milagre
Hello everyone,
In 60601-1, subclause 9.7 is applicable to "Pneumatic and hydraulic parts." I am trying to determine how the standard defines pneumatic.
Definitions for the word pneumatic can vary significantly from "containing gas under pressure," to "using air pressure to move or work."
My device is a neonatal CPAP. The "pneumatic" system in our device mixes air and oxygen together and then gives it to the patient. "Pneumatics" do not assist in the motion or support of our device (although I guess you could make the arguement the gas does some "work" in the lungs).
The easiest and perhaps intended way to define pneumatic is to go off of the 9.7.1 ("General") contents. Here, it says:
Of course, my CPAP device would have an unacceptable risk if tubing ruptured, as the device would lose essential performance of providing air to the patient.
My question:
Should my path forward be to show that the tubing cannot rupture in normal or single fault conditions? This is true, but the phrasing of 9.7.1 seemed to imply that any rupture, even beyond single fault conditions, would have to be considered. Maybe that is only my inexperience talking.
I looking forward to hearing opinions on this matter.
The requirements of this subclause apply to vessels and parts of ME EQUIPMENT subject to pressure, the rupture of
which could result in an unacceptable RISK.
You could use this statement to define "pneumatic" as any part subject to pressure that would result in unacceptable risk if it ruptured.which could result in an unacceptable RISK.
My question:
