarding Recycling symbol (The Mobius Loop) applicable for the given materials REACH and RoHS Conversations 4
H Regarding Usability Engineering File according to IEC 62366-1 CE Marking (Conformité Européene) / CB Scheme 2
H Regarding external surface temperature limit requirement for lab incubators. CE Marking (Conformité Européene) / CB Scheme 2
H Regarding the validity of EMC & Safety test reports without NABL & ILAC-MRA mark. CE Marking (Conformité Européene) / CB Scheme 2
H Regarding EMC & Safety retesting requirements of the product CE Marking (Conformité Européene) / CB Scheme 2
D Question regarding PCR workstation Fume Hood upon first use ISO 13485:2016 - Medical Device Quality Management Systems 0
H Regarding confusion of the validity of the European implementation of IEC standards Other Medical Device Related Standards 1
H Brexit Regarding differentiation of CE & UKCA CE Marking (Conformité Européene) / CB Scheme 8
D ISO 13485--Question regarding performing calibrations in house. ISO 13485:2016 - Medical Device Quality Management Systems 13
L Question regarding "Customer Property" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
T Noob question regarding sample size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Ron Rompen Question regarding CMM probe damage General Measurement Device and Calibration Topics 4
D Question regarding where "validations" fit according to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
Azaarus Help with CAPA for an IATF finding regarding inspection documentation IATF 16949 - Automotive Quality Systems Standard 10
lanley liao Questions regarding the change of critical suppliers and key personnel Oil and Gas Industry Standards and Regulations 5
H Existing cloud based medical device - questions regarding improving the processes IEC 62304 - Medical Device Software Life Cycle Processes 6
Azaarus Looking for important points regarding First Piece Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 3
D Question regarding "storage and distribution" ISO 13485:2016 - Medical Device Quality Management Systems 1
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 16
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
M Seeking advice regarding use of off-the-shelf (OTS) batteries Other Medical Device and Orthopedic Related Topics 4
K Supply Agreement Regarding MDR 2017/745 - Manufacturer-supplier cooperation Other Medical Device Related Standards 0
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
dgrainger Informational Additional Guidance Regarding the Vigilance System as outlined in MEDDEV 2.12-1 rev. 8 EU Medical Device Regulations 1
M Informational EU – MDCG 2019-7 Guidance on Article 15 of the Medical Device Regulation (MDR) and in vitro Diagnostic Device Regulation (IVDR) regarding a “person re Medical Device and FDA Regulations and Standards News 7
J Any diverging opinions regarding audit findings or conclusions must be resolved no later than the closing meeting ISO 13485:2016 - Medical Device Quality Management Systems 13
M Informational Team-NB published a press release regarding the survey run among its members to analyse the certificates being issued Medical Device and FDA Regulations and Standards News 0
P Regarding lifetime of a Medical Device EU Medical Device Regulations 7
A Query regarding MS Excel usage Excel .xls Spreadsheet Templates and Tools 2
M Informational Team-NB published a press release regarding the capacities of notified bodies to meet the sector needs Medical Device and FDA Regulations and Standards News 0
M Medical Device News Team-NB publishes a press release regarding the designation process in the framework of the IVDR regulation – Regulation (EU) 2017/746 Medical Device and FDA Regulations and Standards News 0
O Guidance Regarding Career In Health Information Management Career and Occupation Discussions 0
T Information regarding Nanomaterials in Medical Devices EU Medical Device Regulations 6
M Medical Device News FDA Guidance - UDI: Policy Regarding Compliance Dates for Class I and Unclassified Devices and Certain Devices Requiring Direct Marking Other US Medical Device Regulations 0
