Registration requirements for custom branded device
Here's our situation:
  • We are a US-based LLC that sells a custom-branded, 501(k) exempt, Class I medical device for the skincare/beauty industry.
  • Our Chinese manufacturer applies our branding & labeling to the device & packaging. They ship the final packaged product directly to a third-party logistics provider's (3PL) warehouse in the US that fulfills orders from our online store.
  • Our Chinese manufacturer is probably private label manufacturing for other companies as well.
  • Our Chinese manufacturer is registered as a Foreign Exporter establishment with the FDA. The device is also listed and associated to their establishment.
My questions:
  1. Do we need to register ourselves with the FDA? If so, as what? An initial importer?
  2. Who should be responsible for the UDI registration/labeling requirements—we or the manufacturer? Especially if the manufacturer does private label manufacturing for other companies/brands.
I've read similar discussions on the board and am left more confused than when I started. Thank you for your help :)
I'm particularly confused by the difference between a wholesale distributor and an initial importer.
From 807.3:
(g) Initial importer means any importer who furthers the marketing of a device from a foreign manufacturer to the person who makes the final delivery or sale of the device to the ultimate consumer or user, but does not repackage, or otherwise change the container, wrapper, or labeling of the device or device package.
(t) Wholesale distributor means any person (other than the manufacturer or the initial importer) who distributes a device from the original place of manufacture to the person who makes the final delivery or sale of the device to the ultimate consumer or user.
gogreen
"Wholesale distributor" is both broader and more specific than "initial importer." WD is broader because it doesn't only apply to devices from foreign manufacturers; rather, WD includes distributors who purchase from US-based manufacturers. On the other hand, WD is narrower in that it only applies to, well, wholesale distributors, i.e., to distributors who distribute from original place of manufacture to the ultimate consumer. For example, distributing from the original place of manufacture to a reseller is not a WD. Unlike WD, an II is not limited only to distributors--"furthers the marketing" is broader than just distribution. II can be importing from all sorts of foreign establishments, such as relabelers and foreign exporters.
Frankly, understanding the above distinctions are probably less helpful than simply understanding that, if you qualify as an initial importer, you are not a wholesale distributor because of the carveout in the definition of WD. You would follow the II requirements.
Going back to your original post, you may be a relabeler. You stated the manufacturer applies your labeling, which sounds like you are changing the "content of the labeling" and going beyond merely adding your own name. The UDI is part of the label. My understanding is if you supply your own UDI, you are a relabeler. If it is the manufacturer's UDI, and you don't change the content of the labeling, you may not be a relabeler.
In either case, you may also be the initial importer. When you register your establishment, you would select "yes" when asked "Does this facility import medical devices to the United States from outside the U.S.?" If you are also a relabeler, you would then check the box for "Repack or Relabel Medical Device" under "Select all of the following activities that you perform at this facility."
gogreen
Based on your description, we're an initial importer AND a relabeler. Thank you!
Since this conversation, I've actually looked into this further. Having your own UDI (and thus being the labeler (small "L") under UDI), does not automatically make you a Relabeler. In your case, where the manufacturer puts the label on, you can register as the initial importer only.
What if the manufacturer applies your particular branding (alongside your UDI)? Does that cross the threshold of being a relabeler?
monoj mon
NO.
If you are talking about registration and listing, then I think there are some confusions going on around here. According to your definition, in my opinion
1. Your Chinese manufacturing partner is 'NOT' the 'Manufacturer'. They are the 'Contract Manufacturer'.
2. You are 'NOT' the 'Initial Importer'. You are the legal 'Manufacturer' as your brand name is on the device label.
3. Your 3PL is the 'Initial Importer'.
4. Either 'Manufacturer' or 'Contract Manufacturer' can put their UDI on the device labels.
5. Since the Chinese company is putting your brand name on the device label already, I assume you are not changing anything on the original content of the label. Then in this case no one is Re-labeler. If you are changing anything, then Register yourself as 'Manufacturer, Re-labeler'.
6. If your Chinese Partner has listed their facility only as 'Foreign Exporter', then you might run into trouble in the future when the 'FDA' starts looking for the 'Actual manufacturing site'. It has to be clear at the registration and listing database, where the device is physically manufactured and who is the 'legal manufacturer' of the device.
If you are okay with disclosing the information about the Chinese partner then just write on the label,
Manufactured By,
Your Chinese partner name and address
Manufactured For,
Your company name and address
gogreen
NO.
Manufactured By,
Manufactured For,
I have to disagree with much of what you said. Your opinion just stated that all private label distributors are manufacturers. This is not correct. You may be confusing some concepts in the UDI regulations, 21 CFR Part 830, where the concept of "labeler" is entangled with the concept of "manufacturer," but that does not automatically mean all labelers are manufacturers. Alternatively, you may be referring to the definition of "Manufacture, preparation, propagation, compounding, assembly, or processing" under the Registration and Listing regulations, 21 CFR 807.3(d), which includes Relabeler. At the same time, Initial Importer is also included under 807.3(d), and you point out that as a separate concept, so I can't fully put my finger on where you are getting your conclusion. Either way, having your brand name does not automatically make you a Manufacturer for registration and listing purposes.
With respect to "Contract Manufacturer," can someone be a Contract Manufacturer without being a Manufacturer? Not sure these are mutually exclusive.
With respect to the 3PL, they can be the Initial Importer if they are the Initial Importer, i.e., they meet the definition. In fact, 3PLs are often not the Initial Importer; rather, in Private Label Distributor (PLD) situations, the PLD is the Initial Importer, and only the Initial Importer because, well, again, they meet the definition. 3PLs, for the most part, handle the freight and customs responsibilities. 3PLs are not typically chomping at the bit to register with the FDA and carry out medical device reporting responsibilities. Why would they?
Looking at this from a totally different angle, we can get to these same conclusions without going through all this rigmarole. Who is (actually) manufacturing the finished product and putting the label on? Is Anon's company doing anything to the product or changing the label? Who is importing and furthering the marketing of the device in the United States?
Your solution regarding putting the manufacturer on the label is probably not viable. As you likely know, many PLD's are protective of their manufacturers.
monoj mon
My entire discussion was based on the assumption that Anon's company has provided 'specification' based on the word 'custom-branded'. May be my sentences looked generalizing and incorporating all the 'private label distributors' under the umbrella of 'Manufacturer'. But, you are right, that's not correct.
This assumption has also led me to believe that the 'Chinese partner' has 'contract manufactured' the 'Customized' product using Anon's specification.
Now, looking again at this sentence, I have realized my answer might not be correct. I beg your pardon for that.
Yes, assuming the Chinese partner contract manufactured based on Anon's spec., that's why I said
These are, of course, not mutually exclusive. I was giving an example to sort out the registration listing issue, which of course is not the only way to handle. In my first-hand experience, some of our US clients (for whom we 'contract manufacture' the devices) do not physically manufacture the device at all, but they list their facility as 'Manufacturer, Specification Developer'. They provide us the specifications, owns the design files, receives the complaints and initiate corrective actions when needed. I know this contradict with the following definition, but in practical people are practicing this way to clearly state who takes the 'legal responsibility' for the device.
Definitely, ultimately they will need to evaluate each of their roles and responsibilities.
gogreen
That does make more sense now. Thanks for clarifying. I'd love to hear about your experiences as a contract manufacturer at some point.
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
M Mexico Medical Device Registration Requirements Other Medical Device Regulations World-Wide 1
M CE Mark and 510(k) -Global registration requirements for every country Other Medical Device Regulations World-Wide 3
C FDA Registration Requirements for Multiple Sites 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
S Private Label Requirements, Manufacturer's Registration & Initial Importers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Latest (2019) requirements for MD registration in Kazakhstan (Eurasia region)? Registrars and Notified Bodies 0
H REACH Registration Requirements - Who is required to Register REACH and RoHS Conversations 1
D Global market registration requirements for IVD's Other Medical Device and Orthopedic Related Topics 2
T Cadastro according RDC40/2015 (Brazil) Cadastro Registration Requirements Other Medical Device Regulations World-Wide 1
N Malaysian Medical Device Registration Requirements Other Medical Device Regulations World-Wide 8
M Argentina IVD Registration Requirements Other Medical Device Regulations World-Wide 2
F 2015 Sudan Medical Device Registration and Labeling Language Requirements Other Medical Device Regulations World-Wide 3
E Medical Device Registration requirements for Bahrain Other Medical Device Regulations World-Wide 4
Gman2 Internal Auditing Requirements before ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
X Algeria IVDD Registration Requirements in English Other Medical Device Regulations World-Wide 2
X Indian Medical Device Registration Requirements Other Medical Device Regulations World-Wide 6
M Dominican Republic Medical Device Registration Requirements Other Medical Device Regulations World-Wide 6
M Morocco Medical Device Registration Requirements Other Medical Device Regulations World-Wide 2
M Myanmar: Class I/II Medical Device Registration Requirements Other Medical Device Regulations World-Wide 1
M Croatia Medical Device Registration Requirements EU Medical Device Regulations 2
Q PEAR (Process Effectiveness Assessment Report) Requirements for AS9100 Registration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
N Barcode Registration Requirements for Japan and GUDID Japan Medical Device Regulations 2
Z Kyrgyzstan Medical Device Classification and Registration Requirements ISO 13485:2016 - Medical Device Quality Management Systems 3
S Medical Device Registration Language Requirements in Portugal EU Medical Device Regulations 4
W Mauritius Class IIA Medical Device Registration Requirements Other Medical Device Regulations World-Wide 3
R IVD Registration requirements in Russia Other Medical Device Regulations World-Wide 1
N Service Requirements for Medical Devices after De-Registration US Food and Drug Administration (FDA) 1
B FDA - New Establishment Registration and Device Listing Requirements Other US Medical Device Regulations 14
R UAE Medical Device Registration Requirements Other Medical Device Regulations World-Wide 1
B Bangladesh Class IIA Medical Device MDD Registration Requirements Other Medical Device Regulations World-Wide 6
B Internal Audit Requirements for ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Registration Requirements and Classification in Bahrain and Qatar Other Medical Device Regulations World-Wide 3
F Specific Country Requirements for Medical Device Registration in Europe CE Marking (Conformité Européene) / CB Scheme 4
P Brazilian - Medical Device Performance Evaluation Only - Registration Requirements Other Medical Device Regulations World-Wide 6
M Macedonia Medical Device Registration Requirements Other Medical Device Regulations World-Wide 4
Z CB Certificate and IEC 60601-1 Test Report requirements - Korea Product Registration Other Medical Device Regulations World-Wide 6
B Medical Device Registration Requirements in Kuwait Other Medical Device Regulations World-Wide 13
E Special Class III Medical Device registration requirements in Germany and France EU Medical Device Regulations 2
C Distributing Medical Devices in Belgium - Specific Registration Requirements EU Medical Device Regulations 7
A Convenience Kits - FDA Registration Responsibilities and Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L Thailand Medical Device Registration Requirements Other Medical Device Regulations World-Wide 4
D Class I Medical Device Registration (STED) requirements in China China Medical Device Regulations 1
L Medical Device Registration Requirements in ASIAN Countries Other Medical Device Regulations World-Wide 20
A Establishment Registration Requirements - Combination Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Diagnostic Test Regulations and Registration Requirements in African Countries Other Medical Device Regulations World-Wide 3
P IVD registration requirements in Middle East and African countries Other Medical Device Regulations World-Wide 1
N Requirements for Site Registration for Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Registration Requirements for X-ray & Oncology Product in Russia Other Medical Device Regulations World-Wide 4
L Distributor Registration - FDA Registration Requirements for a Distributor 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R EU Country Specific Medical Device Registration Requirements EU Medical Device Regulations 33
