Regression for MTBF (Medical Device: Repairs vs Install Base) with Reliability Data
Romvill2002
Sorry to throw you guys off the topic but I need help on what should be the best regression model for MTBF(medical device, repairs vs install base)???
Install Repairs
675 15
872 16
1176 18
1353 29
1575 27
1879 46
2035 48
2302 41
2837 63
2961 53
3132 65
3266 100
3425 88
3597 98
3941 125
Romvill2002
Re: Regression with reliability data
Correct, not trying to predict MTBF but just wanna know if linear or quadratic regression is best to graphically represent the data
Re: Regression for MTBF (Medical Device: Repairs vs Install Base) with Reliability Da
what are you trying do? why regression? if you look at the control chart it is clear that this process has two stable periods. something clearly changed at sample 12.
My concern is that you may be making this far too complicated?
Romvill2002
Im trying to find how strong the relationship of service events with the accumulative installed base. Then will try to figure out which control chart should I use. You have chosen a P-chrt and out of control in the sample 12 due to high returned devices for repairs.Should i just use IMR chart or p-chart?
not sure what the relationship between the install base and the count of repairs will tell you without first looking at the time series.
statistical inference and model building do rely on the homogeneity of the underlying process and with the shift in failure rates at point 12 you do not have a homogenous process so any interpretation of the regression plot alone will be misleading as the shift is confounded with (or coincident with) a particular point in time when the install was increasing. for example, if the defect rate is constant, then an increase in the install base will result in a an increase in the number of repairs and we would expect that there would be a linear relationship between install base and repairs. Now, let's say that at point 12 there was a new defect introduced with a new batch of one of the system components. IF this were the case imagine what the defect rate would have been in points 1-11 if those instruments had the 'new defect rate': it would be higher. so the curve in the regression plot is NOT due to the install base as much as it is due to the 'new defect' introduced in point 12.
There are of course other complications that could shape the regression curve. another example is if the repaired units are returned to the install base their defect rate will change and now you have a mix of instruments that will have different failure rates. this is why we often do a 'vintage' time series to pull this apart...
fancy statistics can be very seductive, but I've found that the simple stuff - plot your data in it's rawest forms in time series and ask yourself questions about that first - is a far more productive approach. there are so many nuances about processes that can get hidden by the 'blind' application of statistical tools. If you first understand the nature of your data and the process it represents you will not be blind when you select a more sophisticated statistical tool. I tell my students to imagine what would happen if they were to pick up a chainsaw to cut down a tree but they were blindfolded. :mg:
As for which chart to use, you need to try both and determine which one fits your need best. *I* have found that the p chart works reasonably well with field repair/return/warranty data especially when the install base is growing substantially as it modifies the control limits based on the install base size and this type of data is reasonable modeled by the binomial. the I, MR chart doesn't do that. I have attached a new file that shows both charts for your data; the upward shift at point 12 is still clear in I, MR chart...
Romvill2002
Hi Bev,
Thank you so much. I used the IMR chart, since the device is newly introduced to the market and due to ramp up on sales installed base rate is aggressively inclining. Maybe when both service and install matured then I may use the pchart. What do you think?
given that I, MR charts doesn't adjust for sample size (install base), *I* would do the opposite. This works much better in my experience. p chart first then I, MR chart when the install base stabilizes, it ever. UNLESS you can determine that the underlying process is a large departure form the binomial distribution and I've not seen that in 30 years of doing this...
M Problem with nonlinear regression Using Minitab Software 12
V Regression and homoscadasticity test Statistical Analysis Tools, Techniques and SPC 8
S Significance of regression, correlation coefficient, hypothesesi, confidence interval Using Minitab Software 8
S Least squares estimate, regression model and corresponding residuals Using Minitab Software 13
N Regression Model (Minitab 18) - Which values my input parameters should have Using Minitab Software 2
A Why I get a different kind of regression equation when I do the same data in a differ Using Minitab Software 7
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
C Regression with Life Data, Incorrect Minitab Documentation? Reliability Analysis - Predictions, Testing and Standards 4
P How to do Multiple Regression Analysis in Minitab 16 Using Minitab Software 8
B Using Minitab 17's Stepwise Regression to Predict Feature Using Minitab Software 2
A Predictive Model Development (Regression?) Statistical Analysis Tools, Techniques and SPC 5
S How to use Dummy Variable in Regression Model in Minitab Six Sigma 2
S ANOVA/Regression - Analyzing a Dataset which contains over 4500 Points Using Minitab Software 3
O Minitab Script to Save Regression Plots to an Image File Using Minitab Software 8
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
S Regression Analysis / ANOVA using Excel Excel .xls Spreadsheet Templates and Tools 2
E How to run an OLS or Logistic Regression when I have Panel Data in Minitab Using Minitab Software 1
S Using Minitab for Multinomial Logistic Regression Using Minitab Software 2
J Minitab Rank Deficiency Issue - Binary Logisitic Regression Using Minitab Software 1
M Understanding of Regression and ANOVA in Minitab Statistical Analysis Tools, Techniques and SPC 8
P Regression Analysis for Aging Study in Minitab Statistical Analysis Tools, Techniques and SPC 10
A Questions about Regression for Modeling, Best Experimental Design Using Minitab Software 2
N Linear Regression Formula with Four Variables to a Power Regression Formula Using Minitab Software 2
Q Regression Analysis for the Attached Data - help needed - TIA Reliability Analysis - Predictions, Testing and Standards 13
B Regression analysis with discrete dependent variable and continuous independent var. Statistical Analysis Tools, Techniques and SPC 13
S How to interpret a Linear Regression in Minitab? Using Minitab Software 3
D Multiple regression with student t distribution Using Minitab Software 1
P How to do Nonlinear Regression and generate a Correlation Statistical Analysis Tools, Techniques and SPC 14
BradM Calling all Regression Analysis Pros! Statistical Analysis Tools, Techniques and SPC 1
C Degrees of Freedom with Linear Regression - Pressure Sensor Uncertainty Measurement Uncertainty (MU) 15
S CQE sample exam - Question 23 about a regression model Statistical Analysis Tools, Techniques and SPC 3
R Prediction Intervals for Quadratic Regression Statistical Analysis Tools, Techniques and SPC 4
S Interpreting Linear Regression Results from Minitab Using Minitab Software 15
R Can Factorial Design provide Regression Equation like RSM? Using Minitab Software 4
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
Q Can I use Regression Analysis in the following scenario Statistical Analysis Tools, Techniques and SPC 18
E Minitab Regression Analysis to predict Horse Racing result Using Minitab Software 2
J Binary logistic regression for attribute/discrete data Using Minitab Software 7
M Regression Analysis Help - Factors influencing a Dependent Variable Using Minitab Software 7
N Using Regression Analysis in Excel - Predicting a Value Statistical Analysis Tools, Techniques and SPC 30
W Z-values in Logistic Regression stem from a Wald test? Using Minitab Software 7
W Discrete vs. Continuous Variables and Linear Regression. Statistical Analysis Tools, Techniques and SPC 7
S How to represent interactions in non-linear regression analysis in Minitab Using Minitab Software 5
J Non-Normally Distributed Residuals - Regression to determine how many testers I need Using Minitab Software 13
I Partial Least Square Regression Result - Question Using Minitab Software 3
J Regression Equations - Can you move terms around I.E. simple algebra? Using Minitab Software 4
A Binary Logistic Regression - Evaluation of Survey Responses Quality Tools, Improvement and Analysis 5
J Evaluating a Regression Model Using the Constant Variance Assumption Six Sigma 8
T Value of Regression Analysis in a plastic injection molding atmosphere Statistical Analysis Tools, Techniques and SPC 4
