Regrinding Material - Thermal properties
V
vivkrish
Hi All,
I have a question, Does the regrinding material changes the melting point / Glass transition temperature by lowering it.
Pls clarify.
If yes what will be the lowering temperature range.
Thanks,
Vivkrish.
Ronen E
Problem Solver
Moderator
Regrinding itself probably doesn’t. However, regrind indicates a previous moulding cycle. Each such cycle causes some degradation in the polymer which means lower average molecular weight, which can manifest in lowered characteristic temperatures.
This is very hard to predict theoretically because many variables affect this phenomenon.
V
vivkrish
Hello Mr. Ronen E,
If we use 20-30% regrinding material also reduces the molecular weight of the polymer.?
I have discussed with laboratory where they are doing molecular weight by GPC method, they declared by 20-30% regrinding mixing we cannot conclude the regrinding material mix up.
Thanks,
Vivkrish.
Ronen E
Problem Solver
Moderator
Theoretically, yes.
Anyway, the figure you stated is probably only theoretical too. Because once you’ve used that regrind it goes into articles that will go through regrind again, and so on and so forth. A smaller and smaller fraction will go through more and more moulding cycles, thus undergoing further degradation (reduction in average molecular weight). This generally needs to be factored in, but it’s very difficult to determine the exact resulting percentage / effect theoretically.
A good lab would use a combination of methods and should be able to tell you accurately the molecular weight distribution, level of degradation etc. However, as explained above it would be difficult to state the exact regrind use percentage. To do that you’d have to run a controlled experiment in which you make samples with known (certain) regrind percentage, over a number of cycles representative of real production, and compare with the test results from the unknown-content sample.
One more thing to note:
The degradation in each moulding cycle is not something fixed. It depends on several factors, such as barrel and melt temperature profile, residence time, purity / additives, mould gate design, part design, injection speed profile, in-mould flow path etc. So you can have anything from negligible to prominent degradation in a single cycle, further complicating any theoretical analysis. This is why I recommend a more empirical approach if you absolutely have to know, with medium to high accuracy, the actual regrind content. It would basically be a mini-project.
V
vivkrish
Theoretically, yes.
Thank you Mr.Ronen E.
I will go with testing and let you know the results.
Thanks,
Vivkrish.
V Regrinding Material - Verify whether a product contains any regrinding material Manufacturing and Related Processes 13
Sidney Vianna AS9100 News AS9101 Change Presentation Material AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
I Prototype Material NCR ISO 13485:2016 - Medical Device Quality Management Systems 3
S Gamma Radiation for Packing Material Quality Manager and Management Related Issues 0
J Raw Material Supplier Site Change US Food and Drug Administration (FDA) 0
K Alternatives to Metal Foil for touch current measurement of enclosures made of insulating material. IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C New 510(k) for non-patient contacting material change US Medical Device Regulations 2
J API 5CT - NDE for Accessory Material - Section 10.15.11 Oil and Gas Industry Standards and Regulations 2
GreatNate Looking for Hazardous Material Management Plan example or HMMP assessment checklist Occupational Health & Safety Management Standards 6
G Ergonomic issue caused by supplier material ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Material Heat Number / Lot Number ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
adztesla Change in material vendor - Medical device ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Full Material Disclosure and IPC-1752A RoHS, REACH, ELV, IMDS and Restricted Substances 1
K Critical Material Vendors: Distributors Vs Manufacturers and Supply Agreements ISO 13485:2016 - Medical Device Quality Management Systems 1
G Any training material on the 1-10-100 rule? Training - Internal, External, Online and Distance Learning 4
P AS9100 and Raw Material Traceability AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M ASQ certification study material Professional Certifications and Degrees 1
H IEC 61010-1 Clause No. 10.5 Resistance to Heat - Sub Clause 10.5.3 Insulating Material CE Marking (Conformité Européene) / CB Scheme 6
M Biocompatible material ISO 13485:2016 - Medical Device Quality Management Systems 3
H Pre-production units & Purchasing/Supplier/Material controls ISO 13485:2016 - Medical Device Quality Management Systems 6
T Testing for proving food safety on USP class vi material RoHS, REACH, ELV, IMDS and Restricted Substances 0
Q SUS Material Manufacturing and Related Processes 0
R Finding Equivalent Material Information Manufacturing and Related Processes 1
W Nonconforming-Material Process Nonconformance and Corrective Action 1
Stoic Details of Operational Qualification (OQ) test design for plastic extrusion processes, effect of material property noise, and GHTF/SG3/N99-10 US Medical Device Regulations 2
T Control of Nonconforming Material AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
DuncanGibbons Safe-Life, Fail-Safe and Damage Tolerant approaches and their relevant material property requirements Federal Aviation Administration (FAA) Standards and Requirements 0
T Shrinkage Testing for EPDM Material Various Other Specifications, Standards, and related Requirements 5
M Preparing a document for Raw Material of Medical Device EU Medical Device Regulations 1
J ISO 13485- 8.3.1 Non-conforming material high volume ISO 13485:2016 - Medical Device Quality Management Systems 4
Awais Taking Pictures of Outbound Material - In the Manufacturing Shop floor Manufacturing and Related Processes 5
Q G11 material Manufacturing and Related Processes 7
M Medical Device Marketing Material - Control of Social Media 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Origin of Material Review Board AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
D Raw Material Expirations Manufacturing and Related Processes 2
W What is okay to use as a reference material for ISO 17025? ISO 17025 related Discussions 4
J Scrap Material Scale Calibration Required? IATF 16949 - Automotive Quality Systems Standard 21
R Revalidation under VDmax25 following material change ISO 13485:2016 - Medical Device Quality Management Systems 2
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
S Advice on how to reduce overhead of handling non-conforming material Nonconformance and Corrective Action 7
S Predicate Material 510(k) US Food and Drug Administration (FDA) 1
S Predicate Material 510(k) Medical Device and FDA Regulations and Standards News 3
lanley liao Who can share these material with me ? Training - Internal, External, Online and Distance Learning 1
E Record Retention - Raw Material (Steel Certs) Records and Data - Quality, Legal and Other Evidence 3
M Documents to be included in 1.3 Material check in PPA report APQP and PPAP 4
rerusk1 MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
Q Change the shape of the raw material FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
