Regression Model (Minitab 18) - Which values my input parameters should have
N
nicud
I am trying to find out which values my input parameters should have (not which one is more important). I have the following model:
RESPONSE A B C
2 5 10 15
3 10 5 20
4 20 10 20
5 15 5 10
I am trying to make a regression model that will tell me the best values for my inputs(inputs are A,B and C), I read a lot of tutorials but all I learnt was how to find out which variable contributes the most to the result not what values I should have for my variable.
The data that I analyze has about 2000 rows, the lower the response variable the better.
Can anyone help ?
P.S. I am using Minitab 18, new to Minitab :( .
Thanks in advance.
Use Regression to create your final model, then use the Response Optimizer under the Regression submenu to determine the best input levels to achieve a specified output level.
N
nicud
Thanks for the reply, sorry for the late answer.
Not really what I was looking for but it helped ^.^.
S How to use Dummy Variable in Regression Model in Minitab Six Sigma 2
J Point Estimation - I need to use the Quadratic Regression Model - Minitab 14 Using Minitab Software 6
S Least squares estimate, regression model and corresponding residuals Using Minitab Software 13
A Predictive Model Development (Regression?) Statistical Analysis Tools, Techniques and SPC 5
S CQE sample exam - Question 23 about a regression model Statistical Analysis Tools, Techniques and SPC 3
J Evaluating a Regression Model Using the Constant Variance Assumption Six Sigma 8
J Managing design verification regression testing of design changes Design and Development of Products and Processes 1
M Problem with nonlinear regression Using Minitab Software 12
V Regression and homoscadasticity test Statistical Analysis Tools, Techniques and SPC 8
S Significance of regression, correlation coefficient, hypothesesi, confidence interval Using Minitab Software 8
A Why I get a different kind of regression equation when I do the same data in a differ Using Minitab Software 7
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
R Regression for MTBF (Medical Device: Repairs vs Install Base) with Reliability Data Reliability Analysis - Predictions, Testing and Standards 16
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
C Regression with Life Data, Incorrect Minitab Documentation? Reliability Analysis - Predictions, Testing and Standards 4
P How to do Multiple Regression Analysis in Minitab 16 Using Minitab Software 8
B Using Minitab 17's Stepwise Regression to Predict Feature Using Minitab Software 2
S ANOVA/Regression - Analyzing a Dataset which contains over 4500 Points Using Minitab Software 3
O Minitab Script to Save Regression Plots to an Image File Using Minitab Software 8
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
S Regression Analysis / ANOVA using Excel Excel .xls Spreadsheet Templates and Tools 2
E How to run an OLS or Logistic Regression when I have Panel Data in Minitab Using Minitab Software 1
S Using Minitab for Multinomial Logistic Regression Using Minitab Software 2
J Minitab Rank Deficiency Issue - Binary Logisitic Regression Using Minitab Software 1
M Understanding of Regression and ANOVA in Minitab Statistical Analysis Tools, Techniques and SPC 8
P Regression Analysis for Aging Study in Minitab Statistical Analysis Tools, Techniques and SPC 10
A Questions about Regression for Modeling, Best Experimental Design Using Minitab Software 2
N Linear Regression Formula with Four Variables to a Power Regression Formula Using Minitab Software 2
Q Regression Analysis for the Attached Data - help needed - TIA Reliability Analysis - Predictions, Testing and Standards 13
B Regression analysis with discrete dependent variable and continuous independent var. Statistical Analysis Tools, Techniques and SPC 13
S How to interpret a Linear Regression in Minitab? Using Minitab Software 3
D Multiple regression with student t distribution Using Minitab Software 1
P How to do Nonlinear Regression and generate a Correlation Statistical Analysis Tools, Techniques and SPC 14
BradM Calling all Regression Analysis Pros! Statistical Analysis Tools, Techniques and SPC 1
C Degrees of Freedom with Linear Regression - Pressure Sensor Uncertainty Measurement Uncertainty (MU) 15
R Prediction Intervals for Quadratic Regression Statistical Analysis Tools, Techniques and SPC 4
S Interpreting Linear Regression Results from Minitab Using Minitab Software 15
R Can Factorial Design provide Regression Equation like RSM? Using Minitab Software 4
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
Q Can I use Regression Analysis in the following scenario Statistical Analysis Tools, Techniques and SPC 18
E Minitab Regression Analysis to predict Horse Racing result Using Minitab Software 2
J Binary logistic regression for attribute/discrete data Using Minitab Software 7
M Regression Analysis Help - Factors influencing a Dependent Variable Using Minitab Software 7
N Using Regression Analysis in Excel - Predicting a Value Statistical Analysis Tools, Techniques and SPC 30
W Z-values in Logistic Regression stem from a Wald test? Using Minitab Software 7
W Discrete vs. Continuous Variables and Linear Regression. Statistical Analysis Tools, Techniques and SPC 7
S How to represent interactions in non-linear regression analysis in Minitab Using Minitab Software 5
J Non-Normally Distributed Residuals - Regression to determine how many testers I need Using Minitab Software 13
I Partial Least Square Regression Result - Question Using Minitab Software 3
J Regression Equations - Can you move terms around I.E. simple algebra? Using Minitab Software 4
