Regulations for Yield Reporting and Evaluation Upon Lot Completion
Audit Consultant
After requesting a our medical device contract manufacturer (Class II devices) to provide yield reports with each lot sent to us the Plant Manager is claiming providing yield reports monthly should be satisfactory.
The reason I need this information is to understand if we started with an order and provided components for 250 devices to be produced and only received 220. I need to be able to evaluate the reason for the 30 failures and make a decision as to if there could be other issues with the lot as well potentially improve the process for the next lot.
Do you know of any regulations or requirments under FDA, GMP's, ISO 13485 or other that I can use for my pending discussion that require yield reporting IMMEDIATELY upon lot completion for a manufacturer? This is other than individual business requirements or ISO requirements that require evaluation and reporting under CAPA. Thank you.
v9991
Re: Regulations for Yield Reporting and Evaluation Upon Lot Completion?
from regulatory perspective [ Pharma ]..,
the yield reconciliation is part of the manufacturing controls..
and the compliance is summarized in yearly report. viz.,changes to manufacturing process [related deviations/investigation]; along with respective validations where applicable.
for the supplier control, this is part of initial assessment [audits, quality agreements etc.,] and continuous monitoring [rejections,investgations...].
in short...
your objective of getting an yield update for every batch[supplied to your firm] needs to be handled based on your 'commercial agreement' with the supplier, by making it part of the CofA[Certificate of Analysis];
next level is where you might want the supplier to share the RCA/investigation details to know the impact...what will you do if the investigations are "under-way/not-conclusive"...?
essentially the time-frequency specified for concluding the investigations, should drive the frequency of periodic update which you should expect from the vendor...i will give one more try to search for specific reference so frequency of update for investigations etc..,
hope that helps.
valiveti.
jscholen
The regulations are pretty broad in its application to your circumstance. Components yeilds are a form of quality data which should be inputs into your quality system, but how and when you gather that data is up to you...as long as it seems "adequate".
To comment on the lot by lot data versus monthly data, I would ask how many lots are you processing per month. If its only 1, 2 or 3 lots, I might side with the PM, but if its 4+, where you could potentially plot a trend, then I would argue for lot by lot data.
Like valiveti said, your supplier agreement should spell out what the expectations are...if you don't have verbage about it, then your going to have to negotiate or find a new supplier.
Other things to consider, are you getting back the failed components to investigate? is their inspection of the components the same as yours?.....you might want to change your outgoing inspection criteria to their incoming or inprocess inspection to ensure you guys are looking at the same thing...
good luck.
M Is There a Revision History or Change Log for Canadian Regulations? Canada Medical Device Regulations 3
J Interesting Discussion Compliance with regulations in exceptional circumstances EU Medical Device Regulations 5
M Status of Medical Device Regulations in UK Post-Brexit Other Medical Device Regulations World-Wide 8
G App - Local regulations applicable EU Medical Device Regulations 2
Pmarszal External Standards and Regulations Management Process Document Control Systems, Procedures, Forms and Templates 10
M Advertising medical devices in the U.S - Advertising regulations or guidance documents Other US Medical Device Regulations 3
T Confirming The Local Safety Regulations for Equipment - I'm in Malaysia General Measurement Device and Calibration Topics 0
Q Regulations for Medical Device Kit for Training Personnel? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Medical device related standards or regulations - Disposed records log ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Interpreting China Medical Device regulations/standards China Medical Device Regulations 1
M Informational EU – EMA revised guidance – Questions & Answers on Implementation of the Medical Devices and In Vitro Diagnostic Medical Devices Regulations ((EU) 201 Medical Device and FDA Regulations and Standards News 2
M Informational EU – Manufacturer incident report (MIR) for serious incident- template 2020 (Directives and new regulations) version 7.2 and related documents Medical Device and FDA Regulations and Standards News 2
P Is there a counterpart to the General Safety and Performance Regulations for the USA? Other US Medical Device Regulations 2
M Informational Update – MDR and IVDR implementing measures rolling plan – 2 more NBs designated under the new regulations Medical Device and FDA Regulations and Standards News 0
L Staying up to date on Regulations Other Medical Device Regulations World-Wide 8
M Informational TGA – European implementation of Medical Device and IVD Regulations – Implications for Australia Medical Device and FDA Regulations and Standards News 0
S Mammography standards or regulations for radiology software (no hardware)? Other Medical Device and Orthopedic Related Topics 0
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
K CE mark transition and new regulations CE Marking (Conformité Européene) / CB Scheme 0
M Informational Commission Regulation (EU) 2019/319 of 6 February 2019 amending previous regulations as regards health certification at import into the Union concerni Medical Device and FDA Regulations and Standards News 0
M Informational USFDA – Radiological Health Regulations; Amendments to Records and Reports for Radiation Emitting Electronic Products; Amendments to Performance Stand Medical Device and FDA Regulations and Standards News 0
M End of Life or Device transfer regulations for Legal Manufacturer Other Medical Device Regulations World-Wide 1
F Assignment of Special Characteristics to government regulations IATF 16949 - Automotive Quality Systems Standard 5
D Documentation requirements for the new Medical Device Regulations (2019) CE Marking (Conformité Européene) / CB Scheme 5
M Medical Device News EU – Transition Timelines from the Directives to the Regulations – Medical Devices and in vitro Diagnostic Medical Devices Medical Device and FDA Regulations and Standards News 13
N Per the FDA regulations can a medical device be class I despite that it is sterile? Other Medical Device Related Standards 4
Q How to efficiently and compliantly reference external standards/regulations Other Medical Device Related Standards 2
J What are a Taiwanese Medical device subcontractor's legal responsibilities with Taiwan regulations? Other Medical Device Regulations World-Wide 2
S China 2018 draft Amendments to the Regulations on the Supervision and Administration of Medical Devices China Medical Device Regulations 1
V Class IV Laser Regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M FDA News USFDA Draft Guidance – Clarification of Radiation Control Regulations for Manufacturers of Diagnostic X-Ray Equipment Medical Device and FDA Regulations and Standards News 0
F What directives/regulations apply to Analyte Specific Reagents (ASRs) in EU EU Medical Device Regulations 0
K Moist Heat Sterilization worldwide Requirements and Regulations Other Medical Device Regulations World-Wide 1
M Medical Device Regulations in African Countries Other Medical Device Regulations World-Wide 0
R How to keep track of all FDA rules and regulations for medical device companies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Applicable Medical Device Wifi regulations for various Countries Other Medical Device Regulations World-Wide 7
J FDA regulations vs. IEC 60601-1 Labeling Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
M EU Regulations or Standards for instruction for use (IFU ) EU Medical Device Regulations 3
C "Fast action" claim and MDR (Medical Device Regulations) EU Medical Device Regulations 8
T Research Medical Device EU - Requirements and Regulations EU Medical Device Regulations 13
E Doubts about the FCC regulations for the use of Bluetooth in medical equipment Other Medical Device Related Standards 3
H EU Medical Device Regulations (MDR) Checklist EU Medical Device Regulations 1
C Where to buy the latest MHLW, Canada MDR, Brazil medical device regulations Other Medical Device Regulations World-Wide 2
J Regulations GSM trackers on medical devices EU Medical Device Regulations 2
S MDR (Medical Device Regulations 2017/745) training recommendation for Auditors EU Medical Device Regulations 1
M FDA Considers Shift on Medical Device Quality System Regulations - 2018 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S TGA regulations and ISO 13485:2016 gap analysis MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 2
F India Medical Device Regulations - Update - 2017 Other Medical Device Regulations World-Wide 11
N Customer Survey Question Has Me Stumped - Compliance with Laws and Regulations Customer and Company Specific Requirements 4
L Hearing Aids Labeled as "Used" - Canadian Regulations Canada Medical Device Regulations 2
